The only firmware change I can think of which might be relevant is to change FAST_PWM_START to 255, to force it to use phase-correct PWM. But this would likely only change the numbers by a tiny tiny amount (like half a percent).
The rest is probably due to hardware. You might want to try bypassing springs, checking your measurement setup, using thicker wires anywhere possible, using a hotrod cell, etc. Might also be worth checking to make sure the light hadn’t already stepped down from maximum when the measurement was taken.
The emitter type and vintage makes a big difference too… if it’s a recent XM-L2 it might not be able to go as high as an older XM-L2, for example.
I’m not sure what the best practices are for high-amp measurement, but it seems like most people prefer to use a clamp meter and thick short wires and it probably doesn’t work as well to use a traditional DMM on an open tailcap. I recall a lot of discussion about this on the BLF X6 thread, and how hard it is to accurately measure amps. It might be easier to measure lumens instead.
I use this method on the 84 and 85 as it has 512 bytes. I already have an array of 16 bytes full of different settings not that are changed unless user enters the user programming mode, so before this array gets filled up with the stored settings I use it for looping through as described to find the mode bytes.
On the 13A I’d go withToyKeeper’s suggestion. There is no need for the array really, just use a single byte. You won’t notice any difference in start-up speed, takes less space to program and uses less RAM.
That’s really strange. I’m not as familiar with STAR; I only changed what was necessary to make it work as a 1-mode driver.
Looking again, I see one other thing which could make things a little weird. STAR sets alt PWM (in set_output()) to the same value as the primary channel (regardless of whether it’s compiled to use dual PWM), so it’s turning on both channels on a 2-channel driver. In my blf-a6 tests I found that turbo is actually brighter with only the FET channel — turning on both the FET and 7135 causes lower output. So if you’re using a 2-channel driver it might be that the 7135 is actually getting in the way.
More generally, I’m not certain it’s a good idea to run at full direct-drive amps on a 1-mode light, unless you make the turbo timeout really short. If it’s mounted on a weapon, there’s no skin contact so nobody would notice if it gets really hot.
Wow, interesting... Not sure if the Studio IDE set that somehow by default. It's in the Compile "Miscellaneous" settings. When I create new solutions/projects, I simply copy a previous to begin with.
I was thinking about doing it byte by byte but thought it would be too slow so I went with a 8 byte array instead. I got plenty of space in ram anyway but I may switch later when my flasher arrives. But i don’t want a noticable boot time in my driver.
Edit: Using an array was a bit tricky with a weird pointer to the eeprom adress. Must get my flasher to confirm I got it right.
The attiny13a is running at 4.8 MHz. It only takes a few clock cycles to check each eeprom byte, and there are 64 bytes. Let’s say it takes a dozen cycles each; that’s 768 cycles, which should take about 0.16 ms total. The data sheets suggest an array might save about four clock cycles per byte, but it’ll still be roughly 0.1 ms.
Can you feel a boot-up difference of 0.05 milliseconds?
In general, yes, phase-correct PWM is a good idea on the highest level. It doesn’t usually make any noticeable difference, but it’s nice to make the code default to phase-correct to account for the few cases where it matters. I don’t think the hardware has a default; you have to explicitly tell it to generate pulse waves because those pins can also serve other functions.
Well, the timer is set to arround 1.5minutes- then it ramps down to 50%, the FL body gets only warmer this way ….plus when its mounted on a weapon it lights for usualy 10 seconds tops- i use simple momentary on self made remote switches, made from thick Cu pads: found that those are most reliable, especialy with all that forest fog and moisture
The 7135 thing……you might be right, i have to try the 024 version out then
Once again, 10x for that 1mode version, i waited for this long time
Most likely not. But, you can have all the mhz in the world, if it’s slow reading from eeprom it’ll still be slow. Look, I’m not saying it’s too slow reading byte by byte. I thought it was faster reading 8 byte blocks but if it works reading byte by byte that is a simpler solution.
