Tom, you mean 17mm DD+single-7135 driver ? Can it be controlled via an el switch? Thats the main reason i wanted to try this driver out
Well, i will test that MOSFET anyway, ordered a sample already
Yes, this: https://budgetlightforum.com/t/-/31102
I've built a couple with my custom e-switch firmware, based on the latest version from JohnnyC, STAR_Momentary (http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/head:/JonnyC/STAR/STAR_momentary/). It has full support for the two PWM outputs. Recently modded a UF F35 e-switch light, a Yezl Y3, and now I'm working on a ZY-T11 clone. I got amazing #'s on the F35 and Y3 in a neutral tint, so expecting the same for the very pocketable ZY-T11 clone - it will have a MaxToch 25mm MCPCB screwed down, 20 AWG wires with the LED+ direct connected to the spring from the LED via holes drilled thru the stock driver (stripped) and hole drilled thru the LED+ pad on the HYBRID board. The ZY-T11 clones from BangGood is a great deal for what you getting, and really nice mod host. Like the lockout feature of the anodized thread tailcap, very compact size, nice size reflector for some throw, can take a big MCPCB, excellent reflector for wire soldering clearances, etc. The quality of the anodizing is fair (not good) and you play the lottery on what condition it will be in, but I lucked out on the 3 I've gotten.
I was sniffing around a bit and found Farnell:
http://bg.farnell.com/international-rectifier/irlr8721pbf/mosfet-n-d-pak/dp/1551907?ost=70N02&rpsku=STD70N02L
They seem to be shipping to many countries. And then there are also Mouser and Digikey. Those I think are the big international ones in electronics, from the west at least.
Lots of different FETs will work, with the most important factors being on-resistance at 3V-4V gate voltage and total gate charge. A good starting point is to look for a logic level FET with as low of on-resistance at 4.5V you can find, then go into the data sheet and look at the resistance vs. gate voltage figure.
Gate charge should only be a problem when you get up into the 80+nC range. Generally if you stick to FETs that are 30V or lower drain-source rated you will be well under 80nC, and probably under 50nC. The problem you run into with too much gate charge is that the attiny has a hard time switching it directly at fast PWM in the middle modes. If you do run into this problem, you can always put a gate resistor inline.
There are some "big" DPAK-2 FETs that perform slightly better than the IRFR3711ZTRPBF that I now stock, but the difference was slight and the cost increase was huge. Kind of like a PSMN3R0 vs. the SIR800DP: a tiny, almost imperceptible improvement, but at twice the price or more I don't think it's worth the cost.
Thanx Richard for the info!
Yes - I bought a dozen of the SIR800P's at $1.50 each, so I'm burning through them. It's hard to say what's worth 75 cents, and I'm not sure if I'll continue buying them. Putting it in perspective of what the total cost of a full mod is, it's certainly a small part of the typical $12-$24 (driver, LED/MCPCB, UCL or AR lens, materials, etc.). I lack the time and maybe expertise to setup a proper test bench for comparing these FET's, so I really appreciate your experience and knowledge on this.
this post was terminated!
Some very important tools/rules (hope it helps and not too late):
It's certainly not for everbody - I could never have done it on my own without professional help I got from guys at work who know wayyy more than I do (super tech, EE's, etc.).
Of course this list is only partial... Probably could add a dozen more things...
Thanks a lot for the help!
I used one of those cheap ebay loops, which helped me to see that one of the legs of one of the components was just hanging in the air... put solder on there, and now its working..pffff
For this kind of stuff I use a stereo microscope, nothing beats that in seeing what you are doing.
I have one of these oldies (Olympus zooming stereomicroscope) , but any type will do a fine job.
I use a $4 magnifying loop from FastTech (fasttech.com-rotatable-25mm-40x-magnifier). Can't find a link right now for the glasses, but think I use reading glasses in the range of 2.0 to 3.0. You can get them at drug stores ($10-$60) or cheaper ones online.
You can go cheap and still practical .
Bought a Radio Shack helping hands thingy a few months ago…. and NEVER USED IT!The glass is distorted bottle glass and the helping hands move about too much. P.O.S! Headlamp, aaa light, vice grip and a magnifying glass like what Tom linked to above are what I use. A needle nose tweezers are useful too but be careful! When a smd part pops out of those, they going flying off into oblivion!
Same here - I have a couple of those helping hands things and never used them. Can't figure it out, but same problems - mag glass is worthless and hands are too lose and unstable. I use a Harbor Freight desktop vice for just bout everything - with or without the rubber snap-ons, depending. The rubber snap-ons are now in real bad shape - too much distortions and damage from heating, filing, etc.
I bought a high end headlamp, Nitecore HC90 I think it is, helping hands, and of course I have macro lenses with full frame camera sensors that work in live view.
I don’t use any of it, merely take off my glasses and go to work. Sometimes when building just one driver or with limited time I hand solder the entire driver, solder paste masks be danged. I even spent good money getting a 1” thick piece of aluminum machined to fit on a 6” burner, it sits in my file cabinet.
I use the bevel tip that came on my Hakko, for everything. If it gets to not working I either scrape it off with my scissors or file it down then re-tin it. Supposedly you can’t do this, but it’s been working for me for 2 years. Don’t tell me what I can’t do, I might unknowingly succeed.
Yes, I know I bought few other things never wound up using.. But love my HC50 - nice wide coverage, use it on 3rd of 5 modes. Just wish it was more neutral tint than cool white -- looks like a bugger to take apart to mod. I really can't see as good without some sort of headlamp or extra light source, though I got 3 big flourescent fixtures in my small room - well lit. Before I used to use an 18650 tube light w/TIR optic in a NiteCore headband, but the headband would stretch out over time, and the light would end up drop'n right where I'm working...
How big host will you need to run DD? Will a Ultrafire/Convoy C8 be able to take the heat? Is there a chart somewhere that shows current and time with a good battery for this kind of driver?
Edit: Haha, Tom E is BLFs own little Sherlock Holmes with all his home made solutions. :bigsmile:
The host size for DD is pretty much personal opinions but there's also a lot of contributing factors:
I got a 14500 size light, the G10 (dx.com/uniquefire-g10) doin bout 1,100 lumens with a 15DD driver, but actually it's a pretty chunky little light, big for AA size.
I got this for home use last year, and its the best 8 euros deal i had( bought it localy)
Modded the build in diodes with Nichias 5000k(5mm, 32k mcd)
That's a pretty darn nice setup, specially with Nichia's. Like it! Might be worth look'n around for.
Yeah TOm, the lens are glass ones( borosillicate, at least they stated so) the stand is high enough, has a build in 3xAA battery case, came with 220v adapter and a solder iron stand but i removed it
It has 6 emitters in that lamp but the default ones had a huge blue tint
For 8 euros its a great deal, prolly it could be found cheaper in the US( here we have massive taxes and VAT)…but even if it costed 15 i would buy it, i had several “third hands” bt this one is the best so far
Thanks to Tom E and his embossing gun idea this has been my set up for led reflows and one unsuccessful attempt at a driver build. It works like a dream for me reflowing leds. The helping hands are raised and lowered depending on how quick I want the item to heat up and how hot it gets.
The embossing guns wire clip stand just sits on the ally RHS and the gun removed without effort when not being used.
For anyone in Australia the gun came from Spotlight though compared to Chinese prices was not that cheap. The helping hands came from Jaycar at a real cheap price and have no issues with the magnifying glass that came with it. The small alligator clips are pretty flimsy though the way they are mounted in their holders but do the job. I also use the ally RHS as a spot to sit drivers etc when holding them in the helping hands to stop downward movement when soldering etc.
