Courui D01 mod - my way (picture heavy)
36 posts / 0 new
Cula
Cula's picture
After many Courui modification posts here on BLF, thought I could also give it a try. Why not, how hard can it actually be :)?
Hope You can enjoy my build as much as I did. It was a great journey and quite a challenge.
Project cost (shipping included):
1. Courui D01 (Gearbest) – $28,00
2. Omten switch (Fasttech) – $0,60
3. Fet driver 22mm (Mountain el.) – $17,00
4. XML-2 U3 1A (International outdoor store) – $5,00
5. Maxtoch PCMCB 31,5mm (Banggood) – $4,00
6. 18650 Samsung 25R (Fasttech) – $15,00
7. Copper tube 35mm (Ebay) – $7,00
8. Copper sheet 1mm (Local hardware store) – $4,00
9. Screws 2mm (Ebay) – $2,00
10. Other supplies (Local hardware store) – $5,00
So let as begin:
1. Improving a switch.
All springs removed, preparing a copper base.
2. Cut, sanded, polished and soldered.
3. Battery compartment inside look
4. Switch side parts all together
5. Springs soldered to contact plate, 18AWG wires going trough directly to the switch. Small copper plates are soldered on the top for better contact with the batteries.
6. All sanded and polished
7. Inside look
8. Three wires from springs and one more from copper plate are soldered to one side of omten switch. One continuous 18 AWG wire is soldered from switch to three body contacts.
9. Naked original driver. Preparing it for better ground contact with the body of the flashlight.
10. Drivers battery side. Making a copper circle and the ring for better ground and battery “+” contact.
11. Sanded, polished and soldered.
12. Drilled a hole. Plan is to solder drivers “+” wire directly to copper circle below.
13. Finished and in place.
14. A look inside the body.
15. Sanding threads to gain more space for the pill.
16. Three 1mm copper circles ready for soldering
17. Soldered together
18. It looks like a big heavy coin. It took 2 hours to file, sand and polish this.
19. Ready to go inside?
20. YES
21. Inside look
22. Copper cylinders, cut and trimmed to fit inside the body
23. It is a tight fit
24. Soldered together, it’s a mess!
25. One ring to rule them all :bigsmile:
26. Another angle
27. Marking “the coin” for drilling
28. Threading holes and tightening the pill to the body
29. Coin and ring are ready to be wed. There is a coil of solder wire between them ready to be melted.
30. Married!!!
31. Another mess to be cleaned
32. You have to admit that this looks very nice.
33. Other side
34. Screwed tightly to the body
35. Inside look
36. Boring part about soldering driver to contact plate and electronic switch is skipped. The pill is alive!
37. Gasoline dedome – check, thermal paste – check. Reflector is going to sit on the PCMCB.
38. Reflector is sanded to gain clearance from the wires.
39. Sanding the body of the flashlight to lower the reflector down with 400 grid paper. It should sit on the PCMCB.
40. Sanded body and a perfect tight fit.
41. Job Done!
42. Courui D01 and my beloved ZY-T08 (http://budgetlightforum.com/node/37694#node-37694) side by side.
I will try to make some beamshots later, it is daylight now in Croatia.
Current readings also later, batteries are in the charger (unfortunately I have only two Samsung 25R-s, others are in the mail).
Cheers Beer .
Edited by: Cula on 02/11/2018 - 01:50
nitro
nitro's picture
Well done looks great
ImA4Wheelr
Last seen: 1 year 1 week ago
Real first-rate work there.  Congrats on your new beautiful beast. Smile
garrybunk
garrybunk's picture
Last seen: 4 days 1 hour ago
Wow!  Gorgeous! Can't wait to see some beamshots and some current readings!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
mizjif
mizjif's picture
Last seen: 22 hours 52 min ago
WOW. Thats a lot of thought, time and hard work put in. Very impressive.
DanielM
DanielM's picture
Last seen: 1 year 6 months ago
A real artist, very well done sir you are a real craftsman.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
unknown00101
I think I've said this several times, but polished copper is just breathtakingly beautiful. Great job!
jhalb
jhalb's picture
Last seen: 5 years 5 months ago
Winner! Mod of the Century, no, Millennium!
Cool
Man! Bravo!
Let me be the first to shake your hand. Just incredible handy work there!Wink
Any interest in selling this?
M4D M4X
M4D M4X's picture
Last seen: 1 year 1 month ago
great work!
waiting for the beamshots…
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
downlinx
downlinx's picture
first, WOW Shocked
second, how much extra weight did you ad there? looks like it could be used as a blunt weapon now.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Cula
Cula's picture
Thanks guys for your comments Beer .
