That's true, perhaps its slenderness made it looked longer than it should.
How was your fit between the body and the tail? I have a notable lip on mine since the diameters aren't exactly the same.
I'm curious if it's just luck of the draw, or they're all like that.
Thanks Old. Glad it went unnoticed. I guess Ima have to order!
And devman, it does look like your tailcap is a hair wider than the body. I wouldn't mind that since I plan on inside pocket carry. It might be easier to find the clickie end from the extra width (or lip I should say) w/o having to actually look at it or feel for the clickie.
I want to know how you got yours so quickly. Where is mine?
Easy, man. When you're a real addict, you cheat.
I'm visiting my girlfriend in HK again, so it was actually shipped by a local courier instead of HK post.
Thanks for the review. Looking forward to getting a NW and CW here soon.
Great review! Quick question though, how did you get the lens retaining ring out? It looks to me as if there is nowhere to unscrew it or anything..
I need a girlfriend in HK
thanks for the review! when can we expect more detail photos (of the driver, led, o-rings?,..) and beamshots, please?
can't wait for mine :)
Raining ATM = No beams - Sorry
Lens retaining ring - grip and twist , maybe try some leather or other grip'y material
The guts , too small - looks like might be a press fit ?? truthfully , I dont want to stuff this one up ...
I will take a peak tomorrow and see if I can do it and not damage it
More pics please, if you get the time. Not of your girlfriend either, not with this crowd.
sorry, didn't mean to imply that you should gut it :)
white wall or bathroom beamshots with some other known lights would be great until it stops raining, pretty please
and are there any o rings at all? id doesn't look rainproof
Yeah no O rings , but the only way in for water would be the clicky , the rest appears to be tight tolerances ..
This is not a foul weather light , if you need to use it in the rain , protect the clicky ..
The light is small enough to fit in your hand .
White wall , yeah I can do that ...
CNQ AAA
Thanks for the beamshot... maybe a mouse-over with the Maratac on high? Do you own the DQG Tiny II (neutral) by coincidence?
Any idea where the additional power goes on NiMH compared to alkas? (heat/efficiency)
Voltage ....
Looks like the driver is working hard to maintain current to the emitter , and efficiency increases with voltage ...
1.3v x 1A = 1.3Watt
1.7v x 0.37A = 0.629W
Thanks a ton... that tint is really nice. Might have to get one... like you said... only thing missing is a pocket clip.
You collected more stuff in the yard since you took all the other photo's :D haha
Thanks for the comparison. That is a nice tint, indeed. This seems to outperform the BLF Tank and at a slightly lower price even (over all, not in lumens).
And this is a single-mode which is not customized except for the faint printing.
