I’ve put up the possible prices, I have bought 2 sheets of the material so far for a special offer price, I don’t know how long it will last.
Can you let me know if you are interested so I can see how much material I need to buy!
I am definitely interested for the XM and XP sizes.
I expect you will receive glowing reviews. :bigsmile:
This is really a neat idea.
Good one
Cool idea! If you plan on doing blue, let me know.
I am planning on doing blue! Just don’t have any blue material yet, it is also more expensive than green
Can it take the heat?
[quote=James3]
MTG2 is a lot harder due to the centre size.
Dont tell me you are an MT-G2 tease
First you show me MT-G2 porn then you play hard to get!
That just looks incredible! I love it!
I did a test on my DMM with temp probe, It curled up at the sides (melting adhesive?) at 188C degrees and I kept going until 243C degrees, took it off the heat and lit it up and it still glows great! Didn’t take it any higher than that but I don’t think I need to!
It can be done but i do not have a 9mm tool for the centre, so has to be done by hand!
Maybe I will take special requests
A couple of pictures:
Convoy C8 SMO with GITD gasket
Convoy C8 SMO with GITD gasket 1M away (ambient light from TV)
I’d be interested , usual suspects , XML-XPL-XPG.
I may need to get some more material!
The BLF Ti light with all those grooves and slots.Imagine flat GITD o rings in the base of those grooves , or “swiss roll” budget trits in the front slots :bigsmile: The possibilities are endless J)
Great /Excellent concept! Subscribed.
I’d want some for both xpg2 and xml2
Update:
PET gaskets:
XML2 standard 16mm
XPG2 standard 14mm
These are the only available PET gaskets, eg. If you buy a 20mm XML2 gasket it will have a 16mm gasket on top, if you buy a 16mm XPG2 it will have a 14mm gasket on top
14mm XPG and 16mm XML will be a perfect fit as they are the standard ones
For those who have used the flat PET gaskets you will know what I mean!
OP has been updated with this info
interested in some for XPG2 16mm*
