That sounds fantastic. That's the only reason I sold mine. Output was good, great UI, great led tint, great F&F, but the mode gap at lower voltages on 4aa/D was a huge bummer.
Maybe a 26650 sleeve included for 26650 and C Cell use? If not enough room in the box for another adapter why not have only a 26650 adapter with one of these 18650 to 26650 adapters stuck in it so it will fit in the box?
"18650 to 26650" doesn't seem to work in a 32650/D tube. Gap is still there. We provided "18650 to 32650/D" .
Most people have 18650,I think. and it's very simple to use 26650/C. The spring will "lock" the battery, no crack. For safer reason, piece of paper works great.
I know that English isn’t your first language so maybe you weren’t getting my meaning.
I was meaning opening the inside 18650 to 32650 adapter hole to 26650 size so it will take 26650 or C cell (make it a 26650 to 32650 adapter) and use that white plastic 18650 to 26650 adapter inside the 26650 to 32650 adapter when you want to use a 18650.
This way we can be able to use 26650 and C cell batteries too and have room inside the Lumintop box for the AA carrier, adapters and accessories. Putting the 18650 to 26650 adapter inside the 26650 adapter before it’s put inside the Lumintop box so it doesn’t take up as much space.
Just wanted more flexibility to be able to use 26650 and C cell since I consider the Lumintop SD10 the “End of the World/Zombie Holocaust” flashlight. You can scrounge up just about any standard alkaline battery to power it. I even got a 4 AAA carrier around here somewhere that fits inside a 26650 flashlight. Stick that inside a 26650 to 32650 adapter and you are in business.
Interested Fix the problems that the first one had. Not impressed with the HXP50 ,better
the MT-G2 or a XML the driver from the DQG tiny will run a MT-G2 Lose the BLF logo
use the REYLIGHT logo Raylight Limited edition in script superimposed over a dragon? or a
Unicorn. Think about it, its time you became a custom brand.
allthumbs
