LD-2 driver info thread:
http://budgetlightforum.com/node/39673
Price:
14.9$/piece
Note: NTC resistors (1 per driver) are included by default.
Additional DIY parts
Moonlight parts 0.25$/set (for one driver)
2xLi-ion("6V") support parts 1.0$/set (for one driver)
3xLi-ion("9V") support parts 1.0$/set (for one driver)
4xLi-ion("12V") support parts 3.5$/set (for one driver)
Resistor for 5A,7A,8A,9A,10A or 12A mod 0.1$/piece
Equation for max. current set :
Rset=900/I;
(Rset- required resistance in kOhm,I -desired current in Amperes)
30AWG 200C silicone wire 0.5$/set (25cm RED + 25cm BLACK)
Great wire for e-switch and NTC connections,super-flexible and high temp. resistant (picture with 22AWG for size comparison)
STANNOL 0.7mm HS10 solder wire 0.3$/25cm
Probably one of the best solder wires for DIY,incredible flow, mirror-like finish!
Other
Soldering moonlight and/or 6V parts fee 1.0$/driver
Changing/soldering max. current resistor fee 0.5$/driver
_______________________________________________________________________________________
LD-M2 driver info thread:
http://budgetlightforum.com/node/43510
There are two max. current versions: 6Amps - optimized for 4-12Amp range
12Amps -optimized for 12-20Amp range
Price:
19.9$/piece
Note: NTC overtemp. resistor,moonlight parts and 1S-4S multicell parts are already on board by default.
Equation for max. current set(same 0603 resistor as on LD-2) :
6Amp version: Rset=900/I;
12Amp version: Rset=450/I;
Other
Shipping: Priority airmail shipping(pretty fast): +2$
Tracking number option: +5$
Estimated shipping times:
EU 3-5 days
World 5-20 days
Paypal fees-included
Paypal: led4power@hotmail(dot)com (replace (dot) with .)
Note:for Italy only tracked shipping is available
Thanks
Maybe some of us should get together with an EU member and order that way? Which EU country has the cheapest postage, and trustworthy member?
Nice to see its finally ready.
50 pieces? :_(
PLEASE, somebody do a GB for us poor guys in the states who can’t afford to buy 50 pieces!
- The YKK Philosophy
I take 5 pcs
Thank you sir. Can I please reserve two as I am heading out the door to work. l'll PM you later today to get a cost on what I think I need. Cheers.
Fixed.
djozz quotes, "it came with chinese lettering that is chinese to me".
You’ll need to reserve 48 more.
Which gets really boring. – Tuomas Holopainen, 2015
Hi Steve, I could buy two for you and send them to AU if you're ok with that. (btw, before I'm going to be the world's postman, this is a one-time thing).
link to djozz tests
I’ll take at least 10 drivers for somebody interested in a U.S. group buy?
KB1428 “Live Life WOT”
Thanks djozz. I hate reading things twenty times and still not understanding whats said or missing the point totally. I'll get there yet, maybe. Appreciate the offer.
If I could onsell 45 of them, I would buy 50 but I just don’t see it as a viable option.
One possible solution could be if MTN or IOS could stock these, so you non-EU based guys could get some easier.
MTN has a request new products form in the OP of RMM’s sales thread, maybe those interested could put in a request
led4power, are this going to be available for now & can we/i get an heads up if you plan to take this product of the market please :),
I plan to order some but i can afford it just now unfortunately.
Sucks |(
I’m in with two. PM send.
Regards
Guys I'm really sorry about that 50pcs for rest of the world,there a few reasons for that;first I have very little free time now,and "spamming" local post office isn't my favorite free time activity;second thing if I'm sending letters outside of EU,they must be opened for inspection,that takes more time(generally PITA). I hope I'll decrease that min. quantity to 4-5pcs after some time,when things "settles" a bit.
led4power.com
I think most people, if you let them know, would be fine with posting once a week. Thats saves you trips to the PO at least.
Subscribed to this thread in the hope that the minimum order qty will come down at some point.
