Probably not, but itโll be nice know the bin values. With a dedome, tint shift is often inconsistent and the impact on lumens is unknown. This removes all of the darkness and unknowns of doing a dedome. Itโll also save the grief of ruining emitters with a failed dedome.
Is it just me or does that look like it has a โplate glass window in front of itโ maybe the โdomeโ is gone but it looks like a โlensโ is still there.
XLamp XP-L High Intensity
Industryโs First High-Intensity LED
The XLampยฎ XP-L High-Intensity LED is the first of Creeโs new class of High-Intensity LEDs optimized to deliver maximum candela through secondary optics. The XP-L High-Intensity LED is the first single-die LED to deliver over 100,000 cd in a 4-degree beam with a 50-mm diameter optic at 10 W. Built on Creeโs breakthrough SC5 Technologyโข Platform, the XP-L High-Intensity LED delivers more than double the candelas of the industryโs previous highest-performing single-die XP-L LED through the same optic. The new high-intensity LED offers a drop-in ready upgrade for XP-based luminaire designs, enabling manufacturers to achieve higher luminous intensity with minimal redesign to accelerate time to market.
SpecificationsVariationsDocumentation Data Sheet (pdf)
Size 3.45 x 3.45 mm
Maximum Drive Current 3 A
Maximum Power 10 W
Light Output up to 1095 lm at 10 W
Typical Forward Voltage 2.95 V at 1.05 A
Viewing Angle 115 ยฐ
Binning 85ยฐC
ANSI
Thermal Resistance 2.5 ยฐC/W
It looks like there is a just a thin layer of silicone, likely to protect the phosphor and bond wires. This might mean surface brightness will be some percentage lower than a typical dedome, but reliability and tint should be better.
