I’m still trying to figure out if I can afford one… and I have until the XP-G2 3D version comes out to decide. 3D is the sweet spot for pure neutral white in Cree emitters, and this light makes one hell of a nice flooder.
I’d like to see a beamshot of the 1D dedomed to see if I can stand the tint (I’ve yet to be pleased with any dedomed CREE tint). Unfortunately, so far nobody’s posted a beamshot of that emitter. :weary:
I don’t really want to spend this kind of money on an emitter with tint I might hate, especially given the complete absence of beamshots. I haven’t even been able to find a beamshot of a dedomed 1D in a different light.
FWIW, tint is remarkably difficult to show effectively in beam shots. Cameras and monitors simply don’t have the right sensors and emitters to portray tint accurately.
I did the deed and ordered one in stone white with S2 1D’s dedomed. Depending on how easy it is, it may get half dedomed XP-L V6 3C’s after it gets here.
Todays digital sensors are very well capable of showing tint differences, all depends on how you set the camera up for the shot. (Maybe it’s the $8000 sensor , not sure?) And today’s monitors have also come a very long way.
I will try, it’s almost dark and my sample’s cells are almost recharged.
An early observation/question has come to my attention…. the cells are none too tall in the battery tube and I’m wondering if the short phosphor bronze springs are taking some set with heat as Djozz found with his samples. Might it come to be that the cells won’t make contact? Seems like early pictures of this light showed the button top cells slightly protruding, these are slightly below the rim of the tube and I don’t feel like they’re being compressed by the springs very firmly when screwing the light together. They don’t rattle, but they can’t be in there really snug it seems like.
Could anyone give some feedback on this potential issue?
Oh yeah, these pics are with the Canon 20D and 24-105mm f/4 L IS lens. Settings are ISO1600, f/4, 1/8 second exposure. The red oil drum is at 97 yds, lens was at 24mm for the beamshots (or equivalent to about 29mm on a 35mm film camera or full frame sensor)
Those 10 lights use 42 batteries, so all of them are not in their optimum arrangement. lol The Meteor is, with freshly charged HE-2’s. Several of the others that should be kicking some bu… have lesser cells or rested/partially used cells.
Looks very nice to me and anything less is going to be all flood.
The lumens figures in those pictures was measured in the box right before taking the pics. Those are the real time numbers for the picture you see. So for a light like my Eagle Eye X6 Quad that typically makes some 4500 lumens, tonight it came straight out of my pocket, partially used cells, and was measured then shot.
I purposely did not match up any of the 10 lights, left the photo order pretty random so as not to be misleading. The Nitecore Caveman AA light just came to me today so it’s in there as a first measure and as a stock AA light. Surprisingly tight beam, old XM-L emitter even.
It’s not green, more of a yellow/orange warm at lower power that get’s whiter on the high end. Not a problem to me and definitely better than most XM-L class emitters when de-domed. The XP-G2 seems good in this respect, holding a more pleasant tint when modified.
This is the XPG2 DD sample obviously? How does it handle the heat? This light lowers the output the hotter it gets right? No thermal stepdown or turbo timer right?
