They were like that when I first pulled it out of the box. No connection issues with the button top cells. The driver contact protrudes below flush.
Click for larger pic in a new window.
Oh yeah, these pics are with the Canon 20D and 24-105mm f/4 L IS lens. Settings are ISO1600, f/4, 1/8 second exposure. The red oil drum is at 97 yds, lens was at 24mm for the beamshots (or equivalent to about 29mm on a 35mm film camera or full frame sensor)
Those 10 lights use 42 batteries, so all of them are not in their optimum arrangement. lol The Meteor is, with freshly charged HE-2’s. Several of the others that should be kicking some bu… have lesser cells or rested/partially used cells.
thanks!
great pictures!
would you say the S2 1D D-D is a GO!
or why not?
Looks very nice to me and anything less is going to be all flood.
The lumens figures in those pictures was measured in the box right before taking the pics. Those are the real time numbers for the picture you see. So for a light like my Eagle Eye X6 Quad that typically makes some 4500 lumens, tonight it came straight out of my pocket, partially used cells, and was measured then shot.
I purposely did not match up any of the 10 lights, left the photo order pretty random so as not to be misleading. The Nitecore Caveman AA light just came to me today so it’s in there as a first measure and as a stock AA light. Surprisingly tight beam, old XM-L emitter even.
Hi Dale,
What do you judge the Meteor M43's tint to be like?
Thank you,
George
It’s not green, more of a yellow/orange warm at lower power that get’s whiter on the high end. Not a problem to me and definitely better than most XM-L class emitters when de-domed. The XP-G2 seems good in this respect, holding a more pleasant tint when modified.
Thanks for the beamshots Dale.
Awesome job!
Dale, having the light in hand have you changed your opinion at all about the domed vs. dedomed emitter statements you made earlier?
I like the size and flood output!
This is the XPG2 DD sample obviously? How does it handle the heat? This light lowers the output the hotter it gets right? No thermal stepdown or turbo timer right?
Thanks! I really wanted to see how the Meteor compared to a Terminator, and also wanted to see the driver.
The size and output definitely look nice, but the driver looks like it uses chips I can’t reflash. I was really hoping the MCU would be friendly to reprogramming.
Thanks DB!
There is thermal regulation which will lower the brightness based on 2 temperature thresholds, 50C and 70C (press button Turbo only) according to the manual.
LOLed
Todays digital sensors are very well capable of showing tint differences, all depends on how you set the camera up for the shot. (Maybe it’s the $8000 sensor , not sure?) And today’s monitors have also come a very long way. I will try, it’s almost dark and my sample’s cells are almost recharged.
Owning various DSLRs and lenses I can tell you that the same scene under the same light condition, preset white balance, etc, you will see for example how one lens favors certain colors more than others. I once had a major problem during a shoot of works of art ( I was using and L lens) where a certain purple color kept showing as almost cyan under natural light at shade.
Sony cameras (like prosumer A6000) even to these days have inaccurate colors that must be post processed. Inaccurate does not mean bad colors to the viewer, I am just saying inaccurate colors. Some will go be infuriate if the red they have chosen for the specific work of art is not absolutely identical to reality, then you explain to them that you TN panel is not suitable for photo viewing, does not go through to them :(
Maybe a bit too detailed, even if you struggle hard, the viewer may have a display that is either bad or either favors certain colors, certain Sony laptops had some weak blue range, and yellow was dominating, several years ago ( real issue not setting could do nothing for them, not even calibration with custom profiles), so even if the user is happy with his IPS display that still is not realistic.
Wow Dale, that’s an impressive collection to compare it to. That Shocker is serious. This will definitely be the brightest light I have when i do my beamshots.
It uses ATtiny85V. (info from Fonarevka)
Wow and ouch. That Nitecore EA8 looks like an anemic mini mag incan 2xAA :s
