[quote=James3]
MTG2 is a lot harder due to the centre size.
Dont tell me you are an MT-G2 tease
First you show me MT-G2 porn then you play hard to get!
[quote=James3]
That just looks incredible! I love it!
I did a test on my DMM with temp probe, It curled up at the sides (melting adhesive?) at 188C degrees and I kept going until 243C degrees, took it off the heat and lit it up and it still glows great! Didn’t take it any higher than that but I don’t think I need to!
It can be done but i do not have a 9mm tool for the centre, so has to be done by hand!
Maybe I will take special requests
A couple of pictures:
Convoy C8 SMO with GITD gasket
Convoy C8 SMO with GITD gasket 1M away (ambient light from TV)
I’d be interested , usual suspects , XML-XPL-XPG.
I may need to get some more material!
The BLF Ti light with all those grooves and slots.Imagine flat GITD o rings in the base of those grooves , or “swiss roll” budget trits in the front slots :bigsmile: The possibilities are endless J)
Great /Excellent concept! Subscribed.
I’d want some for both xpg2 and xml2
Update:
PET gaskets:
XML2 standard 16mm
XPG2 standard 14mm
These are the only available PET gaskets, eg. If you buy a 20mm XML2 gasket it will have a 16mm gasket on top, if you buy a 16mm XPG2 it will have a 14mm gasket on top
14mm XPG and 16mm XML will be a perfect fit as they are the standard ones
For those who have used the flat PET gaskets you will know what I mean!
OP has been updated with this info
interested in some for XPG2 16mm*
Ready for sale!
I have 100+ stock of the XPG2 gaskets, but lower quantity of XML2, expecting a delivery of 100+ XML2 next week, so first come first serve!
XML2 temporarily sold out!
All orders shipped, XML2 re-stock expected next week
100 XML2 back in stock!
I ordered a few for the xml2. When they arrive I will post my review here if that’s OK by the OP.
Yes that’s fine, I’m fine with criticism if there is any, it makes me improve!
Here here :party:
wow talk about fast shipping! perfect fit! A+
Edit, fixed errors
