I'm a bit on a flashaholic ration at the moment (my girlfriend is getting annoyed lately about the time I spend hobbying and she is right), but at least reading BLF is not as disruptive for family life as hands-on testing/modding in my hobby-corner.
Can you explain to me why the collar is as large as it is? Couldnât it be just slightly larger than the LED? The distance from reflector to LED is the same as the distance back to the LED so the aim should be the same even though a smaller reflectorâs angles would be wider. It also seems a larger reflective surface would need to be more precisely smoothed and positioned.
OMG, Gaston! That is simply amazing! I had to read the throw figures 3 times before I was sure I was seeing one MILLION three hundred and fifty THOUSAND candela. Good lord! What a fantastic job! You didn't just build your own Deft X, you smashed it into the ground and doubled it's throw. Mighty impressive work.
Santo cielos! Es un lĂĄser de color blanco. Del dicho al hecho hay muuucho trecho! pero no lograste, huevĂłn lo superaste! Ya el foco tuyo es el cima. Quedo buenĂsimo.
Nice work, and very impressive figures youâre seeing.
I would like to see verification of those figures measured at greater than 6meters though.
Call me skeptical but I consistently see artificially higher candela figures when taking measurements below 10 meters. The beam isnât really formed yet at that range (provided the focus is set for maximum throw) so Iâd be really interested in seeing what kind of difference in throw (if any) you get when measuring at longer ranges i.e >50meters.
Oh and if youâre not happy with the look of that plumbing pipe, have you thought about finding and combining some cheap lens hoods/filter rings on ebay that will fit that 78mm lens? Itâs a good size lens for that kind of approach!
Keep up the great work
Thank you all for the comments, make me very happy , and encourages me to share with you my same passion, I regret not having done it beforeâŠ.
Hi
Sorry I can not explain how it really works this necklace is that it is very complex and is beyond my knowledgeâŠ
When came this technology, also ask to try to see how it works but got no specific answers so I decided to buy it and experiment with the.
Yes! in the city, I get light to the naked eye, some water tanks very high towers located 1.5 km according to google earth, Iâll try to take pictures of it
Buen español! muchas gracias
Hi
I too would like to compare values with some of you but we are far unfortunatelyâŠremember that the head is moving and lets you focus at the desired distance, inside my house fully measured from 3 to 9 mts mts focusing on die each measure correctly and I had no variation to convert values to 1 mts, instead on my mods flashlights with reflector always find variations measured at different distances above, not very big but variations at the endâŠ.
Measurements at close range really hurts sight watching the die, the light spot is in my eyes for a few minutes :~
Also, I will try to make measurements tens of meters, when given the opportunity
Ah yes, forgot you said you had a zoom ability. That would indeed improve the accuracy of measurements at various shorter distances compared with a fixed focus lens tuned for long range performance.
Iâd still encourage a long range test to reduce the margin of error on distance and am curious to see how the numbers shake down.
I was so impressed with this, I began experimenting with a really poor manâs collar. I had a couple of cheap parabolic reflectors from some old solar spotlights, so I cut the top off and proceeded to try and wrap my head around the concept. It seems like you get maximum results by focusing the light back on the emitter, it worked! Then I played with a couple of lenses from old binoculars and a large magnifying glass. Finding the right focal length may be a challenge but it is definitely doable.
Check out the Courui link in my signature, weâve been looking at some cheap diy collar options. Up to now melon ballers seem to be a pretty good budget option
I wonder what would happen if you drilled about 3 holes in the collar, evenly spaced. Then focused three 445nm laser beams of say about 150mw each on the phosphor. Hmmmm
