new edc triple xhp70 not firing up
47 posts / 0 new
light junkie
light junkie's picture
Hi all my friend and I bought this livht from Ric of edc and cnq qaulity goods http://www.edc-light.com/edc-light-triple-cree-xhp70-xhp-50-12000-lumen-... are the specs http://m.banggood.com/12000LM-Customized-Version-3XHP50XHP70-Super-Bright-LED-Flashlight-p-970456.html.I took the specs from banggood because they show better pictures and specs and how ric assured us he tested the lights before shipping them amd said they worked and when we got them I checked tail cap and drivwr with digital multimeter on diode test and it was good so when I installed the AWT 75 A 26650 nothing turned on ,I know the driver is a regulated and protected driver could to much amperage Set the protection on?I am bemmed we were both looking forward to our new mega torches any how here are the batteries I tried to use : content://com.sec.android.app.sbrowser/readinglist/0505201921.mhtml please any I dead would be GREATLY APPRECIATED!
Lj
Edited by: light junkie on 06/12/2015 - 02:10
pilotdog68
pilotdog68's picture
Last seen: 1 month 1 week ago
Try completing the circuit at the tail with a DMM instead of the tailcap and see what that does. Are you using button-top batteries?
light junkie
A jumper at tail cap and nothing my friend and I got the xhp70 and just a we bit upset it would have been my first thrower all I have are either c8s solarforce p60 one shadow darth and a small sun with mtg2 I fried I was really hoping to have a really high output light.
Lj
will34
will34's picture
Last seen: 6 hours 32 min ago
Does the light have a spring on the positive side?
pilotdog68
What light is it? The links in the OP are not working for me.
telephoneman
Last seen: 1 day 2 hours ago
Firelight2
Firelight2's picture
Last seen: 3 hours 53 min ago
Yikes! Quite a lot of money to pay for a light to not have it work out of the door. Sad
saypat
saypat's picture
Last seen: 1 day 15 hours ago
Vnre wrote:
Got it for much less here: www.edc-light.com/edc-light-triple-cree-xhp70-xhp-50-12000-lumen-3×2665... if only it worked…maybe you have to pay extra for that
this is a very funny comment! You should be a comedian!
light junkie
My friend and I are not happy that makes 3 xhp 70 that were DOA out of the box ,I thought Ric sold good products from CNG , wow this really sucks
Lj
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 1 month ago
Ric does sell good products and has for a long time. Here's what I would do. I would take the body tube off the light and stand the head with the driver up, so I can get to it. I would take my cells and use magnets in between them and set them together, on a bench. Than I would use magnets on each end and take two test leads, with alligator clips on them and put the clips on the magnets, so you can use the other ends to clip against the positive and negative right there on the head. You can meter the leads that way, before testing and make sure you have voltage. If you do, then use them to test the light. If it does not turn on then, it's bad. If it does, then there's an issue with your cells when they are in the body, or an issue with the tail cap switch. You can meter the switch to see if it is bad or good.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Mr. Nobody
Mr. Nobody's picture
Last seen: 11 months 3 weeks ago
Just so you are aware some batteries will not light up an LED or even a ICAN bulb.
I have a ROP Hi bulb That unless you use good quility cells it will not light up AT ALL.
I have 2× 26650s from radio shack that are not IMR cells therefor will not light the bulb. Same goes for a XHP70 build i HAD ended up making spacers to use 18650 IMRs which i have a lot of.
So before you jump to conclusions please try some high power batteries, I bet that’s your issue…
BTW thats a hefty price for a big @$$ 3x XHP70 light. i LOLd at the name EDC I pictured a smaller light for edc that had three XHP triple in it!
chops728
Last seen: 17 hours 57 min ago
I agree with Old Lumens —looks like that light might take button top batteries—if you are using king kong 26650 the + is slightly recessed —I’ve had trouble with those in series—-
jhalb
jhalb's picture
Last seen: 3 years 9 months ago
I just looked at the driver their putting in that thing.........lol
No wonder it won't light up.
light junkie
OLD LUMENS, ,,My buddy and I ran the AWT 75 Amp batteries in series on the table and got ove 12 volts very time and they are brand new batteries I bought just for this light using rare earth magnets on ground side and still nothing
Lj
light junkie
Please see op I have attached with pictures
Lj
light junkie
And have either good or bad luck?
Lj
light junkie
My buddy came and picked up the light and is returning both of them and is going to see about getting a refund he doesn’t want to deal with them if they are already causing problems ,so does anybody want to buy never cycled AWT 26650 75 amp high drain batteries cheap or trade for thrower?
Lj
light junkie
Well friend payed for both so he picked them up and is asking for Ric to refund him at last word
Lj
Jubeldum
Jubeldum's picture
Last seen: 4 years 10 months ago
If jumping from the negative terminal of the battery to battery tube with a small screwdriver doesn’t do anything to rule out trouble with tail cap, maybe a wire came loose during shipping due to a bad solder joint? I’d check to make sure driver ring was tight and grounding the driver properly first and then tear it down and check every solder joint for the wires coming from driver to MCPCBs. If I’m correct, the driver is a 18 volt buck/boost with the LEDs wired in series.
If the soldering job wasn’t up to snuff, all the banging the light received during shipping knocked something loose or it’s just a cold solder joint. It has to be something real stupid. I wouldn’t ship it back just yet. Try trouble shooting it first.
Try putting magnets between the batteries in case buttons aren’t protruding enough. Trying different batteries wouldn’t hurt either. Shove 3 of those plastic 18650 to 26650 tubes in there and drop some 18650’s in there for giggles.
