well put Woody!
And I thought that the V11R was expensive. Little did I knew that GearBest’s V11R takes the price to the stratosphere.
They will probably have codes for them. Prices are indeed nothing spectacular right now
Beautiful!
A discussion and interest thread about this light Javelot:
my review of sunwayman C22C!
5.8 ( May 8th)
1. Shadow JM35 Cree MT G2 LED Flashlight
Main Features:
● Unique hollow design: Looks elegant and helps to improve heat dissipation, decreasing temperature at the same time
● Stainless side switch: Anti-corrosion, prevents the JM35 from corrosion and wear
● Booster circuit: Boosts a power-supply voltage to a higher level
● Reverse polarity protection: Prevents improper battery installation
● Stainless steel bezel: Offers good protection for flashlight and may be used in an emergency situation
● Vacuum aluminum orange peel reflector: Offers smoother and floodier beam throw as well as long throw, suitable for hunting, security, outdoor, EDC use etc.
● Screw thread handle: Prevents slip and be comfortable to touch handle
● Processed by CNC machining center: Tactical handing hole can be placed upside down
● Cree MT-G2 light source: Utilize Cree MT-G2 LED and max up to 2200 Lumens
● Powered by 1 x 26650 battery
2.” Shadow JM30 1800Lm Cree MT G2 4 Modes Waterproof LED Flashlight ( 1 x 26650 Battery ) “:http://www.gearbest.com/led-flashlights/pp_183130.html
Main Features:
● Tactical switch: Allowing momentary activation as well as clicking on / off
● Reverse polarity protection: To prevent improper battery installation
● 3A drive circuit: Provides double intelligent protections for LED and battery to maximizes their lifespan and ensure safe use
● Vacuum aluminum orange peel reflector: Offers smoother and flooder throw as well as long beam, suitable for hunting, security, outdoor, EDC use etc.
● Aircraft-grade aluminum body with anti-scratch type III hard anodizing: Prevents rolling and works perfectly with the various tactical techniques
● Screw thread handle: Prevents slip and be comfortable to touch the handle
● Processed by CNC machining center Tactical handing hole can be placed upside down
● Cree MT-G2 light source: Utilize Cree MT-G2 LED and max up to 1800 Lumens
Do both the JM30 and JM35 come with extension tubes
Hi ReAvenger, thanks for your interests, I will confime it next week
Is any one interested in the Sunwayman new member?
Sunwayman G25C Cree XM L2 U2 1000Lm 4 Modes Side Switch LED Flashlight ( 18650 CR123A )
Mirage is my love.
♡♡♡G25C♡♡♡
Truth be told, I’m tired of all those XML cool leds 18650 flashlights coming out. Really wanted a 1X18650 with neutral white led. Those sunwaymans, fenixes are great but I’ve become less happy about cool white (which is what I preferred when I was new)
Order placed! :heart_eyes: K60 :heart_eyes:
Thanks for your order
new arrival
1.
Nitecore EC4 CREE XM - L2 U2 1000LM LED Flashlight 2 x 18650 / 4 x CR123A
wish you like this new lights.
2. Warsun X65 Cree XM L2/L Focus Adjustable LED Flashlight 1200Lm 3 Modes Waterproof 26650 Torch
X65 looks noce. Any coupon for that?
Summer is coming,will you like the Cool military style of GearBest SK68 ( we plan to make it with GearBest logo )
Part 1:
introducttion
GearBest SK68 CREE XPE - Q5 400LM 14500 Water-resistant Zoomable LED Flashlight - Neutral White ( Manufacture will add the GearBest logo on our selling items )
● Cree XP-E Q5 LED:
Utilizes Cree XP-E Q5 LED, max output up to 400 Lumens
● Three brightness levels:
High - low - strobe
● IPX-5 water-resistant standard:
Protects SK68 from low pressure water jets
● Focus adjustment:
Adjust focus to satisfy your needs
● Ultra mini size:
9.3 x 3 x 3 cm for easy carrying
● Attack head / digitally regulated output / hardened aluminum alloy construction / UCL lens
For max performance and long run time
five colors to choose
Part 2:
Price contest:
We will make a special price for the GearBest sk68 on Monday, the first two who guess the right price, will have a chance to choose anything under $20 as a gift.
join in the contest by posting your guessing price.
welcome to join in with your great enthusiasm
