will the extender work with a TrustFire USA 168???
I don’t think so as the tail cap looks more like a c8 then a TR-3t6 or TR-1200 but my trustfire USA should be here with in the next week so I’ll let you know
Thanks!!!
no i tryed the extenders from my TR-1200 and TR-3T6 (same thing) and it was a no go sorry
well ive been telling people the TR-3T6 has a throw of around 150 meters as its been hard to do beam shots and test the range of the light in the forrest as the wall of light it put,s out, but last weekend when we whent camping it made me think it had more throw the i have said, so we took it over to my old man,s who lives on a cattle farm to do some measured range testing with some other lights and i was blown away.
my actual measured range test
we test my TR-3T6 3 x 18650 on two trustfire flame batteries with a caip cap current draw reading of 2.7 amp's
250 meters (273 yards or 820 feet) of good usible throw with massive spill and i mean massive spill it basicly lit up the whole feild during the test.
300 meters (328 yards or 984 feet) of throw.
i was blown away by this i has under estimated the throw of this light due to the size of the reflectors and them being xm-l,s but xm-l,s seam to throw dam well also.
250-300m of throw, although it seems to have the same reflectors. I don't think my DRY throws that far but maybe in a pitch black environment it will :)
Your DRY with the turbo mode even with neutral white emitters (-15% for T4 5A3) will definitely outthrow the the 3T6 with CW, by quite a lot.
These lights are really fun to play around with. I ended up getting one of these as a gift.
I wanted to ask: Did anyone experience some issues with the modes? After running on high for 30 seconds, the rest of the modes don't work (goes black). When switching to medium after it ran for 30 seconds, it will go black. If you leave it "on" medium it will kick back on in about 10 seconds. Cleaned and lubed it pretty good. I re-heated the solder on the outer-spring part of the module but that had no effect. No idea what the next step is.
Can anyone provide any input?
Otherwise, it's a really fun light. It feels heavier than my Sky-ray drop-in I purchased earlier. It's a tad dimmer also as others have mentioned. I'm probably happier with my SR just because it held up very well so far.
Is the UCL lens a worthwhile upgrade?
I intend on keeping this thing, its probably the plateau for performance/technology/cost for a long while. Its a long term "keeper".
No issues with mine. Where did you get yours? There appears to be some fakes on ebay
I think so it’s only a few bucks
I purchased mine from Manafont.com SKU: 8009 (the three 18650 version). Since I started reading this forum I stopped trusting other sellers. Online chat told me to E-mail them. Kind of worried about return shipping.
It's a very interesting issue. Could be as simple as a cold solder joint inside; however, it still doesn't make since why high works so solidly in that case. I'll see what Manafont says first before I go tearing into the driver. I could just order a new driver board but then I don't think it could accept 11.1 volts.
have a chat to Jim @ manafont as mine will run fine in any mode and will do 60 min runs on high and has been use for many hours now, sounds like yours might be playing up, im sure you have tryed other batteries ive had some cheapies cause me issue,s with lights cutting out before.
Is that a good way to measure? Less than 1m distance to the meter ?
I have chosen some optics from DX
SKU 13569
SKU 13618
SKU 43044
plz suggest which will be best for concentrated beam for using with TR3T6
There were some errors thatsy deleted my post instead Read the REPLY post of "Hikelite"(the grey portion) posted on Wed, 10/05/2011 - 21:39 post number #204.In conjunction also read post no #205 of mine.
Plz assist that if it is possible or not.
By reading to your reply post no #204,probably ur asking with referernce to the linked video of mine,even I don't have the clue,it was just that I found the 3T6 video on Youtube & for query pupose I posted,but I noticed some thing in the video actually the total corona section is not falling in the sensor so the actual lumen measure can get increased if "Less than 1m distance to the meter" is set.
no to mention the 3T6 light you mention is not the same light we have been talking about on here, its a drop in not the TR-3T6 screw in module to diffrent brands with two diffrent styles of drop in.
the TR-3T6 made by trustfire with the screw in module will throw 150 + meters depending of your conditions and what you call usible throw, mine to me will throw good usable light to 250 meters while lighting up the whole feild.
my opion is the 3T6 light you linked if your video will not handle long runs or transfer heat to well or as good as the TR-3T6 due to less contact erea of the drop in and not directly contacting the head.
i sugest reading the whole thread
hi ,it is really nice one ,how can i get one ?
