paypal sent
Yes,but when you solder moonlight parts,driver won't "recognize" that automatically,you must enable moonlight mode in UI.Moonlight is independent of other modes.
Thank you. So it is 3 mode, and a half press of the switch will enable moonlight, I guess.
Not half press,how to enable/disable moonlight is described in info thread(when flashlight is in low mode,wait for 120sec until very short blink appears;then if you half or full press the switch within 2seconds after that blink,you'll enable/disable moonlight).
Perfect, thank you!
I would like 2 with all the extra parts.
Ronin, if you’re asking about forward and reverse clicky’s then yes, the driver won’t know the difference as it’s simply a break in the electrical connection.
A light like the Convoy L4 has a tail clicky as well as an electronic switch. This driver will turn on/off with the clicky, like it’s a cut-out for safety, and the electronic switch will enable you to use the different UI’s that otherwise aren’t available. A Sunwayman T40Cs is another, or a Fenix TK22…but I’ll warn you that most lights equipped with both switch styles are somewhat of a pain to change the driver.
Edit: An excellent way to use this with both switches would be a light like the Courui D01 “Big Head”. Swap the driver and mount a cut off clicky in the tail cap. Then you have safety if carrying in a backpack or such and the easy use of a side e-switch.
One of the things i really like about this driver is the thermal regulation. I see that dozz tested it and it worked well, but I don’t see the external temperature thermister included as an accessory. Is this something that will be supported with this release ?
See post 78, ntc resistors are included by default
Got it, thanks. My limited electronics brain didn’t realize a NTC resistor was the same thing as a thermister
I know it seems straightforward but it would be nice to see a pic of a properly installed thermistor. I’m assuming that’s underside of pill or led shelf but my assumptions have always been my greatest enemy.
It will work with a forward switch, with the only difference that instead of a half-press to switch modes as you normally would with a reverse switch, you need to click twice to cycle off-on.
Thanks for the info!
Just curious, are there many left?
I have enough parts this time.
I still have 4 of the LD1s, why am I tempted to buy 4 LD2s?
So you can gloat when everyone else’s are gone.
The LD-2 is a nice match to the new flat-top emitters and the Reylight.
A hot flashlight. Celsius, if not sex appeal.
I should have taken a little more care to center the little button but it wanted to stick where it is……….
Thanks, led4power!
I have an application in a headlamp, I am wondering can the modes be spaced closer and not so fire breating on the high end.
I want to put a 6v MT-G2 in the spark SX5 so max brightness will not be the most important thing. (the magnetic lights did not work out so this is a fall back project).
Does the LD-1 or 2 (or other) work with electronic switches?
Also how do we get ramping put in, so we can choose how bright we want it?
and do you have Boost drivers for single cell 6V applications?
Sorry I maybe asking dumb questions.
