Really i do not know wich companies can make that old designs, but i can recomend you companies like “muela” and “cudeman” high quality spanish companies, especially fixed knives (Aitor, exposito, nieto… other companies too).
@steve or isti:
I got my orange EL01. It has two white nylon washers - every other EL01 of mine one white nylon washer and a metal one. Which one do yours have?
My torx 7 screw doesn't fit perfect (I ruined my screwdriver a few weeks ago and need a new one, to remove the screws).
If you mean you chewed the end of the torx screwdriver, just file it back some. It might fit better after filing too because they usually get wider further back.
I tightened the pivot on my orange one and I had to press the flat side of the pivot screw against a piece of rubber to prevent it spinning freely.
This new orange version must be from a different batch because the pocket clip and the machining of the liners is also slightly different from the previous versions.
I had seen this a while ago during an EL01 image search, then I scoured the web for quite a while trying to find a vendor for it and came up with absolutely nothing, only that one photo with a dead link.
I have a RAT II, which is the RAT’s little brother, but not too little! I am very impressed. For $19, I may just buy the big RAT.
What I am really wanting is someone to come out with a clone of the Benchmade Mini Griptilian! :heart_eyes: Love the axis lock, but the framelock is my second fave.
A Hungarian Spyderco? Where would I find them? :davie:
Nice pattern, but the stated blade material is “stainless steel”. I tend to think Chinese Damascus offerings are most probably just etched standard stainless, not the real thing.
Is it me or EL-01 series have gone UP in price quite a bit?!
@doubleknife
Question is, if there is a need of registration to get all methods for payment. I don’t like ro register only to see, i can not use PayPal.
And i many shops, you even not.need.to register, cause PayPal got the adress….
I’ve been wanting an ESEE Izula for some time but can’t justify the fifty bucks for a small chunk of 1095 that doesn’t even come with scales and has a moulded plastic sheath. Besides, I already have the very similar Eskabar that handles all the same duties.
When I saw a store on Aliexpress had knock off Izulas for less than eight dollars I decided to take a chance and order one.
Overall I’m pleased with the little clone, the finish isn’t perfect but I wasn’t buying it for a show piece. It’s made from some unknown Chinese stainless so I don’t expect the best edge holding ability but so far I’ve not put it to the test.