I am in for ten
Great Driver !
Regards Xandre
I’ll have to join the US bandwagon and take two pieces from whoever’s doing the GB. I can’t afford more
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself.
Can someone explain to me why is this driver ‘good’ and why is it so expensive? I don’t get it at all.
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECT – SCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Best way is to read the original thread, linked at the top of this thread. That thread also has links in the OP to the review threads by djozz and HKJ, as well as a link to the LD-1 thread, which this driver replaces. Once you successfully read all of those, you’ll know why this driver is so special, and worth the money.
For a quick fix, here are the stats that I find significant:
Current controlled (no PWM) This makes the lower modes more efficient. If you look at the Cree PCT, or any datasheet, you’ll find that LED emitters are more efficient at lower drive current. A driver using PWM is giving the emitter the full current rating of the driver, and just turning it on/off really fast to imitate lower current modes. The human eye is tricked by this, but the emitter is not. By truly lowering the current for the lower modes, this driver taps into the increased efficiency of the emitter.
High power capable This is desirable to just about everyone here on BLF, and should need no explanation.
Low circuit resistance This goes along with the high power capability. With lower resistance in the circuit, the LED gets more of the available power from the cell(s) so you get more light output and greater efficiency overall compared to other drivers.
Disclosure: These are my observations, based on my understanding. If I’m wrong, someone please correct me.
I’ve never done a GB before, but if nobody else steps up, I’d be willing to do one for the US. Better would be for RMM or IOS to grab some of these and resell them, as cajampa suggested. If a GB is performed, remember that total time from order to receipt will be long, because one person would have to take orders, collect funds, order the drivers, wait for led4power to ship, re-package, and re-ship them. Price would have to be a little higher as well, to cover shipping costs for the extra ship step. Would it be better to add a fixed cost increase to all the US orders, or charge actual shipping to each?
Edit: Oh yeah, the shipping will most likely be pretty cheap for anywhere in the US, and with the price breaks given by led4power for larger quantity orders, it would probably wash out at worst, or at best, still be cheaper than buying smaller quantities from him. :bigsmile:
That’s the reason for the HUGE 50 piece minimum? Wow.
I was looking forward to this release. What a disappointment.
You’d be surprised how much your free time is worth, when you start to run out of it. I understand and agree with led4power’s position. Instead of trying to shame him into reducing the MOQ, how about getting in touch with Hank at IOS, and see if he will become a reseller? By the way, 50 pcs is no where near a HUGE minimum, when you are talking about international sales.
Not shaming anyone that’s your assumption.
I understand the value of ‘free’ time and am very familiar with MOQ when quoted in an appropriate context so no need to get condescending.
I doubt he’s selling these at a loss so it’s not exactly fitting the definition of free time is it?
If he’s not interested in international sales no problem I’ll keep my money for something else.
That’s fine.
There some other aspects that I would like to point out, but aren't they actually explained by Led4Power already? Like working with old-school clickies and also with tactile switches (aka digital switches), moonlight level select, thermistor....
Also the circuit was designed and created by Led4Power.
If we in the US could put together a group buy, I will commit to at least five (maybe more if kept close to 50 pc. price) with additional shipping once in US. I’m not sure I could handle the group buy side as I don’t have experience with that sort of thing. Please let me know if there is any way of working something out with those of us in the states.
Thank you for taking a constructive approach to the MOQ issue. It looks like, with a little luck, a GB will indeed be forthcoming. If so, I too will place an order.
If someone is looking to do a US group buy I could do 2 or 3. I guess we’ll see who else speaks up.
I have yet to come across someone who sells a own design dedicated flashlight part at these low quantities who has become rich of that.
Led4power has been an active BLF-member for a few years, I think his motivation has not solely been making money. No doubt he has spend numerous hours developing and testing these drivers, and I would be a bit surprised if the total sales will result in any form of descent wages for all those hours.
link to djozz tests
Ok,I give up,min. order for non EU countries is 10pcs,best I can do currently.
led4power.com
