I seriously considered the JM30 but the lack of a side switch and not being able to use one 26650 cell were the deal breakers for me. This really looks nice!
The Shadow JM35 has arrived to Banggood with MT-G2 or XHP-50 option for $49.95, although it isn’t expected to be actually in stock till 17th of May. I didn’t know it also had a tail switch as well, the Banggood page confuses me. Link here Banggood
Well, it looks like they haven taken up my idea do combine the head of the new JM35 with the batt. tube of the BTU STR1.
A normal switch for on/off and the side button for mode selection would be nice indeed.
This is great, I guess that’s what the “upgrade” is? Now it will have a lockout switch for parasitic drain.
I think I will be getting this and the JM30 Body Extension Tube. I will make up a 26650 dummy battery because I like a longer handle for home use along with the option to convert to a shorty for pocket carry. So happy I waited and didn’t get the JM30, side switch and single cell option were the only things missing.
Now we just need M4DM4X to get us a discount code!
I do think that this is a clear case of lego……don’t have the JM30 but the batt tube of the STR1 looks exactly the same.
Grtz
Nico
Bytheway: Me buying a JM35 will have to be postponed a little while because the “Wonderfull & Intelligent Financial Executive” (aka W.I.F.E.) has strongly advised me to postpone this due to the number of ongoing projects and recent purchases…… :_(
I’m in doubt of which one I should choose (the JM30 or JM35), I want to be able to use one and two batteries…
Anyone know yet if we will be able to use two 26650 batteris (with extension tube) in this one?
I am looking longingly at this Shadow JM35 (1xMTG2), or SL3 (3xXM-L2). Both available from Ric @ CNQG/EDC-Light.
Still undecided between these – any kind advice?!
I think that’s the same driver I tried out in my ZY-T08: Mod: Small Sun ZY-T08 MT-G2 (without cells in series conversion)
I didn’t like the sluggish mode selections, so I never bothered about resistor modding it. I went ahead and designed a new driver and switch plate for series conversion instead, but that’s for another thread when I get around to completing it.
You cannot choose JM30 to be able to use one cell if you want the MTG-2.
2 cells in the JM35 might not be possible. The descriptions shows Working Voltage: 6v.
Not sure if “working voltage” is the same as “Voltage Input” as shown in the specs on other lights from different sites (like DX)
I like the side switch so it will be JM35 for me. I want to run 2 cell configuration more to have a longer tube than for runtime. So my idea is to get the JM35 and the JM30 Ext. tube, then I will use a 18650 dummy battery in an 18650 to 26650 conversion sleeve for the 2nd cell.
Yeah I guess it’s not possible sadly… Would love to have the JM35 with 2 cells. I guess I could just bring with me a second cell, but the boost driver reduces the runtime quite a bit i suppose.
M4D M4X, will you be getting a MT-G2 or XHP-50 version. Would be interested in the differences and exactly how this host/reflector handles the subtleties of each LED.
i.e. Black ‘X’ in middle of four-die XHP50 vs yellow spots of MTG2 - if I’ve researched correctly!
Maybe each JM35 emitter option also has other host differences based on production age:
Pictures of the MT-G2 version on CNQG/EDC-Light have a different tail-cap (with what looks like a flat metal trigger button).
Whilst pictures of the same light on BangGood have a tail-cap that looks like the JM30 style (with rubber boot button).
Do you know which style(s) BangGood carry in stock? Is their MT-G2 version host different at all from the XHP50 host as pictured above, or would they have the same tail-cap button style?
I really want to order this light, especially with your great $39 deals. But can’t commit to either option until we know which is best and any other differences…
