Richard
Ok, so I'm gonna go ahead and try to add my 2 cents here. I'm not really sure if this is where I should post this, but it seems appropriate since what I have is really just a spin off of the OPs board.
I asked nickelflipper to tweak the layout of this a hair for me because I needed a set of stars on the bottom to access certain functions. When doing one offs there is typically no need for this, but when you want to pre assemble large quantities of production type lights or bulbs, its really a pain to have to access the top side of the driver.
Case in point is the copper XHP-70 bulbs I make. Since the driver is crimped in I wanted to be able to assemble them and still have the option to use the "lock" function with the DrJones Guppy2drv I got from RMM.
Anyway I have tested about 12 boards so far with 3 different user interfaces, including my Sport UI, the Guppy2, and DrJones Nlite. The boards and stars seem to function perfectly using the layout and the exact BOM I will post.
Most of the samples I tested used the 2S zener mod, but a few samples were also tested with the 1S set up.
Here is a link to the board at OSHPark.
https://oshpark.com/profiles/ForgivenMatt
I would suggest using the exact parts I am posting, from this seller and the brands only because it has been proven that all components and brands though they be marked the same are NOT created equal.
I also very highly recommend ordering a stencil, even if your only going to do a few boards, because it makes them come out nearly perfect every time.
Here is the BOM from mouser
For single cell driver.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=75156464cd
For 2 cell driver
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=96d1691809
Thanks again to everyone who has contributed to this project, especially to you wight!
PS: if anyone in China is reading this please clone my board and sell them back to us fully assembled for around $2.50 each!!
+1 VOB, thanks for posting!
May I ask why you don’t have a larger via in the center to make spring bypass with wires easier?
I’ve not tried stencil’s yet as most of my driver boards are still under development and I haven’t yet settled for final versions. Do you get the stencils made from OSH Park? Or OSH Stencils?
Also, if I may ask, what do you upload as stencil mask? Looking at my solder mask layers it seems that bare copper battery contact plats, vias and ground rings are exposed. Do you need to edit them out prior to uploading the files?
Edit: Dont worry about answering the stencil question here (don’t wanna flood this thread with off topic clutter). I’ve asked in the Eagle video tutorial thread: Eagle Video Tutorials BLF Style
I’ve been asked by vestureofblood to provide the answers to these questions. So,
1) A large middle pad for wire bypass on spring is a good idea, it just wasn’t considered at the time as only a braid bypass was discussed.
2) OSH Stencil was used for the paste mask. There should be a Top Paste Mask.GTP file in vob’s zip file which in turn can be previewed in gerbv, or some other gerber viewer. Vias are covered in this design, and wouldn’t normally show up in the paste layer anyway’s? Pads in the design could show up in the paste layer but don’t, just like the vias. The B+ contact and ground rings were scratch made, so a paste layer was not automatically included, like a component part, or say a stock pad design might. If they had, then yes you could just edit them out, so they wouldn’t show up in the stencil.
Here is the OSH Stencil preview.
I think his desing is good enough, that center pad can hold 9mm spring easy
The desing offers also a larger border pad: the original one was too small and i have to always mod it in C8( for instance)
10x for the efforts about that everyone
Thanks Kent..
Is there some way I can make a shared project at OSH stencil so everyone can just click for it ( like a t OSH Park? I was able to load the file, but don't see any option to set this up.
Matt, I don’t believe that an open project setting exists in OSH Stencil, like OSH Park. So people are stuck with downloading your zip, and then transferring the paste mask file over.
Good enough :)
Can someone give me a brief of what happened in there? I never checked this thread to be honest and from the last few posts I read, I gather this project is currently ‘in waiting’? Thanks
Just discussion about the driver. People are still making improvements, but it’s ready to use.
+1. Part of the reason this driver seems like its in limbo is because the creator wight is taking a break from the hobby for a while. However there are some working versions of the driver listed, mine just above being one of them. Fully assembled drivers and parts kits can also be purchased from Mountain Electronics.
Thanks man!
