Not a quadrat puncher but a square punch and a circular one for the outer diameter, not that hard to do yourself but you’d have to buy the tools which have added up to over £25 including the sheet so not a great option of you just want a couple of gaskets! My idea is to make a load and sell them in 5’s or 10’s or whatever for a reasonable price!
I have the glow sheet and a decent small circle punch. Just need to find a square punch. I get my sheets from eBay. Quite costly but very cool stuff.
Can you say MT-G2!
great idea!
Ok, I ‘charged’ the GITD gasket with a direct drive XML2 for about 30 seconds, at 13.40, left it in a dark box and just checked it now at 20:51, very dim but visible, so I think more than 30 seconds of light will give it a decent chance of staying glowing longer, 7hrs11mins glow time isn’t bad of 30 seconds of light!
It is very dim but I could see it in a totally dark room with a pale green glow (bright green at the start) I think the reflector in the light will also make it look a bit brighter.
I’m just waiting on some tools to start making these, currently doing them by hand hense the prototype, the final product will have cleaner cuts etc.
MTG2 is a lot harder due to the centre size, I think the XML2/XPG2 will have to have the PET gasket on top otherwise they are quite flimsy so hard to line up, however, this means they ‘flop’ over the wires better compared to the harder plastic gaskets
I am interested also
I’ve put up the possible prices, I have bought 2 sheets of the material so far for a special offer price, I don’t know how long it will last.
Can you let me know if you are interested so I can see how much material I need to buy!
I am definitely interested for the XM and XP sizes.
I expect you will receive glowing reviews. :bigsmile:
This is really a neat idea.
Good one
Cool idea! If you plan on doing blue, let me know.
I am planning on doing blue! Just don’t have any blue material yet, it is also more expensive than green
Can it take the heat?
[quote=James3]
MTG2 is a lot harder due to the centre size.
Dont tell me you are an MT-G2 tease
First you show me MT-G2 porn then you play hard to get!
That just looks incredible! I love it!
I did a test on my DMM with temp probe, It curled up at the sides (melting adhesive?) at 188C degrees and I kept going until 243C degrees, took it off the heat and lit it up and it still glows great! Didn’t take it any higher than that but I don’t think I need to!
It can be done but i do not have a 9mm tool for the centre, so has to be done by hand!
Maybe I will take special requests
A couple of pictures:
Convoy C8 SMO with GITD gasket
Convoy C8 SMO with GITD gasket 1M away (ambient light from TV)
I’d be interested , usual suspects , XML-XPL-XPG.
I may need to get some more material!
