FS: GITD insulation gaskets XML XPG XPE XPL XHP50 nichia
58 posts / 0 new
3Tronics
3Tronics's picture
Last seen: 9 months 3 weeks ago
Hey guys,
Im currently selling insulation gaskets for XML XPG XPE XPL XHP50 nichia
The gaskets will come in a 14/16mm size
Military spec GITD material
self adhesive back
Manufacturers specs for the GITD material glow time is 10 hours (Not tested will be soon) works out about 8 after a full charge, although not a high power glow it does dim over the 8 hours
Glows green
Aids finding your light in the dark or just to give it a cosmetic touch
PayPal and contact email: ledjames92@yahoo.com
Prices:
With PET gasket:
x5 XML2 GITD insulation gasket + PET gasket 16mm £2.50
x5 XPG2/XPL GITD insulation gasket + PET gasket 14mm £2.40
PET Gaskets:
XPG2 size is 14mm
XML2 size is 16mm
I can also do small squares 2,3,4,5mm2 of GITD self adhesive material to sick on your light, or as kit markers.
Or 14/16/20mm circles
Postage (based up to 10 gaskets)
UK £1.00
International £2.00
James
! photo image.jpg1_zpskzizqe1n.jpg!
! photo image.jpg2_zpsrwtc6ger.jpg!
Custom builds | Modifications | Powder Coating
Gallery: Instagram
Edited by: 3Tronics on 06/17/2015 - 07:58
pilotdog68
pilotdog68's picture
Last seen: 7 months 1 week ago
Cool! Are they going to be disc shaped? Butterfly shaped?
3Tronics
3Tronics's picture
Will be disc shaped, in 16/20mm diameters, and if there’s interest maybe even 26mm or bigger, for the larger MCPCBS or different emitter shapes (MTG2etc)
Gallery: Instagram
kronological
kronological's picture
Last seen: 3 years 11 months ago
How soon will you be testing them?
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
nofearek9
nofearek9's picture
Last seen: 3 hours 27 min ago
are they just sticker or they help in centering the led?
3Tronics
3Tronics's picture
In the process now, they seem to glow very brightly for about 1-2 mins,
in total darkness I would say they would glow for a few hours but dimmer, in total darkness it would still be easy to see, same with everything that’s GITD, but testing currently.
Once I have a few ready I will make them available for sale, I’ve tested a few different materials and this is the best one so far
Gallery: Instagram
3Tronics
3Tronics's picture
Insulation gaskets, they stop the reflector shorting to the wires but do not centre the led
Gallery: Instagram
Otanacious
Otanacious's picture
Last seen: 14 hours 34 min ago
definitely interested...subbed Smile
nickzom
nickzom's picture
Last seen: 11 months 3 weeks ago
sounds interesting. subscribed
Werner
Werner's picture
Last seen: 2 years 2 months ago
Interesting, I have made some myself with the gitd sheet from hobbyking.com. This sheet really glows very long and bright, much better than the usual cheap paint or tailcaps.
I made them with a hole punch and/or scissors. Looks really cool after switching the light off :bigsmile: I also have tried to put some foil underneath the semitransparent discs which are available.
I also made some small stickers with a holepunch for offices, and glued them on some lights so that I can find them in the dark.
How do you make the cuts? Do you have a special quadrat puncher?
KawiBoy1428
KawiBoy1428's picture
Last seen: 19 hours 27 min ago
Hey James great idea! How thick are they? And 26mm would be great too!
KB1428 “Live Life WOT
3Tronics
3Tronics's picture
I’ve not decided yet, either just the GITD sheet material which will be about 1-1.5mm thick but maybe with a PET insulation gasket over that as well for better durability when the reflector rubs on it, which would bring it up to about 2-3mm, it will still be lower than the Dies substrate though
Gallery: Instagram
3Tronics
3Tronics's picture
Not a quadrat puncher but a square punch and a circular one for the outer diameter, not that hard to do yourself but you’d have to buy the tools which have added up to over £25 including the sheet so not a great option of you just want a couple of gaskets! My idea is to make a load and sell them in 5’s or 10’s or whatever for a reasonable price!