Did some current readings but unfortunately with only two Samsung 25R-s. So the final result should be slightly better when the third one kicks in.
Levels from 1-6:
1. 0.01 A
2. 0.07 A
3. 0.15 A
4. 0.67 A
5. 1.90 A
6. 5.01 A
I’ll upload beamshots very soon.
MRsDNF
MRsDNF's picture
Last seen: 2 months 3 days ago
Speechless. What an amazing effort. Love the end product, admire your skills and wonder about the patience.Laughing
Cula
Cula's picture
Beamshot 1 - Courui on the left at 5,01A, Small sun on the right at 4,85A. Pictures are taken with older Smartphone.
Beamshots - controle picture, distance around 400 meters.
Beamshots - On high, distance around 400 meters.
tatasal
Last seen: 3 hours 26 min ago
This great mod is now added to this thread’s consolidated mod threads at the bottom of the op: http://budgetlightforum.com/node/34384
FmC
FmC's picture
It’s great to see another person’s take on a light that you are familiar with.
A lot of work went into this one, that’s for sure!
Well done, Cula Beer Beer Beer
Tom E
Tom E's picture
Last seen: 1 month 3 days ago
Wow, just wow! Great job!! I too love the look of polished copper! Shame to hide it in the light...
jhalb
jhalb's picture
Does anyone know how well the Courui responds to a MT-G2? Primarily I am interested in maximum throw. I know that the mt-g2 is a very large led and can be difficult to get to throw well.
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 9 months ago
Everyone's already said it, but that is some great work. Lots of time, care and skill went into that one!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
BanglaBob
Fantastic work, Cula Big Smile
I am mightily impressed by your work. It’s super!
(…wish I had one, too Smile )
Lights out! That's when things get interesting...
Muto
Last seen: 1 hour 45 min ago
Artistry in Motion!
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
JohnnyMac
JohnnyMac's picture
Last seen: 4 days 11 hours ago
Found myself saying "Wow!" out loud at least 5 or 6 times as I read your post. Amazing work!!!
Cula
Cula's picture
Thank you for your offer, maybe in near future. I have to get my hands on something new to work on before selling this one.
downlinx wrote:
first, WOW Shocked second, how much extra weight did you ad there? looks like it could be used as a blunt weapon now.
I Didn't weight it before but now it is 560g without batteries. It's heavy in hand.
This really took a lot of patience to finish. Like 2 months of patience Laughing.
Yes, it's a real shame. But it is now posted here on BLF where people will appreciate this kind of work. Good comments and a killer thrower is all I need.
Thanks Old-Lumens, I learned a lot from your posts and You tube videos. You are one of the reasons that I got myself into this great hobby.
Billy X
Billy X's picture
Last seen: 7 months 2 weeks ago
It must be really satisfying when the solder traces polish out and just disappear 8)
LSX
LSX's picture
Last seen: 3 weeks 6 days ago
Wow that looks awesome! I love heaps of copper!!
First dibs if you ever sell it! haha
MRsDNF
MRsDNF's picture
Hmmm. Another one infected by OL. l guess we have something in common. Cool
ChibiM
ChibiM's picture
Last seen: 4 days 18 hours ago
I one tried to solder 3 thin round pieces of copper together, but failed miserably.
Lots of air in between and places the solder didn't flow.. also I have no real vise. Just a cheapo from eBay. (Max do a is about 4- 5cm)
Are yours totally connected with solder? And how did you do it?
jhalb
jhalb's picture
LSX wrote:
Wow that looks awesome! I love heaps of copper!! First dibs if you ever sell it! haha
NO!!! I asked him first if he was selling it!!! So I get first "dibs"!!!Tongue Out
Cula
Cula's picture
This helps a lot when you try to solder bigger pieces http://www.banggood.com/MT100-Cordless-Gas-Soldering-Iron-Gun-DIY-Weldin...
But first you have to apply solder on both sides completely covering the surfaces. When applied and cooled, use blowtorch (or a powerful soldering iron - min 60W) to melt it again and press it so that excess solder is pushed out. I prefer using small blowtorch like one I linked above because it is much easier to heat up objects. For a few dollars you get a very good tool to do this kind of work.
n10sivern
n10sivern's picture
Last seen: 2 months 2 days ago
You did an absolutely amazing job.
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 17 hours ago
First DIB’s on your next piece of artistic work! J) If you ever decide to sell it! Excellent job! Wink
KB1428 “Live Life WOT
cajampa
Last seen: 6 years 2 months ago
This is just great, i love how you took the low resistance mods to the next level here Smile
Thanks for some great ideas for future Courui D01 mods Wink
