Sigh… I wished I never bought this light… it has hollow pill and the head is about the same size as regular SRK… same brightness with the old SRK except more floodier, the only cool thing about this is… it has lighted color on the power switch
Did you receive this light already?
Ohh - also with the new XPL lights, FT has this: https://www.fasttech.com/forums/2417900, which looks exactly like the TrustFire 12X 6 cell lights that have been around, but a lot cheaper. Hope quality is the same...
Hollow pill make sense for this cost - can't get M6 quality at these prices.
Me Likey!
I have ordered one from DX, just because I have one more item to order and I want them combined for tracking.
Update: I received the light and let's say it has opportunities. I like the looks (and the green led shining through the switch cap ) but the performance, as expected, is meh.
I threw in a mixture of high drain cells (2xCGR18650CH, 1xNCR18650PF, 1xVTC5 :bigsmile: ), and measured output: 1800lm at start-up, 1500lm after 30 seconds. That is 200lm per led . I have not measured current but that should be around 500mA per led, 6A in total. The leds are on a single ~2mm thin aluminium board clamped by the reflector, without thermal paste, against an anodised shelf inside the head. So the low current is there for a good reason, it makes the emitters survive.
So how does the light achieve that low current on four parallel high drain batteries?? First cause are the steel springs at the bottom, perhaps it uses a cheap high resistance FET, but I think what truly gets the job done are two long and tiny (24AWG?) led wires feeding all 12 emitters (they are on the right, the four wires on the left go to the e-switch and green indicator led):
With those wires you can just have zero Ohm current limiting resistors on the driver ;-)
Modding plans? I will do do this one as lazy as I can get away with:
The ledboard shelf is quite broad, that is nice: with some sanding away the anodising and adding a bit of thermal paste, the heat path will be improved a lot. With a thin copper plate under the ledboard it should be good enough. I will dedome the leds because I want a bit warmer tint. I will not be replacing the 12xXP-L ledboard because the current per led will be under 3A anyway and I don't want to do the work and spend the money for 12 copper DTP-boards. Perhaps a better FET can be used on the driver (or two in parallel?) and I will have a look at the traces on the driver board if they need reinforcing. I may go for no driver at all, just connecting the batteries to the leds, and replace the e-switch for a high current clicky. Tail springs will be bypassed. That all should get this light over 6000lumen, will it?
This mod is low on my project list, so it takes a while for a next update.
I looked at buying one of these a few times to mod, but the red-bezel kept me away.
I quite fancy the red bezel :party:
I have a 6-XM-L SRK i’m working on modding to make a 6-N219 high-CRI Flooder, but strip the driver and add in a Nanjq/Qlite with moon light. ( but i would replace the side switch with a clickie so it can turn off and no parasitic drain.
I didn't end up ordering one of these XP-L soup cans - spent too much $$$ on other projects/fiascos, like the Small Sun T43 (T08 w/e-switch) .
I didn’t end up ordering one of these XP-L soup cans - spent too much $$$ on other projects/fiascos, like the Small Sun T43 (T08 w/e-switch) .
Even if you did order one I don’t think you would get XPL LED’s in it.
Mine came today , yay new toy! , so I loaded some Panasonic 3400Mah from my SP03 and …… no light in button press button and nothing nada zip squat no bloody output at all.
LED’s had debris on them so I took front off to clear it and the MCPCB is held in with the reflectors and fresh air, no shelf under it at all.
Then I looked at the LED’s and thought they looked odd every XPL I have has “shaved” sides making it flat down the bottom of the side ( Mine are mainly on Noctigon from Intl-outdoors and they were V5’s )
These are round and I cannot see the bond wires at all
Here is a couple of piccys, anyone know what they are??
And
I added a loose XPL on top just to compare the two LED’s in case anyone is wondering about the 10th one.
I bought mine from DX.com is it worth going back to them or just starting a Paypal dispute?
hmm not XP-L and not Cree. Looks like the same “mystery emitter” that we delt with a couple months ago hiding under a centering ring. Somebody figured out what it was, but I don’t remember anymore.
I wonder if Djozz got real XP-L’s or maybe just didn’t inspect the emitters?
I identified the LEDs as being PK2E in the centering ring case, but these in the photos are not PK2E.
Hhmm. I just got a cheap, crap triple XM-L2 dive light in from TMART - same looking LED's, footprint of an XP, not XM, and same look as those with the white base.
This one: tmart.com/LT-CREE-XM-L2-5000LM-dive for you sucka
the "dive for you sucka" is my own creation . Things are goin from bad to worse out there. The 5000 lumens I can live with, but the bait 'n switch of pictures and parts specs is ridiculous. Of course the stores we buy the stuff from never see the product they sell, so they are getting baited same as we are.
The light I got had a 1.3A at the tail on 2S cells, so maybe ~2.3A to the LED's I'm thinking, and got about 500 lumens measured out. The dive light though has a very thick lens, so extra loss's there.
Now it makes a whole lot more sense. No way can they sell those lights at those prices without bait 'n switching us on the LED's.
Hhmm. I just got a cheap, crap triple XM-L2 dive light in from TMART - same looking LED’s, footprint of an XP, not XM, and same look as those.
the “dive for you sucka” is my own creation . Things are goin from bad to worse out there. The 5000 lumens I can live with, but the bait ’n switch of pictures and parts specs is ridiculous. Of course the stores we buy the stuff from never see the product they sell, so they are getting baited same as we are.
I got a dive light just like the one pictured there. I can’t remember which store I bought it from, perhaps Tmart. But it did have XM-L emitters. Too bad the driver quit working after less than a month. |( I still have the light, but I’m unsure what to do with it, since it uses a hall effect sensor for switching on/off the driver.
I bought the dive light at like $18.nn, on special deal. Was talk'n this morn bout building my own hall effect driver, but with multi-modes based on a port that would give me a signal level on the magnet strength. Might be a different part, but they do make them.
I bought the dive light at like $18.nn, on special deal. Was talk’n this morn bout building my own hall effect driver, but with multi-modes based on a port that would give me a signal level on the magnet strength. Might be a different part, but they do make them.
YESSS!!! I want one, when you get it done. :heart_eyes: Also, are you interested in doing those MTN-MAX drivers for me? :bigsmile:
Well, then the 7*XP-L and 9*XP-L I bought from FT will be fakes too…
https://www.fasttech.com/products/2418100
https://www.fasttech.com/products/2418000
Smells like a refund…
Djozz - do you have original XP-Ls?
I think so. Even in FT’s pictures it has the fake emitters.
I got a couple of those dive lights from a Light In The Box pricing mix up a few weeks back:
https://budgetlightforum.com/t/-/32869
It had XM-L emitters, but was generally unimpressive.
I had two of these; I took the first into a swimming pool (above ground, only about 40" deep) and just let it sit on the bottom for a while. Took it out and it was full of water, in the head, reflector, battery tube all. Now corrosion on the driver, and messed up reflective coating on the reflector.
I think I'll keep the second as a "Water Resistant" option, but it's not great for that due to the low drive current, poor heatsinking, and funky operation of the hall effect switch.
Thread derail complete!