DB Custom
DB Custom's picture
Last seen: 2 weeks 2 days ago
A few things. First, this light is not and will never be a thrower.
I bought the ShengJie with XM-L2 emitters and converted it to triple XHP-70 before Ric got these done. Mine does over 11000 out the front lumens. ( actually am doing this for a friend, so it’s not mine )
Second, those cells wont’ run it. Try Efest Purples or King Kongs. Even good 18650’s like the Efest 35A, LG HE 2 or HE 4, Sam 25R, any of those will do it.
When it come’s to cells, cheaping out is likely to get you no result at best, and a very dangerous result at worst.
FWIW, I paid $75 for the light originally, am selling it to my buddy for $120 making 11,000 lumens. This is measured lumens, not Chinese.
DB Custom
DB Custom's picture
That link to EDC is a great price! That’s almost cost, certainly for us it’s cost, I mean, I bought the light for $75 and then emitters for $18 ea. and built the driver and it’s $120 cost for me to build one like this. They even have a reasonable lumens quoted! Pretty accurate, surprising!
I have to agree with what’s been said, something must have come loose in shipping. There’s going to be a simple explanation that those 2 lights don’t work, seriously. I’d start with checking a better set of cells, or maybe a power supply. Then I’d go ahead and open it up and check connections.
The light is well made, once I had it in hand I didn’t want to sell it to my friend. Even the stock XM-L2 light is nice, with a suprisingly tight hot spot. Really, I wanted to keep this one and will probably buy another to keep as a long life emergency flashlight.
Jubeldum
Jubeldum's picture
What driver did you use Dale?
DB Custom
DB Custom's picture
LOL, I used a 17mm FET driver with a Zener mod, and made a dummy cell to fill in the 3rd placement, closest to the tail cap. The light works with 3 cells, but I believe it’s stressing the emitters and won’t do it myself. (My BTU Shocker did a little over 20,000 lumens with all 3 cells in series, but vaporized the copper traces almost to the point of annihilation and I had to rebuilt the carrier because of this) I don’t recommend running one this hard. Somethings going to give and monies will be wasted.
light junkie
Between my friend and I that’s 2 and then Vnre and I used. Multimeter.on diode mode and all was good from tail switch to emitter I tried Samsung 25rs with a homemade sleeve ,and you can’t get to the emitters without damaging something. So that is why my friend who bought them is returning for money and my responsibility was to buy the batteries which h were the AWT 75 A s brand new 6 each
Lj
DB Custom
DB Custom's picture
Did you look up the review from HKJ on those cells? They’re most likely your problem…
http://lygte-info.dk/pic/Batteries2012/compare26650/AWT%20IMR26650%20380...(Yellow)-Capacity-20.0R.png
Or HERE
A screenshot from HKJ’s site…
This is AWT’s 3800mA 26650, not the 4500 like you used. Everywhere I saw yours was showing $10 ea or higher. Maybe you got scammed? At any rate, this lower capacity cell shown in the test sucks at higher amperage and the lights creds show 3*6A, that’s 18A in my book.
light junkie
These aren’t efest they are the AWT s and he did a test on the AWT 18650 high drains over 35 Amps I wish I could find it but I can’t any how the lights are GONE my friend is returning
Lj
DB Custom
DB Custom's picture
Dude, the red lines are Efest Purple 3500mAh cells, the blue lines down at the bottom are AWT 3800mAh cells. Essentially, the blue lines show the cells dropping below the emitters Vf requirement almost immediately. Won’t run the XHP-70. I have no idea what the driver is doing in that light, if it’d help a lesser cell work or if it’d shut down due to “low voltage protection” under load.
Also, the cells you listed are not 18650’s. They would have much different behavior patterns, as all brands show with different cell sizes.
light junkie
Tell where this going to turn into an argument anyhow I tried 3 Samsung 25 rs in series with a pvc sleeve nothing and then I. Checked 3 AWT 266t0 in series 12.67-12.7 volts and what I was trying to sy HKJ did a test on 186t0 high drains and it tested well so WY wouldn’t the 266t0s if can send HKJ a battery let hkj Test it if he wants I will because Iam curious to see how they do and the bottom lin e the lights are gone I don’t have them my friend took them back and returning them and also Vnre s light didn’t work either so all 3 lights failed?
Lj
southland
southland's picture
Last seen: 1 month 12 hours ago
Didn’t read the whole thread but I have one of these except with XM-L2. Protected batteries were too long and were shorting out on the driver. Had to use unprotected batteries and use a spacer(a few coins). Unprotected were too short without the spacer and protected were too tong.
DB Custom
DB Custom's picture
No argument, just trying to make sense of it all. I know that you can’t look at the test results from one cell and expect the same from another from that manufacturer. It might do as well, it might not. Typically the bigger cells can’t do as well in total output, although they do have more capacity. The Efest cell is the exception.
At any rate, I still agree that it was probably something relatively simple to fix the issue. Shame y’all sent em back so quick. Oh well. Happens that way sometimes.
I got started modding with an HD2010 that didn’t work out of the box. Every fix I did the dang light managed to come up with another reason to quit working! So I kept fixing and kept fixing til it was finally satisfactory. That taught me a lot, took some time but gave me confidence. Smile Then Old Lumens did the challenge and I found that one can do almost anything if willing and patient. I’m still not an electronics guru, so the drivers stump me sometimes. I just yank em and stuff an 17mm FET in and carry on. Wink (of course it’s usually not that simple, but that’s the fun, the challenge!)
light junkie
It and do what you said and try to figure it out but my buddy wanted send them back since it was in his credit card now Iam a little resentful because I bought 6 brand new batteries 26650s and nothing to use them in
Lj
