I can see the use of these ultra low mode but I don’t use them enough to justify a dedicated mode on my main light. I’m sure if I daily needed a ML mode, I would look for a light that had one but that seems like a very specialized task and shouldn’t be a main mode. Hidden mode like most strobes are? Fine.
So what I propose is all strobes and firefly modes be forever banished to hidden mode territory. Bury them all deep where we don’t have to cycle through them to get to our real light. No normal person carries a 18650 flashlight to have .003 lumen that he could get from the smallest, cheapest, crappyiest light ever. I didn’t become a flashaholic to have weak wimpy light that nobody can see anything with.
You are quite right. For that I carry a small trit light source. It is enough to avoid bumping in to furniture and walls in otherwise complete darkness.
However, I carry an 18650 Olight S20L2 baton with 600 hours runtime on 0.5 lumens.
And the coming A6 GB seems to have a nice moonlight. Very nice...
See, that’s just not true! I don’t know what the real numbers are, but here’s an example to get close. Let’s say you have a 20mA LED light. I can’t think of any LED’s rated lower than that, but maybe I’m wrong. If you say it uses 3.0V, then you have 3.0 X 0.02 = 0.06 watt. At a low rating (cheapie remember?) of 80 lumens per watt, you would have 4.8 lumens coming out of that flashlight! I think most of us agree that doesn’t qualify as “moonlight” mode. And, it is definitely a lot more than 0.003 lumen by a long shot!
Now, I’m not one to use a 0.003 lumen moonlight. But, as others have said, moonlight mode of just under a lumen is plenty of light for seeing in the dark without ruining your night vision, while also taking care not to disturb others who don’t want to be awake at that time. I use my moonlight mode every morning when I get up, so I don’t disturb my wife who is not ready for bright lights yet. I actually very rarely have any use for a very bright flashlight. I just like bright lights, so I have them.
I’ll give you this: I don’t have a problem with making moonlight mode semi-hidden. In my Olight S20-L2, you can always get to moonlight from off. But, if you happen to be cycling through modes, moonlight isn’t part of the normal cycle. I think that’s a decent way to do it. In fact, the Olight UI seems to me to be almost perfect. The only thing I would change is the return from lock-out. The Olight always unlocks into moon mode. I’d rather it unlock into the last used mode instead.
I think your posts on this topic are bordering on divisive. You have a right to your preference for more light, but why are you being so abrasive about other people wanting a lower mode? Why do you feel like you have to insult people for wanting a moonlight mode, and insist that it isn’t really useful, even after being told by so many that it is very useful? Did someone abuse you with a moonlight mode in your youth? :_(
This is ANOTHER post that is a perfect example of what Mike C said in post #41………What I find amazing is how short sighted some people are. When something is of no use to them they simply cannot grasp the concept of it being useful for someone else.
_
This is coming from a guy who has 15 modded throwers staring with one that fits in the palm of my hand[75Kcd] to the TK75vn KT[3300 LUMENS/341Kcd and the TK61vn V4- 750Kcd!!!
Just because you do not like ML or strobe,doesn’t mean it isn’t useful to others! I already posted how important STROBE is to someone walking a Dog on Hilly and curvy roads,I am one of them!
This
Plus, others who really care enough can learn to flash your own firmwares so everything is exactly how you want it. It’s intimidating at first, but in the end very simple.
The problem is, as it has always been. People. Some just like to cause trouble. Some like to see problems develop and arguments come up. Some live to see others get upset or cause controversy. Here, in a bar, in a home, at work, on the street, on the phone, in a war, there’s always someone to stir the pot and others to jump in and add to it. That’s all it is and it’s a waste of time as always.
In case it might help, the Baton.c firmware unlocks to the last-used mode instead of moon.
This bothers me too. As O-L said, it’s a people problem and some people like to cause controversy. That’s how things have always been, but the internet has a knack for amplifying this sort of thing from a nuisance to a danger. Fortunately BLF is pretty resistant to drama, but it’s still worth a bit of conscious effort on our parts to try not to weaponize the conversation so our friendly admin doesn’t have to get involved.
For my practical use, just 1 floody lumen makes a good low. At the other end 500 Lumen is about as bright as I ever need. I don’t work in a coal mine or find I need to light things up more than 200 feet away or compete with the sun , so this range has me covered for 99.99%.
Furthermore…. all lights brighter than about 1000 Lumen should be banned or restricted to special permit use only. There is just no reason why common civilians should be allowed to use so much light. Someone could be temporarily blinded and it’s just gross light pollution. Too much attention is paid to these big bright monsters here.
And for those that think they can get around with these sub-lumen modes, they should be required to wear a helmet. It’s just too dangerous to be stumbling around in the dark this way. Someone could get hurt.
That works for me. Now I’m taking my toys and going home.
I like my BLF X6 on low ( among others).
If I need more light I ramp it up.
I like the ability to flood everything and still light a small area when I need to.
I use low more than high unless I’m trying to impress newbys.
