New XP-L High Intensity Emitter
Double Handful x (+1000) = 10 x 1000 = 10 000!! I’ll take 20 reels then!! Yikes, I’m clearly having a hard time with Lumen-Sickness :slight_smile:
If these can go under unmodified triple optics, and if they come in a 3D tint, I’ll be wanting a bunch of them. :slight_smile:
Sort of like SBT-70 with lots of bond wires, something tells me that such emitter would be more expensive due to being able to take more current.
@Djozz:
Yes, but maybe this flat dome XPL is a good choice for a Uniquefire shorty Aespheric? :bigsmile: :wink:
Cheers
Nico
yep, that is one them :-)
It will be the XB-H High Intensity. Forget the old generation. http://www.cree.com/led-components-and-modules/products/xlamp/discrete-directional/xlamp-xbh
This is great news. Such a good time saver and don’t need to be soo concerned about damaging a bond wire anymore.
I am with ToyKeeper. This in a 3D tint will be awesome.
You are right about max flux bin V2, i messed up when i checked the pdf before, i saw a CW V5 high density and thought i was looking at the High Intensity ones.
But isn’t it strange that the High Density ones according to cree only goes to V5? Is the High Density ones different than the old XP-L, I though High Density meant with the dome like the old ones :~
I hope not the XB-H looks at least according to Cree’s data cheats to have lower output than the XP-G2, and that is not even counting the newly released S4 flux bin.
XB-H
XP-G2
Any chance of the meteor to be sold with the new XP-L? Or Is it possible to order it with a blank, separated mcp? This is shocking news and I will have to re-mod at least 15 lights including A couple XP-L triples with modified carclos…
I wonder how many flashlight modding projects were suddenly paused and postponed with this announcement? 3 for myself…
Let's make an educated calculation.
XP-L V6 @ 50Celsius, @ 2A does 874lm (CREE PTC used for values), now cut 11% loses in the new XP-L HI = 777lm
777*12LEDs = 9324lm, now losses in optics and glass -12% = 8205lm.
Losses in optics and glass can be higher of course, I chose 10% for Carclo 10507 and 2% for the glass.
What we don't think about it is that if the Vf is higher than results can't be better at minutes later, a very important aspect totally ignored, when it is proved that it is not higher well then it can be ignored, we know that what CREE specifies for the Vf is often not what is found in reality.
There is no gains over dedomed regular XP-L (either lumens or candela) , just makes the tint good.
That is if it fits under the Carclo optics.
why you ruining our party? :party: :party: :party:
I’m joking of course. but seriously, I want to see if it fits under Carclo optics. that’s the question.
When they’ll be available? OR when ,where to get them?
I’m kind of into aesthetics, like, I LOVE the way the SBT-70 looks.
That said, I might have to put 12 of these in my new Meteor and leave the optics off. A 12 XP-L High Performance Mule! :slight_smile: Oh YEAH! Bring it! Did you say 3D tint? Do a little dance, make a little love, get down tonight! WooHoo!
Even if it doesn’t fit, perhaps we can make it fit by carving off the sides of the cover with an x-acto knife.
this changes everything
Cree reels are generally 1000.
It looks to me like the Carclo optics will fit over these, barely. Normall when de-doming there is a small gap between the die and the very bottom of the optic, this will be taken up by that .35mm difference in height
borrowing here from the pic previously posted, the height difference is going to be very close, it might be quite feasible to lightly sand the narrow end of the optic to sit at but not press into the covering over the die. Effective creating a seal? This might actually work very well, can’t wait to try it out. :slight_smile:
In the meantime, I might try slicing the dome off an XP-L like I’ve done recently with the XHP-50 and see how that looks/works/fits.
again
Could I ask this; could this XPL be in a cool white tint?
Would it be brighter than a sinner triple nichia 1000 lumen?.
Thanks.
