how2
(how2)
September 29, 2011, 1:05am
2
What you need to is to buy a new driver and new Led.
Also Thermal glue . You have to decide what LED you want and the suitable driver for it.
Get a soldering iron and de-solder the Led from the red and black wires. Do the same for the driver. Then measure both for the size.
08CivicSi
(08CivicSi)
September 29, 2011, 1:32am
3
how2:
Ok, desoldered the LED and the empty spot is 9/16th of an inch. The driver is 11/16th. I would like to stick with a new driver that has modes for High, Med, and Low, strobe is fine too. I use 18650 batteries in this light, but also like that it had the option to use 3AAA, so a driver that will work with that would be great. I have no idea what i'm looking for :o lol
It'd also be great if there's somewhere I can order the parts from that doesn't take a month to receive, like DX :)
how2
(how2)
September 29, 2011, 1:53am
4
Can you give it mm please
08CivicSi
(08CivicSi)
September 29, 2011, 1:57am
5
Unfortunately I have nothing to measure in MM. But according to Google:
(LED) 9/16th Inch = 14.29mm
(Driver) 11/16th Inch = 17.46mm
how2
(how2)
September 29, 2011, 2:11am
6
I you need a led which sits on a 14mm base and the driver needs to be 17mm.
What type of led do you want see this
The LED you have is a XRE this is good for throw.
XPG has more flood but can throw as well
XML Has even more flood and and throw more than XPG.
Costs for XRE is between $3 and $5, XPG $5.5 to $8, XML $8 to $12.
Choose your led and then we can choose a driver.
XRE produces 230Lumens
XPG produes 350Lumens
XML Produes 800 Lumens.
08CivicSi
(08CivicSi)
September 29, 2011, 2:10am
7
how2:
XML Has even more flood and and throw Than XPG.
I think XPG would work well for this light, around 350 lumens would be great
how2
(how2)
September 29, 2011, 2:16am
8
Are you based in the U.S?
how2
(how2)
September 29, 2011, 2:20am
9
E1320
(E1320)
September 29, 2011, 2:29am
10
08CivicSi:
Today as I was playing around with my Ultrafire U4-MCU the LED dome fell off inside of the reflector. I took the light apart and it wouldn't stick back on, so i pulled out the pill and it seperated and part of it broke. My question is what do I need to repair my light? The reflector is aluminum and has a hole that looks to be 13/16ths of an inch in diameter that the pill slides into, it has no threads. Here is a couple of pictures showing the broken piece inside the pill and the reflector. Is there any way to replace the pill? I really liked this light, would hate to have to throw it away! Thanks in advance guys.
http://i69.photobucket.com/albums/i55/icemurder/2011-09-28_20-42-43_902.jpg
http://i69.photobucket.com/albums/i55/icemurder/2011-09-28_20-48-39_923.jpg
Do it right do it once here are parts based in the US three days from order to your door.
Shiningbeam for parts decide what tint do you want go XML 2.8 amps .
XML 4B tint XML 1A tint
I would get this emitter
http://www.shiningbeam.com/servlet/the-106/**NEW**-Cree-XM-dsh-L-T5/Detail
you want this driver
http://www.shiningbeam.com/servlet/the-132/3-dsh-Mode-Regulated-Circuit-Board/Detail
if you like the tint on the right here is the link to that emmiter
http://www.shiningbeam.com/servlet/the-34/Cree-XM-dsh-L-T6-LED/Detail
You just need some adhesive and you will have 800 lumens of vanilla ice cream yummm
08CivicSi
(08CivicSi)
September 29, 2011, 2:31am
11
Yes I am in the U.S. and that driver and LED look fine :)
Will probably order them tomorrow, thank you so much!!!
08CivicSi
(08CivicSi)
September 29, 2011, 2:28am
12
Id rather get a cheaper emitter than 12$ because I have 2 of these lights, so i'll probably upgrade both of them at the same time :)
how2
(how2)
September 29, 2011, 2:30am
13
He needs a 14mm base for the LED. 16mm will be too big.
E1320
(E1320)
September 29, 2011, 2:37am
15
You can get XMLs from LCK LED for $7 bucks but you are going to wait a month for your parts to get here from China.
http://www.lck-led.com/p853/Cree-XLamp-XM-L-Cool-White-LEDs-w/16mm-Board-T6-Group,1000Lm@3A/product_info.html
You can get the drivers from KD for 4 bucks instead of 7 but again you are going t wait a month.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11088
You want it done right or you want it done right now only difference is price and patience.
E1320
(E1320)
September 29, 2011, 2:39am
16
Gonna have to go with cuttter than if he wants XMLs in 14mm
http://www.cutter.com.au/products.php?cat=Cree+XM-L
how2
(how2)
September 29, 2011, 2:43am
17
E1320
(E1320)
September 29, 2011, 2:46am
18
Those are better choices sorry
I am distracted by the Red Sox game if they don't win this game I am going to burn my damn house down.
how2
(how2)
September 29, 2011, 2:50am
19
Do you want to know where to get a cheap lighter from?
08CivicSi
(08CivicSi)
September 29, 2011, 2:52am
20
Ok, I decided to order the parts you suggested from ShiningBeam for now to fix the broken light. But i'm planning on ordering the XM-L and driver you suggested to upgrade the identical light that I have in the (hopefully) very near future :)
Thank you for the help, i really appreciate it! Can't wait to get the broken light working again!
E1320
(E1320)
September 29, 2011, 2:56am
21
08CivicSi:
You can't go wrong with Shiningbeam you will have an e-mail by noon from Bryan saying your parts already shipped and you should have them by Saturday. You pay a little more but the service is unmatched.
