9-9 Updated in OP. 2nd Group Buy of Lumintop SD10 (SD4A)
Maybe a XP-L V6 or XM-L2 U4 with 4D, 3D, 3A, 2D, 2A, 1D and 1A tint option even if it cost more?
2nd batch of SD10?
i want one :smiley:
Maybe a 26650 sleeve included for 26650 and C Cell use? If not enough room in the box for another adapter why not have only a 26650 adapter with one of these 18650 to 26650 adapters stuck in it so it will fit in the box?
What does SE mean? Special Edition?
First costed 39$. but this new one might costs a little more. for adding some accessories.
"18650 to 26650" doesn't seem to work in a 32650/D tube. Gap is still there. We provided "18650 to 32650/D" .
Most people have 18650,I think. and it's very simple to use 26650/C. The spring will "lock" the battery, no crack. For safer reason, piece of paper works great.
I know that English isn’t your first language so maybe you weren’t getting my meaning.
I was meaning opening the inside 18650 to 32650 adapter hole to 26650 size so it will take 26650 or C cell (make it a 26650 to 32650 adapter) and use that white plastic 18650 to 26650 adapter inside the 26650 to 32650 adapter when you want to use a 18650.
This way we can be able to use 26650 and C cell batteries too and have room inside the Lumintop box for the AA carrier, adapters and accessories. Putting the 18650 to 26650 adapter inside the 26650 adapter before it’s put inside the Lumintop box so it doesn’t take up as much space.
My “26650 to 32650 adapter” is a pair of o-rings…
But…
That’s a good idea!!!
Ah yes, got u now,sorry.
32650-26650 and 26650-18650.
Just wanted more flexibility to be able to use 26650 and C cell since I consider the Lumintop SD10 the “End of the World/Zombie Holocaust” flashlight. You can scrounge up just about any standard alkaline battery to power it. I even got a 4 AAA carrier around here somewhere that fits inside a 26650 flashlight. Stick that inside a 26650 to 32650 adapter and you are in business.
An emergency light should have protection against reversing the batteries, the others didn’t, did they?
Yes - Special Edition. :wink: I couldn’t remember if the Lumintop had that designation, but I know the EagleEye X6 did, and I like it! :bigsmile:
I’m interested in one. Thanks
Edit - XHP50 would be nice!
Missed the first round. Interested in this one.
Subscribed.
Interested Fix the problems that the first one had. Not impressed with the HXP50 ,better
the MT-G2 or a XML the driver from the DQG tiny will run a MT-G2 Lose the BLF logo
use the REYLIGHT logo Raylight Limited edition in script superimposed over a dragon? or a
Unicorn. Think about it, its time you became a custom brand.
allthumbs
Moonlight mode that lasts forever, well spaced modes, decent high output on Eneloops and lithium batteries, ability to run on D cell, decent regulation, PWM not visible, neutral tint.
Im interested in this light, just dont make it too expensive, lets keep it BLF :)!
I’d be interested as I didn’t partake in the first one. Think it needs to perform on li-ion though. Why else would you have such a huge light? And some descent tint. Truly don’t understand why ‘premium’ flashlights continue to only offer CW.
TBH I personally think a well driven XP-G2 would be nice. Make for a good pocket thrower.
I would want one. I was sad that I had to miss out on the first batch.
Wish list:
1. MT-G2 (nice Neutral White tint)
2. Well spaced modes
3. Better 4xAA battery carrier
I still think a 3D tint Lumintop SD10 would be the cat’s meow. I’m impressed with the tint of my Convoy C8 with a XP-L V6 3D. It’s just gorgeous.
Also reverse polarity protection should be a must. I’d hate for the wife to stick a battery in backwards and fry the driver.
