I’m in
Thanks!
im in
i have worked in an optical industry for a year and man these glass lenses are
hard to make. imagine polishing one of these.
I’m in!
Thanks!!!
Im in Thanks buddy!
I’m in
And to answer your request, here it is… Boom!!!
http://www.dx.com/p/99mm-replacement-glass-lens-for-flashlights-43043#.VVbiVqlIfpo
99mm x 80mm FL
$10.74 shipped
I also usually check for lenses in Anchor Optics, Melles Griot and Surplus shed
Surplus shed has a lens that is 126mm and a FL of 300mm
http://www.surplusshed.com/pages/item/pl1273.html
Anchor optics has a lens that is 100mm and a FL of 200mm
http://www.anchoroptics.com/catalog/product.cfm?id=417
This place has 75mm and 50mm FL
http://search.newport.com/i/1/nav/1/q1/Lenses/q2/Aspheric%2520Lenses/q3/Aspheric%2520Condenser%2520Lenses/q4/2.95%2520in.%2520(75.0%2520mm)/x1/section/x2/chapter/x3/family/x4/facetValue04
This place has 75mm x 60mm fl
https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=3835
This place has 80mm x 59mm fl
Saabluster used a very big glass Aspheric Lens for his very first DEFT that came from a Subaru SVX ’92 Hid Headlight lens - 79mm dia, bfl 54mm is F# 0.71
Or you can find hi quality optics in those old projection tv’s for free if you know where to look, they are also big.
HTH
AlexGT
I’m in
I’m in, thanks KKW, nice giveaway.
I’m in
Thanks for the giveaway
I’m in
I’m in
I only found really nice glass lenses for $25 each that meet and exceed the specs.
http://www.optolife.com/singlet_lens/A391.html
http://www.optolife.com/singlet_lens/A007.html
I am in
i am in ,thanks. :party:
I’m in!
I don’t know where to begin looking for your extra post items, so I’ll hope I’m lucky enough with one post in the draw.
I’m in! Great giveaway thanks!
I’m in.
I am in.
I’m in, thanks!
I’m in!
I’ve bought from this store before. They do a nice job packing.
High-power 10W-100W LED optical glass lens diameter 104 glass led lens ,LED convex lens
US $5.80 / piece
Shipping: US $7.20 to United States via ePacket
Product specifications
Outer diameter: 104mm
inner diameter: 100mm
Height: 33mm
epitaxial thickness: 3mm
optical transmittance: 99%
of the refractive index: 1.95%
focal length: 110MM (For reference only)
Beam angle: the angle can be adjusted (through the lens and adjust the distance between the LED, you can get the actual condenser angle)
Material: optical glass temperature
Optical glass lens for LED lighting, car lights, flashlights, lamp specific, use high-temperature borosilicate material, the angle can be adjusted 10-80-90 degrees, you can meet a variety of high-power LED, spot uniformity, no black hole, shadow, dark area. For 1W, 3W, 5W, 8W, 10W 15W 20W, 50W, 100W high power LED product applications.
High-power 10W-100W LED optical glass lens diameter 108mm glass led lens ,LED convex lens
US $6.30 / piece
Shipping: US $6.26 to United States via ePacket
Outer diameter: 108mm
inner diameter: 101mm
Height: 22.2mm
epitaxial thickness: 2mm
optical transmittance: 95%
of the refractive index: 1.474%
focal length: 190MM(For reference only)
Here’s a couple more
111mmX80mm Optical Glass Led Lens Lighting Angle 120X60 China Led Lens Manufacturer
US $16.00 / piece
Free Shipping to United States via China Post Registered Air Mail
SPECIFICATIONS:
Size:Diameter 111mm*H80mm
Lighting Angle:120X60
Tolerance:+/-0.2mm
Material: High Temperature Resistance Borosilicate Glass
Light transmittance:96%
Net Weight: 385g
Features: High brightness, Uniform Light, No dark shadows
Applied Arrange
Optical Glass Lens right for all kinds of lighting source, widely used in LED spot lamp, Led Bay Light, ,Factory Light, Flood light, Explosion -proof lamp, Street lamps, Car Light, Flashlight and so on.
Package inclue
1pcs 111x80mm led lens
US $18.75 / piece
1 Piece Diameter 104mm Height 33mm High power LED optical glass lens, Street lights Plano-convex optical glass lens
Specifications:
Outer diameter
104mm
Inner diameter
100mm
Height
33mm
Edge thickness
3mm
Light transmittance
97%
Optical refractive index
1.474
Focal length
110mm
Beam Angel
Adjustable Angle (by regulating the distance between the lens and the LED)
Materials
High temperature-resistant optical glass
Application
Flashlight, LED spotlight, car light etc.
Other features
Light evenly, 10-80-90 adjustable angle, apply for various high power LED.
Package includes
1 x Lens
That’s not a Solarstorm SP03 in the picture but I wouldn’t mind getting a Solarstorm SP03 if I was to win. :bigsmile:
Here’s another link. I hope it’s in your specs. I think my other post had too long of a focal lenth. This one doesn’t say focal lenth but you could always ask the seller.
1piece Dia 100mm Convex Optical Glass Lens for 20W-100W Cree Leds
US $12.83 / piece
Free Shipping to United States via ePacket
Pls note the led in the picture only for reference, package only include glass lens.
Specification:
Dia: 100mm
Apply: 20W-100W Cree Leds
Apply Area: Road Lighting, Project Lighting, DIY Aquarium Led Lamp, Plant Lamp.etc
Package Include:
1piece 100mm Optical Glass lens
