2 red LED’s with a 1.8-2.2 Vf, 1k limiting resistor, 560 ohm across driver, bridged diode pads on board for 3rd spot
2 LED version of the board
Your comment about voltage drop across the driver just rattled something loose in my brain. A lower value resistor on the driver will drop more voltage, which probably let’s the driver see a voltage too low to run. When the value is too high it’s sees a voltage too close to its operating voltage, so the driver memory must never set.
That is my educated guess without following Pilotdog68’s advice and re-reading the other thread yet(which I will do).
Hmm something seems off. Those red leds should be much brighter with only a 1k.
Your theory lines up with my own. I don’t think the issue is just the OTC not draining, I think it the entire driver is getting enough power to stay awake, so memory never sets in. (I’m pretty sure that’s what you said)
I don’t know all the electrical lingo and my circuit understanding is still pretty basic, so I’m just going off what I observed. The test with the blinking LED revealed a lot.
Are the LED’s in series or parallel on the dual LED board? I’ll test the current draw with my DMM, but it wasn’t even registering 1mA on my power supply.
The LED’s are parallel to each other, and in series with both D1 and R1.
I was reading through the other thread just now, and post #86 is a good one to start at. That’s what I believe is happening to you, but a lower resistor on the driver should remedy it.
Pilotdog68 = my hero
Thanks for the help, I’ll update once I get it all sorted out.
Results are in. Modes work again. Here was what I did.
1) changed current limiting resistor to 470 ohms to increase brightness as requested by slow2go
2) changed to a 330 ohm resistor on the driver, no mode memory
2) added a 1N4148 diode to the board to see if I could reduce leakage to the driver, no change
3) dropped resistor value on driver to 100 ohms, MODES WORK, draws 2.9mA
4) dropped resistor value to 220 ohms for current limiting resistor to further increase brightness, mode memory stopped working
5) changed the resistor on the driver to 51 ohms, works properly again.
Based on my findings I think the ratio will need to be about 5 to 1 for the resistors (limiting resistor on board about 5x the value of the one on the driver).
I love a good challenge.
Well I’m glad you got it working, but I’m puzzled why you need that low of values for the led’s to be bright enough. Where did you get these red led’s? It sounds like they are very inefficient. On both of the red ones I have made, I used 560ohm on the driver and 4.7k in the tail and it was bright enough to be clearly seen in a well-lit room. I had to switch to a 6.8k in the tail to make it suitable for bedside use. 3ma draw makes a lighted tailcap a lot less attractive.
I got them from lighthouse LED’s.
It's a voltage divider -
Take the battery voltage 4.2V, and subtract the LED Vf 1.8V (or even 1.6V @1mA), this leaves 2.4V across the two series resistors, the 1k and the 560 (we'll ignore the driver for now).
2.4V / (1000 + 560) = 1.54mA, this is the current though the resistors and split between the two LED's (0.77mA each). Being in series, each resistor passes the same current. So the voltage drop across the 1k is 1.54mA x 1000 = 1.54V, and the drop across the 560 is 1.54mA x 560 = 0.86V. This is very close to enough to run the ATtiny. Either the MCU is not shutting down or this voltage keeps the OTC at 0.86V, which will interfere with memory.
You can increase the 1k, this will lower brightness, or decrease the 560 this will increase brightness. Or, for red LEDs, you may try them in series and use the 1k/560, this will increase brightness but stop working at a higher voltage, about 3.2V or so.
Because there are so many variables, driver resistance, Vf, battery voltage, etc. Calculations only get you so far, then you have to roll up your sleeves....
Edit: I started composing this before you came back with your results... I agree with Pilotdog about the LEDs being inefficient. Maybe try others?
Weird, those are the exact led’s I have as well. I see you are using the Larger omten switches, so that would explain a little blocked light, but I’m still baffled as to why they seem so inefficient.
I’ve got another red one to build, so I’ll be examining everything very closely to see if there is any difference in output and if so, why. I’m also going to sand the nylon washer thinner to try to minimize it’s effects. Honestly I’m hoping I just screwed something up (although I don’t THINK I did) because it’d be nice to be brighter AND more efficient. The LED that is, although I wouldn’t mind the same thing.
Good luck on that one
So results for #2 in red are identical to #1. With a 1k limiter and running off my power supply it’s dimmer than the steroid version running a 220 ohm with another 50 in series. I expect they’d be the same with the same limiting resistors.
Well that’s less than ideal. I don’t know what’s going on.
I’m baffled, but now that I think about it the double blue tailcap is pretty dim too (although it’s running a 4.7 or 6.8k limiting resistor). I may bump that to a 220, build a single in blue and a single in red at 2.2k and compare them all.
I can’t fathom why the single might be brighter, but the single I built in green with a 2.2k is BRIGHT.
I’ll be interested to hear what you find.
So far I have done 2 red doubles, 1 red single, 1 green single, and 1 blue double all with the 0805 led’s from lighthouse. On all of them, I have had 560ohm on the driver and 2.2k-6.8k on the tail.
Not something I’d normally consider, but do they carry a low output version of this LED and I just got the wrong one shipped to me?
With the fact that I’m getting a measurement of 5.7mA it’s hard to imagine that they’re having a problem with getting enough power.
No i don’t think they do. I’m more inclined to think we have something stealing current somewhere. Where are you measuring the draw?
I’m putting my DMM in line with the negative battery terminal to brass button and a jumper between the body and tailcap ground.
