I did that with a 105c today. …
stripped the 8 7135 and mounted the fet (taken from a computer Mainboard )
low and high work bit mid does not…
could it be that a fet has problems with a specific pwm ratio?
amps are nearly DD
amps are nearly DD
I know not enough about FET's to know what happened to your med mode, I just know that there are several types, some work as a discrete on/off switch, others allow intermediate currents (like the FET on the LD1 and LD2).
thanks mozart. Note that in post #10 there's a link to an even cheaper ak-47 driver (set of 2 for $2.89) , from dx. Dx does not mention the type but they are genuine ak-47A drivers.
edit: dx is sold out at the moment :-(
A common issue is that output in each mode is a fixed percentage of maximum so when you up the maximum by replacing the 7135’s with an FET the middle and low modes get boosted as well so low mode might be brighter than one might wish. This is normally corrected by adjusting the firmware to lower percentages.
Another is that if the input capacitor is in the wrong place voltage spikes can cause malfunctions.
I have bypassed the springs at switch and driver. Know the xm-l get burned I think thats to much current. Is that possible? It is hard to measure without destroying another led.
LED mounted on DTP board, & attached to a light/heatsink, you should not be burning them.
djozz
Is it possible to mod a QLITE REV.A in the same way as the Ak47, i.e., taking out the 7135s and mounting the fet?
I appreciate the QLITE modes, and have 1 driver that is currently not used that could be modded.
Thanks for the help.
Mozart
^ Answer is yes. First sentence of OP has a link to where that was first done (Qlite and Nanjg have the same circuits, just higher "binned" 7135's in the Qlite).
yes indeed, hence the title of this thread referring to comfychair, this is just his mod with a smaller FET that fits easier, and cheaper driver.
Thanks for the replys.
Tried to find some one that used the QLITE in this thread but didn’t find. Excuse my noobness. Trying to learn the basics yet.
I’m in my second led flashlight mod. The first was an Convoy S2+, that was accidently dedomed when received 2 7135s to its driver. Now mounting a Uniquefire 1504 host, that will receive a dedomed XP-G2 S4 2b and a fet driver.
Cant wait the parts arrive to mount a fet hot rod thrower.
Can this driver be zener modded for 6V output?
Djozz
Could you confirm that with the qlite it is necessary to relocate the capacitor, mounting it before the diode and connecting it to gnd?
And with the Ak47, is it necessary to relocate the capacitor?
Yes, I did this for many times.
No, everything stays in place. Pull off the AMCs and add the Mosfet. That’s it…
Prisma, it isnt necessary to relocate the capacitor with the qlite and the Ak47?
For the zener mod, do everything you would do for wight's board, it is effectively the same driver. So I guees the cap should indeed be relocated, parallel to the zener diode.
This thread goes to my book :)
Does anyone else have this with this driver, which should not work different from wight's designs?:
Two cases of builds with this driver:
1) (small 16340 light with 219C) with the tail in place I get normal behaviour, the light works like a charm, but with the tail removed and while measuring current with my DMM the higher modes do not work, when tapped for the next mode it does that for a flash and then returns to lowest mode. Then I used a 0.01Ohm sense resistor for current measurement instead of the current going through the DMM and all the modes were back.
2) (Supfire F3 build with XP-E2) the stock tail worked fine (and was good enough for this 2A build btw), but when the tail was modded with a better switch and spring bypass, it would not stick in high mode. Low and medium worked but when tapped to high mode a quick flash and then return to medium.
I am not enough into electronics to understand what happens, perhaps if the minus wiring from battery to driver has too much capacity something happens??
In both cases when it doesn’t go to high, those are cases where you potentially may be drawing more current through the FET?
So maybe in those cases, because it’s drawing more current, it’s causing the voltage to sag momentarily which may be causing the mode switch?
Then, in the other cases, there’s more resistance, so less current draw, so no sag, so you can go to high mode.
A lot of maybes, but that’s a guess.
From memory some of the original HD2010's had a problem when testing not being able to measure current on some modes with the tailcap off.
I got one failure out of 10 of this driver. What could happen? I am really not sure cause it worked the night before I tested it. And next day did not. LED is OK.
Since I have nasty habit to hard solder driver to pill only way I could de solder my work is with heat gun, and of course it pops out after few minutes of heating, and so does other components on driver :)
I guess that I probably did bad wire soldering(22AWG)
I got one very important question for this driver(it is in picture):
