As medieval told, quality not so good, and now less bright. Dont buy... is a new batch, was sold out on June-July. New batch from latter July - August. Bad
On mine which I got early august, the quality of the build is quite decent. Coating is very hard (seems like ha-iii). The only "problem" on mine is I"m not sure whether the kinda poorly defined hotspot is due to the emitter board being slightly offset (and way too much thermal glue). I'm getting a smooth reflector to see if I can improve. it.
The coating on mine is pretty soft - you can see scratches on it where the wire clip has moved against the knurling. A Hugsby P32 which claims type 3 anodising can scratch it.
I used pliers on mine and paint only came off where I took off/reshaped the base metal. Maybe it's just really tough ha-ii.
The wonders of chinese quality control.
Interesting aside: some tools/knives I got from china have a pretty tough black finish on them (not just cheap paint). The same finish is somewhat expensive (~$10) on similar "brand name" tools. It costs <$1 on the chinese ones.
I got the red black cat 5000k from kd today. It's very good, and surprisingly 5000k (not warm like the pic previously featured here, I suspect that's the "yellow" warm version). A little less bright than the AA-S1 with nihm, but not night and day.
Buy it.
BTW, the AA-S1 I have is not nearly as bad as midieval's, and I only got it a couple week before this. Mine is quite bright on 14500 as well (~200lum I'd guess). His looks awefully white in tint (more so than the crees), and only my nice warm cree drop-in is warmer than my AA-S1 osram. Oh well, chinese lights.
I have noted that the older versions of Black Cat were coming with a LED with 5 divisions (4 lines). Now they are coming with 2 divisions (1 line). So I beleive that the one with 5 divisions is Golden Dragon Plus. The one with 2 division is simply Golden Dragon.
I imagine that with the AA-S1 happens the same, previous versions were with GoldenDragon PLUS and the last ones with simply Golden Dragon.
Do you have a convex lens? can you put one in front of the AA-S1, light it up and see how many divisions has yours?
Also Don can do the same in his S1, also Medieval, to compare
Look the drawing showing the LED die. First versions of Black Cat were coming with a LED which it´s die was like it, 4 lines, 5 divisions. Now the Black Cat is coming with same LED but with 1 line, so 2 divisions and is less bright than older ones.
I beleive that the one with 5 divisions is GDP and the one with 2 divisions is GD (not Plus)
I whish to know if older AA-S1 were coming with 5 divisions LED and newer are coming with 2 divisions LED
The digikey link above will go to photos of the emitter. I don't know what xrayboy is drawing, but it's not a dragon plus according to digikey (one of the premier US parts suppliers).
No, you are correct to some extent; this 5 square pattern exists. I searched pretty exhaustively on digikey and there exist OSRAM GDP part numbers with that sectioned design:
The pattern I'm able to discern (I don't know if it's 100% as the OSRAM datasheet nor any of their application notes specify this) is that of the "pure white" parts, the 6500K ones are two squares, and 5600K ones are 5. HOWEVER, all GD parts also share this trait (5600K):
ALSO, of ALL the "warm white" parts (2700K, 3000K, 3500K, 4000K, 4500K), none I could find have the 5 square shape. So this would imply the one I got is 4500K and not 5600K. Other than this, I'm not sure this means anything else. All are 1A max, and of course flux bin is not marked.
This took quite a bit of time.
I would've like some of the 5600K's, but I guess they don't ship them anymore. Oh well.
