Trustfire Flames "3000"mAh discharge
Well if you are talking about real-world usage, the discharge plateau matters a lot more most of the time then. (yes i do charge up early as well, so the 2100/2900/3100mAh talk about NCR18650CH, NCR18650 and NCR18650A is pretty academic) Unless if you are talking about 2 x 18650 current regulated lights. The Sanyo 2600s has one of the flattest curves around for lower mid-end voltage in the curve upwards, a lot of area, sharp knee. For single 18650 lights, all of them kick out of regulation somewhat early due to insufficient juice. (even the low LED Vf of a XM-L doesn't help, think it's a combination of the cell plus driver or something).....eg my Jetbeam RRT-2 XM-L.
But you are welcomed to contribute the 3000mAh Trustfire flames. For all we know, it could be pretty good, as long as you win in the battery lottery. (we need a larger sample base).
For the 2400mAh flames, they have a slightly higher internal resistance than the others, like NCR18650/NCR18650A/Solarforce 2400/XTAR 2400. In current regulated lights, they always give you a slightly higher current reading than the others of course we try to do the same open circuit voltage for the cell. Sag is more under load. But nothing too serious of course. I consistently get 43-45 min runtime for the Trustfire Flames 2400 on a Sky Ray SR3800 which takes 2 x 18650, compared to Solarforce 2400 it is 50 mins, XTAR is 53min and Sanyo NCR18650 2900 is 60 mins. (tests actually repeated 2-3X and underwater so that the temp is constant). I get 2300mAh @ 1A discharge thereabouts (to 2.7V) for the TF Flames.
I can not show any graphs of discharge or any comparing results, I just wanted to share my result I got playing with my new charger in terms suitable to my purposes (I guess they are not that uncommon).
Discharging below 3,0V shortens the lifespan of batteries as far as I know, no matter what, in real life I will not get this far.
All I wanted to show is these batteries are not that bad.
I have some 2400 flames too, they will go thru the same test.
Sorry, just saw that the max. discharge current on my charger is 3A :-(
Emm, excuse me but what the heck is DRY. I'm familiar with all the flashlight acronyms but this DRY is still obscure to me.
It's a popular budget triple 18650, triple XM-L flashlight: -
http://www.sbflashlights.com/-Dry-3x-Cree-XML-Flashlight-2500-lumens-p133.html
It's that flashlight that is being discussed everyday here on BLF.
http://cnqualitygoods.com/goods.php?id=1177
Hi Joerch, could you please put them to a discharge test of 1A? There are a lot of tests on 1A and I think this is the best way to compare them to the others. Thanks :)
@Ventsi: test started
Cool. I just ordered a pair from Manafont based on your previously posted data. Probably close to the stated capacity under 1A, let's see.
The old Flames 2400 have 2250 mAh under 1A, according to this test: http://lygte-info.dk/info/Batteries18650-2011%20UK.html
Just finished and got 2494mAh @1A when discharging down to 3,0V, would have been more when discharging to lower voltage but I do not like that. This cell has been charged and discharged about 5 or 6 times before.
Thanks again, you should put your data on the BLF Battery Data Base thread :)
So it seems the 3000 flames have about 10-12% higher capacity than the 2400 flames, which is ok I guess.
Got today, 1 pair from Manafont.
1st: 2502mAh @1A -> 2,7V.
2nd: 2496mAh @1A -> 2,7V.
Looks promising , except for the big difference in capacity !
IMO 2%+ difference is not that bad comparing to ones I got from Dino...
They had more like 25% difference............
your figures reflect ~ 20% difference. Typo?
Oh my, not only a typo but I also misread my own typing :D
Sorry, edited now.
Less than 2% of difference...
I might add a note about the ability to put out large amounts of current.
I have one pair of supposedly Panasonic NCR18650 2900mAh, with UF-980L they give 3,86A.
These Trustfires give 4,06A.
For reference, all my previous TF 2400 "Flames", even UN-Protected ones give less with same DMM and same setup.
Up to date, NCR18650 has been my powerhouse in terms of max amps. Seems like not anymore, interesting!
Posted in the sticky on the 2400 mah TF Flames above before seeing this thread. Thanks for the tests. Seems to agree with the tests others have run on these. I don't see it as a negative that they have a higher percentage less capacity as indicated, than the "2400 mah" Flames, as long as they have a higher capacity than "2400 mah" Flames. If these results are typical, then I believe that despite their being $1/pair more they are a good buy. So far (1 week) I am happy with mine, but I have no way of testing them to see what their capacities are.
The Dino also has them for $11.99 before discount.
Using FONAREVKA, you can get 1 set for $11.27
buy 3 sets and you can use the $5 coupon (oneworldweshare) and then it comes down to $30.97 (about $10.30 a pair)
if they are really a good buy, we can ask summer to do a GB!
Second run
1st: 2597mAh
2nd: 2526mAh
