Ok, just got it today. Wow, it’s small and heavy (relatively speaking)… And by the way thanks for linking the English manual some pages back because, out of the box I wasn’t sure how it operated.
So once I read the flow chart I figured it out… but don’t expect to get it without reading it… because you won’t. I like to think of it as a short cut based UI. I don’t necessarily love it, because you need to remember what 1 press, 2 presses, 3 presses do… but it isn’t difficult. UI 3, I don’t even think I’ll bother with, and so far UI 2 seems the one that suits me the best. Personally I’d like it if it was a press on and press off… with pressing and holding from on to get to the mode you want.
Unlike Dale, I probably won’t post anything until I’m finished with the review… but I plan on getting it in the mail in less than a week and a half… and getting my review up a few days after. It’s much brighter even in the daylight than my new Imalent DDT40… but I won’t know how much until I see it in the dark. The light is extremely well built… The fit and finish is pretty flawless too.
I hurried my look at it because I have one of my own coming and there were others wanting to get their hand on it. No real reason for me to do an in-depth review with extensive pics and video on the same light several others will also be looking at.
So I’ll give a better look with my own in XP-G2 S4 2B trim. And maybe then in XP-L V6 3D. And maybe then in Nichia 219C.
My review will probably be a bit briefer than I normally do, because of this. Can’t say I’ll drop the money on this one, unless I can get it for a decent price. That said, it’s tinier than any 4x 18650 light I own, and it’s also way brighter. By the way, what version of the light is this? Anyone know? Anyone know the specific optic used in it? I want to make sure my review is accurate.
Ok, I lied. I’ll upload runtime tests as I do them, even though I’ll speed them up a bit more and integrate them into my main review. I plan on also doing a runtime test on Turbo with some Sanyo UR18650FM 2600mah batteries… just for the hell of it… The light is recommended to use the LG high drain batteries… but the Sanyos didn’t do so bad. When I get both of them rendered I can watch the videos side by side to make an accurate assesment of how the batteries perform during this test
Having just watched the two videos side by side above… it seems the winner in runtime at least is the Sanyo by about 10 minutes. Plus is seems to have a much nicer taper off in brightness. I can’t say side by side which was brighter initially though.