Gallery: Instagram
Gunga
Gunga's picture
Last seen: 7 hours 9 min ago
I have the glow sheet and a decent small circle punch. Just need to find a square punch. I get my sheets from eBay. Quite costly but very cool stuff.
Ronin42
Ronin42's picture
Last seen: 2 years 3 weeks ago
Can you say MT-G2!
great idea!
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
3Tronics
3Tronics's picture
Ok, I ‘charged’ the GITD gasket with a direct drive XML2 for about 30 seconds, at 13.40, left it in a dark box and just checked it now at 20:51, very dim but visible, so I think more than 30 seconds of light will give it a decent chance of staying glowing longer, 7hrs11mins glow time isn’t bad of 30 seconds of light!
It is very dim but I could see it in a totally dark room with a pale green glow (bright green at the start) I think the reflector in the light will also make it look a bit brighter.
I’m just waiting on some tools to start making these, currently doing them by hand hense the prototype, the final product will have cleaner cuts etc.
Gallery: Instagram
3Tronics
3Tronics's picture
Ronin42 wrote:
Can you say MT-G2!
great idea!
! photo image.jpg1_zpstl6l5xt3.jpg!
MTG2 is a lot harder due to the centre size, I think the XML2/XPG2 will have to have the PET gasket on top otherwise they are quite flimsy so hard to line up, however, this means they ‘flop’ over the wires better compared to the harder plastic gaskets
Gallery: Instagram
bladesmith3
bladesmith3's picture
I am interested also
3Tronics
3Tronics's picture
I’ve put up the possible prices, I have bought 2 sheets of the material so far for a special offer price, I don’t know how long it will last.
Can you let me know if you are interested so I can see how much material I need to buy!
Gallery: Instagram
D10ten
D10ten's picture
Last seen: 1 week 1 day ago
I am definitely interested for the XM and XP sizes.
jhalb
jhalb's picture
Last seen: 4 years 8 months ago
I expect you will receive glowing reviews. :bigsmile:
This is really a neat idea.
3Tronics
3Tronics's picture
Good one Silly
Gallery: Instagram
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 5 months ago
Cool idea! If you plan on doing blue, let me know.
"Those who hammer their guns into plows will plow for those who do not."
3Tronics
3Tronics's picture
I am planning on doing blue! Just don’t have any blue material yet, it is also more expensive than green
Gallery: Instagram
scottyhazzard
Can it take the heat?
Ronin42
Ronin42's picture
James3][quote=Ronin42 wrote:
Can you say MT-G2!
great idea!
MTG2 is a lot harder due to the centre size.
Dont tell me you are an MT-G2 tease Wink
First you show me MT-G2 porn then you play hard to get!
jhalb
jhalb's picture
That just looks incredible! I love it! Beer
3Tronics
3Tronics's picture
I did a test on my DMM with temp probe, It curled up at the sides (melting adhesive?) at 188C degrees and I kept going until 243C degrees, took it off the heat and lit it up and it still glows great! Didn’t take it any higher than that but I don’t think I need to!
Gallery: Instagram
3Tronics
3Tronics's picture
It can be done but i do not have a 9mm tool for the centre, so has to be done by hand!
Maybe I will take special requests Wink
Gallery: Instagram
3Tronics
3Tronics's picture
A couple of pictures:
Convoy C8 SMO with GITD gasket
! photo image.jpg1_zpso7vphc3t.jpg!
Convoy C8 SMO with GITD gasket 1M away (ambient light from TV)
! photo image.jpg3_zpsandhfsrc.jpg!
Gallery: Instagram
Billy X
Billy X's picture
I’d be interested , usual suspects , XML-XPL-XPG.
