Meritline spammer! J/K Meritline is good.
They used to be a retailer of mostly recordable optical media and other such related items. But I guess these days there's money to be made shipping cheapo crap from china :).
Now that you mention it, I think I bought CD-Rs from them. Back in the days when Taiyo Yudens were popular. I also bought some recycled ink for my printer. Mainly these days I just buy $0.25-$1.00 items from them
I got the MXDL clicky today. The construction looks decent. I was expecting bad quality but it's actually pretty good. Oh, it accepts a 10440
any idea how bright it it on a 10440
Huh, works with 10440? Not too shabby.
I'll have to try that when I get home.
It's a little bit less bright than my ITP A3 on med (with Energizer lithiums). It's definitely less bright than my BLF delight (also on Energizer lithiums). I'd say it's around 10-15 lumens with a 10440.
I tried a 10440 in my best MXDL clicky (I got 20 of them, and have been using the brightest one) and this thing is distinctly brighter than my iTP A3 on medium according to my naked-eye ceiling bounce test in the bathroom. Since I use the medium mode on my iTP about 90% of the time, I find this to be very useful. Though I'm not sure how long the MXDL will last running on 4.2 volts.
The Focalprice super-budget Tank E08 clones also showed up today, and I was impressed with the their appearance and function. The knurling is pretty good, and the matte finish is handsome and looks rugged. Standard generic Chinese led, with brightness comparable to, if just slightly less than, the MXDL clickies and twisties. The beam is a little blue, which was expected. The rear clicky switch does have a fair amount of side-to-side play, and it is easily activated with light-medium pressure. I wish the spring in the switch was stiffer. It seems stiff enough to not easily turn on accidently in the pocket if stand-alone (nothing attached) but I could see it coming on inadvertently if attached to the caribiner or other keyring attachments and being jostled in a tight pocket. All in all, pretty decent lights - just not sure that they are ideally suited for keychain duty. The form factor is pretty good, otherwise.
Thanks boomhauer for the update! I’m still waiting for mine to arrive, everything takes a few weeks longer down here.
Hmmm, I just ran across the original that these guys seem to be trying to clone...
http://cgi.ebay.com/LD-Series-Black-Aluminum-Body-LED-1AAA-Flashlight-Campi-/270630783450
$70.00 with shipping?????????
http://www.brightguy.com/products/Fenix_LD01_LED_Flashlight.php
Ok, here it's about $48.00 with shipping- to the USA. For shipping to South America it costs a cool $108.00 :quest:
My conclusion? I'll stick my with my $2.00 cheapies thank you very much. I can buy 25 to 60 of these decent clones for the cost of one Fenix LD01. I feel vindicated.
Looks like DX isn't the only one with questionable specs:
Features of Fenix LD01 Q5 LED Flashlight:
• Cree XP-E R2 LED
• 3 brightness levels:
RE: Light from same selller having production differences.
One head aluminum, the other plastic is not surpising - As you know (big) manufacturers /assemblers try to have (3) parts suppliers to pull parts from to protect them from parts shortages. That and there are changes over a production run, the reason I created a thread asking that a "Date Column" be added to reviews, and that any "batch info" /markings that might indicate factory /shift, or batch the units came from be posted as well.
RE: My conclusion? I'll stick my with my $2.00 cheapies thank you very much. I can buy 25 to 60 of these decent clones for the cost of one Fenix LD01. I feel vindicated.
While I'm a fan of quality- that has to be weighed against cost and intended use.
Several years ago I was checking out a piece of property which had a cave.... I had flashlights in EVERY pocket....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320579913319&ssPageName=STRK:MEWNX:IT - the clicky
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320579913323&ssPageName=STRK:MEWNX:IT - the twisty.
Two weeks from when I bought them from HK to here - not the fastest ever but that wasn't the seller's fault - that was down to the HK post. Each light came in a bubble wrap sleeve and they were separately wrapped in more bubble wrap. Both arrived unmarked and undamaged. Why does the twisty have a silly chrome dome on the end to stop it from tailstanding? I'll never understand designers. The AAA NiMH are just about ready to pull off the charger so numbers are as follows:
Clicky:
Switch-on: 20 lumens
30 seconds: 18
2 minutes: 17
Twisty:
Switch-on: 18 lumens
30 seconds: 17
2 minutes: 16
MrLite KC-05 (Lipstick): Lot and lots of modes and mine appears to be completely different from the one reviewed on CPF.
These are the modes I think I have though there may be more - farther investigation required...
Low:
Switch-on: 8 Lumens
30 seconds: 7
2 minutes: 7
Switch-on: 14 lumens
30 seconds: 13
2 minutes: 13
Switch-on: 38 lumens
30 seconds: 36
2 minutes: 33
Switch-on: 61 lumens
30 seconds: 59
2 minutes: 56
More details the next time I update the lumen chart post.
Sounds good Don! Thanks for the update.
Try the MXDLs with 10440 and see what lumens you get.
My MXDLs start out very bright on 10440, but I noticed that they got dimmer after a minute or two. I shut them down after that. Battery voltage measured 3.8V. Lights seem undamaged. I haven’t had a chance to investigate more to determine what’s going on.
Tried the twisty with a 10440. 48 lumens at switch-on, 37 lumens at 30 seconds, dead at 32 seconds. The phosphor appears to be toast ad there was a smell of burning epoxy. Just as well it was cheap! Don't think I'll sacrifice the clicky as it is perfectly usable as is.
Just received my MXDL 1xAAA clicky and twisty pair from an eBay seller:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270554060391
Very impressive for the price. So tiny! Very attractive design, looks even better in real life. Surprisingly the clicky disassembles at both ends, with O-rings. Threads are very dry and scratchy though. The clicky switch is very nice, no flickers. The twisty threading feels quite nice, with a positive feel on the twisty switch action that is much better than I expected. I agree with Don that they should have made the chrome end flat instead of domed. The beam quality on the twisty is rather ringy, and about as bright as my Trustfire F20 on medium, and about the same color as the Trustfire, that is to say, slightly warm white. The clicky, on the other hand, has STELLAR beam quality. Absolutely amazing for a $2 light. I don't know how they did it, but this tiny little thing is amazingly floody, even more so than almost all my much larger AA lights. And the beam is silky smooth from the center all the way out to the aura, quite an impressive spread with no rings or blotches at all. The light color itself is fine for me, although most of you would probably comment that it's a bit blue tinged. But it's not too blue, I'd call it cool white. The battery life is awful, as is to be expected with a 1xAAA light, and even more so with the crummy BTY batteries I used to test. I'll try them with some cheap alkalines later on.
Basically, if you haven't already, buy them. And DON'T fry them with LiON batteries, these are keepers! ;)
