That would be a good question to pose to RMM as I’ve read where he mentions using LED seal when he dedomes leds. RMM, can you tell a difference in the tint of leds that you dedome after using led seal?
Read the references — there are observations of tint change due to volatile chemicals that can get into phosphors — but the devil is in the details:
how much time does it take (and is that operating time while heated, or exposure time after some amount of heating starts something gassing out? which chemical, and which phosphor (many emitters use more than one phosphor). Oh, and what solder was used? what flux? what else is inside the container (flashlight head, for us)?
You are right about max flux bin V2, i messed up when i checked the pdf before, i saw a CW V5 high density and thought i was looking at the High Intensity ones.
But isn’t it strange that the High Density ones according to cree only goes to V5? Is the High Density ones different than the old XP-L, I though High Density meant with the dome like the old ones :~
I hope not the XB-H looks at least according to Cree’s data cheats to have lower output than the XP-G2, and that is not even counting the newly released S4 flux bin.
Any chance of the meteor to be sold with the new XP-L? Or Is it possible to order it with a blank, separated mcp? This is shocking news and I will have to re-mod at least 15 lights including A couple XP-L triples with modified carclos…
I wonder how many flashlight modding projects were suddenly paused and postponed with this announcement? 3 for myself…
XP-L V6 @ 50Celsius, @ 2A does 874lm (CREE PTC used for values), now cut 11% loses in the new XP-L HI = 777lm
777*12LEDs = 9324lm, now losses in optics and glass -12% = 8205lm.
Losses in optics and glass can be higher of course, I chose 10% for Carclo 10507 and 2% for the glass.
What we don't think about it is that if the Vf is higher than results can't be better at minutes later, a very important aspect totally ignored, when it is proved that it is not higher well then it can be ignored, we know that what CREE specifies for the Vf is often not what is found in reality.
There is no gains over dedomed regular XP-L (either lumens or candela) , just makes the tint good.
That is if it fits under the Carclo optics.
