**Update April 21*…Gearbest has decided to give the go signal to start this gb as the intended number of participants coming from the other gbs in the other fora around the world has already been met.
The gb coupon is OPUSBTGB.
WW1504210048269000
W1504210044207815
The “I confirm” names from 2 to 8, have 24 hours from now to make the order, or until April 22, 5pm HK time. They should post their order number within this time span. Those who does not will not qualify for the giveaway. Thanks.
I’ve decided to hold off on this. Thanks anyway for your efforts.
2. itsonlyme
3. Nguyen
4. p5bdkw
5.
6.
7. dekelsey61
8.
The following names are requested to post their order number not later than tomorrow, 5pm Shenzen time (about 18 hours from now) in order to qualify for the giveaway.
W1504211129458370
W1504200343216831
WW1504211334113710
update: April 22, 5am: Cut-off of all submitted order numbers will be this afternoon at 5pm. Shenzen time, and drawing of winners will be done sometime later.
WW150421143175644
WW1504220022562654.
Guys,
The submission of early bird order numbers is now closed. Winners to be announced later. Thanks!
The Early Bird entries are:
1. mrsnrub
2. RollerBoySE
3. Nguyen
4. Yanix
5. p5bdkw
6. dekelsey61
7. PeterWebtrax
Congratulations to Nguyen and mrsnrub !
To the two winners, please choose your prize ( ANY one cell only, not in pairs) between the two links below:
http://www.gearbest.com/keeppower~~\_gear/ OR http://www.gearbest.com/nitecore-rechargeable-battery~~\_gear/
Then send a pm to *Gearbest *of the link of the product of your choice to below: (please do so within 7 days)
http://budgetlightforum.com/messages/new/10960?destination=user%2F10960
Thanks and till the next group buy, folks!
Thank you tatasal
Nguyen
Thanks tatasal. PM sent
PM replied to.
“Generally the peak charge and discharge current for LiIon are a bit high ….
for normal charging I will still prefer a charger with non-pulsing CC/CV charging.”
— HKJ’s latest review
Any hope if we wait that those problems will be improved?
Has the new charger ability to switch to 4.35V without opening it?
No, but if your are a bit proficient in using a screw-driver, it is just about a 4-minute job.
