New: Noctigon Meteor M43 ; in production New color added: Tan
fresh off hanks site:
Led & Tint OTF Lumens Peak Beam Intensity Kelvin
CW S4 2B 6900lm 33,600cd 5700K
NW S2 1D D-D* 6300lm 70,000cd 5000K
NW S3 3C 6600lm 32,000cd 4885K
NW 219BT 92CRI 4000lm 20,000cd 4790K
NW XP-L D-D* 8000lm 44,000cd 4440K
*D-D refers to De-Domed LEDs.
Led & TintCool White - XP-G2 S4 2B
XP-G2 S2 1D de-domed ( +$10.00 )
Neutral White - Nichia 219BT 92 CRI ( +$30.00 )
Cree XP-L de-domed LED ( +$60.00 )
I think for $60 we should get a choice of which XP-L
and just to drive em crazy how about a choice of optics?
I wonder what it would look like if the 10511 were used but the interior TIR surfaces polished for a more throwy effect while the outer TIR’s kept the diffused surface for spill? Or maybe the other way around? Polish the exterior set?
Ok, so I’m not gonna toss a beamshot in here. I’ll figure all that out later and start a new thread with comparisons. Sorry.
Does this mean you have the light?
Just a teaser photo? :slight_smile:
we NEEEEED a: NW S2 1D D-D 6300lm 70,000cd 5000K beamshot!!!
at least i do… :wink:
i am afraid about green XPL (thats why i willl not go for max Lumens)
but max “throw” would make that thingie most useable…
am I right?
am I?
:smiley:
Jetbeam at one point came and made a flashlight which they said limited production 1000pcs world wide. Just put that into perspective, such companies as Jetbeam and Nitecore with huge distribution worldwide make thousands of each model, maybe like 10,000pcs per model.
You can read the claim here of 1000pcs: http://www.jetbeamlight.com/ShowProducts.asp?ID=68
Before I convince myself to get one, will Panasonic NCR18650A work with the meteor?
Some of the weakest cells, they won't power the M43 on Turbo, voltage sag is way serious on those.
And if they are protected they are even weaker. Even Sanyo UR18650FM outperform the NCR18650A and they were available at the same time.
Can you recommend the cheapest cells that’ll work? Need to cost the purchase :smiley:
Thanks HL!
Edit I also have 4 Fenix 2600 batts. Those ok?
I assume you meant these Sanyos? http://intl-outdoor.com/2-pcs-sanyo-18650-2600mah-liion-battery-p-135.html
I have heard good things about Samsung 20R and 25R as well
Cheap and extremely powerful (they have to be button tops), right about the best cells you can get.
LG ICR18650HE2 or LG ICR18650HE4
Edit: Yes or the Samsung 25R
Unfortunately, its difficult to ship stuff from the US. Id rather get it from China
Maybe good to let us know your exact location.. whats BN?
from europe:
http://eu.nkon.nl/rechargeable/18650-size/efest-imr-18650-battery-35a-purple-2500mah.html
from china:
They should have the same LG HE2 inside
Reposting in this thread…
I know to get the most out of this light, you should be using high drain, low resistance cells. The problem is, I’m looking for something relatively cheap, has a high capacity (>2900mAh) and performs well.
These are the candidates:
- Panasonic NCR18650PF (2900mAh) at US$55.90 for 10
- LG HG2 (3000mAh) at US$66 for 10
- Panasonic NCR18650BD (3200mAh) at US$72.80 for 10
If you simply go for $ per mAh ratio, the best option is NCR18650PF at $0.0019 per mAh. The LG is a little bit higher at $0.0022 per mAh; NCR18650BD is $0.0023; and NCR18650BL is $0.0025.
I’m leaning towards the LG HG2 because that has more headroom at 20A versus NCR18650PF’s 10A discharge.
But you need button top battery for it. To make contact and to not to be too short(as is written on fonarevka).
Solder. Make your own button top cells with it.
Rod911, forget about capacity, it is irrelevant becasue you do not care what capacity can be gained after 3V (most cells are claimed for down to 2.5V). And for any serious flashlight you only care about capacity that is resulted at 5A-7A down to 3.6V, after that all cells are way too weak, to matter what they offer at ultra low voltage.
Take a look at this and see the capacity at 3.6V, you will see how the NCR18650PF are the last option and the nominal 2900mAh is irrelevant for 5A.
Solder will be sanded off in time due to friction.
I know. That's why you do it again when it wears down?
I'll stick with my original thoughts and get the LG INR18650HG2 cells. Thanks for stating the obvious.