I prefer the +1 7135 drivers at this point. Got pretty good, multiple versions of firmware supporting them. I like 5 modes on these, with moon and low PWM'ing off the 7135, medium is the full 7135, and hi PWM's off the FET, then turbo is full on the FET. You do get the tint shift going from med to hi, but I like having the 1st 3 modes with a nice tint and running very efficiently.
I have buyed v24 of the driver layout at Oshpark. Now its time to order the comonents. I’am very new in flashlights so I will make sure that I order the right parts.
C1 – 4.7uF [GRM21BR61E475KA12L]
R1 – 22k 0805
R2 – 4.7k 0805
D1 – SOD-323 & SOD-723, assorted
OTC – 1uf [C2012X7R1E105K125AB]
MCU – ATTINY13A-SSU
FET – PSMN3R0-30YLD
Are the size of the resistors proof? Is D1 a Schottky-Diode? I’am not sure?
Next Question: For Zener-Mod I have to place C1 at zener-spot and place the zener diode on top. Thats clear to me. But what about C1? I have to leave C1 empty? I have to change some resistors or other components for zener-mod, too?
Thank you!
Post #36 has the digikey cart list, repeated here: http://www.digikey.com/classic/Ordering/AddPart.aspx?WT.z_cid=Shared_Cart, though might be cheaper ordering the same parts on Mouser. Use these exact parts or exact equivalents, then there's no doubt.
Use the 10 uF cap, not the 4.7uF - 10 is what we all typically use, but wight said the 4.7uF worked for him.
Not sure bout the zener setup.
Post #36 has the digikey cart list, repeated here: http://www.digikey.com/classic/Ordering/AddPart.aspx?WT.z_cid=Shared_Cart, though might be cheaper ordering the same parts on Mouser. Use these exact parts or exact equivalents, then there’s no doubt.
Thanks for the cart Tom! I found the correct link in #36. I will order 10uF!
Maybe there is someone who can help with zener mod.
Next Question: For Zener-Mod I have to place C1 at zener-spot and place the zener diode on top. Thats clear to me. But what about C1? I have to leave C1 empty? I have to change some resistors or other components for zener-mod, too? Thank you!
If the version of the board you ordered is one of the early desings then yes. The old boards had a defect in the layout so in order to make them work the 10uf cap has to be placed on the zener diode pad with the zerner diode over the top. Make sure you get the diode placed on it in the correct direction. The end with the little stripe on it goes toward the inside of the board.
The other components that need to be changed for the zener mod are R1 and D1.
R1 will be replaced with a 36K ohm resistor and D1 will be replaced with a 200 ohm resistor. Notice that all resistors accept the D1 are in K ohm, and the D1 is just 200 ohm.
I hope this helps.
R1 – 22k 0805
BTW, anyone know why it uses a 22k resistor instead of the 1912 we had been using before?
I’ve tried both, and I found that 1912 makes the OTC work quite a bit better. The 22k resistor puts the useful OTC values at the far edge of the attiny’s measurement range and makes the OTC timings particularly temperature-sensitive.
wight states in the OP: "My 22k R1 replaces the 19.1k R1 due to the change in how the divider hooks up to B+. 22k is not guaranteed to be perfect, but it’s close enough for me and for now".
It was supposed to compensate for the design change in order to keep the LVP values the same (130 and 120), but I usually use lower values anyway. wight's and C_K's board all had the design change - changed from the original Nanjg, and the original BLF DD driver (https://budgetlightforum.com/t/-/27210). On the Nanjg and original BLF DD, the Batt+ came after the diode, while on the new designs, it's direct from Batt+. The diode has a voltage drop across it, so maybe the theory was it would be more reliable without the diode? This goes back a while. I thought at the time, there was a good reason for the change.
No idea it effected OTC though -- if the 19.1K is better on this exact board design for OTC, I'm thinking it can be used, just that we would have to come up with different values to use for LVP, as long as it stays in range of course.
Ahhh - wight or C_K would know this stuff cold (both MIA), RMM would also probably know. There are a few others around knowledgeable on issues like this.
The only purpose for the 4.7K and 19.1/22K resistors is LVP, so these can be changed to anything as long as LVP can be made to work.
Sorry, made lots of edits on this post...