Ish. I normally use phase-correct on moon and turbo, and use fast for everything between. The pulses are longer with phase, which makes moon more stable (drops less with voltage).
But if it doesn’t bother you, you could use phase everywhere. I don’t like the whining sound or visible flashing, but not everyone is sensitive to those.
Getting rid of buzzing pwm modes are my main motivation for writing my own firmware. But was thinking about something else. How do the different sleep modes work? SLEEP_MODE_IDLE just seems to be doing more or less nothing. I’m more curious about SLEEP_MODE_PWR_DOWN though. Does it turn off the output? If you run a special mode like ie strobe it could be a bit tricky to turn it off manually otherwise. You only got a few bytes to play with so would be nice if output is turned off automatically when going to SLEEP_MODE_PWR_DOWN.
TBH, I haven’t really optimized much for sleep mode. I have some relevant patches waiting for me to merge and test, but I haven’t done it yet…
In sleep mode the PWM counter stops, but I haven’t specifically tested to see what that does when I don’t set it to zero first. I expect the emitter would stay on if it’s not turned off before entering sleep (which is a trick I use for the standby light on my Roche F6, but first I set it to a special non-PWM low mode).
Interrupts can wake up the MCU from sleep mode, if they are enabled and a relevant event happens. Touching the e-switch is one example, or the watchdog timer can do it too. So for low-power shutdown it’s usually a good idea to disable interrupts too. On e-switch standby though, at least the switch interrupt needs to stay on.
Hey thanks for the tip. By adding c99 to the makefile and using inline for a few functions that only run once I managed to save 40 bytes. It looks like c89 is the default you get. Using c11 didn’t change anything for me though.
Sorry, I’m still a total noob at this. Is this close to what would need to be done? The purpose is for my XinTD X3, i want to have one mode group for 18650, and one for use with 3x alkaline AA’s. So I don’t need LVP for the AA’s.
What is the lower PWM limit where you switch between phase-correct and fast?
Interesting. I never looked at the E-switch versions of Star. I coded my own E-switch routine by changing the watchdog timer to the fastest and have the switch test in my main while(1) loop. It may have made the logic pretty easy but I guess it’s not a power efficient way of running things as my entire main routine with voltage monitoring and all gets executed a whole lot more. Has anyone done any tests? Or maybe this stuff can be found in the datasheets, haven’t looked at MCU power consumption at all.
I use phase for moon and turbo only. The threshold is whatever level I need for moon. Usually I calibrate this per-light, using whatever gets me closest to 0.3 lm. However, if the two nearest phase levels are too far apart and a fast PWM mode gets closer, sometimes I’ll use fast instead.
I doubt the MCU power consumption is a significant factor when the main emitter is on. I mean, it normally spends most of its time in busy loops… so I doubt it matters if you check things more often.
As for e-switches, I’ve been meaning to write a new e-switch code base from scratch. The approach used in STAR works and is compact but makes it relatively difficult to handle or map events. I’m hoping instead to keep an event queue where actions can be mapped in more intuitive ways. For example, “if (events_eq(triple_click)) { blah; }”. This might require a bigger MCU though; my early experiments ran out of space quickly.
After using cypreus2 on a real light for a day, I decided the hidden modes were in the wrong order. I updated it to make things a little nicer by default. Here’s the new interface:
I still have 70 bytes left to do something with, but I’m not sure what. I know I don’t have to fill all the space, but maybe there’s something worth adding? I might be able to fit soft-regulation for moon, to make it more stable at different voltages…
BTW, the reason it has two turbos is because it’s running on a light which goes well beyond the sane limit for power in its size — 10 to 15 amps in a little 18650 tube light (2200 to 3300 lumens, depending on the hardware). That’s the same as a Skyray King or Supfire M6, only in a much smaller host. This is configurable in the firmware, of course, but I don’t want to melt my nice new hotrod.
