I built up an Eagle Eye X6 host a week or so ago with an XM-L2 U3 1A from Richard that makes 1811 lumens in the X6. I first put a de-domed one in, saw it doing 1600+ with the dome removed and swapped in that emitter’s brother for the higher output.
When I tried XM-L2 U3 1A’s in the TK61 I just did, several fried when pushing 7A. Go figure.
Well it looks like a burn in cycle is going to get tested on my emitters to see if I can lower the Vf. It doesn’t help the death at high amps, but could be useful for single battery setups where the high Vf is the limiting factor.
Sounds kinda like what needs to be done on new plasma TV’s to get them right. Most people don’t do this, but the results are much better than those that just go straight to using it. I did a color test/burn in for 48 hours straight on my plasma before it ever had a movie/TV playing.
Is that thermal compound around the led? I think he is doing that to help transfer heat from the MPCB to the metal reflector, not a bad idea if you do not plan to open the light. By looking at the marks it looks like he pokes with a blade around 3 of the edges and then just pries it off, I don’t see anything done to the wires, does anyone have a Vinz light that can take a pic of the die?
Can the heat of the die during operation melt solder? I am thinking that there might be a way if you cut the gold wire from the base and fold it up to where the wire meets the phosphor then a small spot of solder to make a thicker wire from the die, then just solder copper strands to them
I tried to make a coupla decent pictures………one of the led / die.
Be aware that Vinz dedomes the led, gives it his “treatment” and then places a custom made small lens over it, so that all of the output is focussed on the mail aespheric lens.
I would like to upload them but appearently you need to have them stored somewhere in “the cloud” first and uyou cannot upload directly from your pc.
I don’t store ANYTHING in the cloud so, sorry….
