I have 12 of these in hand as of a few moments ago. Off to the stove top we go!
Not much difference in appearance between these and the ones I cut with a scalpel. I’m not real confident the outcome will be satisfactory, but I will try.
I spashed solder into my eye. But of course I didn’t stop there. I got the 12 XP-L H1 in place and it was acting odd. Holding the button down for Turbo it’d ramp up then shut off. The 35A cells are at 4.15V. I tried again. A double click for Hi and it’s really bright. From there I held the button down and it went to Turbo. Stupid bright! How about 7141 lumens on Hi, 11,902.5 on Turbo, with the cells still at 4.15V.
The M43 Meteor, at 11,900 lumens. OUCH!
High level one does 1735.5 lumens. That Turbo is ridiculous!
Edit: Start up does just over 12,000 lumens. I attempted a 30 second run and at 20 seconds it was getting really hot, making 10,381 lumens. Wow. Ok, I’m impressed!
And for the record, these flat little XP-L H1’s fit under the Carclo 10507 perfectly with this 12 emitter set-up.
Does sound high, but my meter in my light box reads a whopping 35,110! (multiplier is .345) And it lights up a 2 car garage sized playroom like freaking daylight! It’s way over 8000 lumens, trust me on that one. 12 emitters at 1000 lumens each, 3A will do that, but holy cow! 36A? Freaky! Wonder if I dare pull the negative and get an emitter amperage reading with my clamp meter… it’s supposed to be good up to 40A.
Eye hurts. I have a Dental Office shoot tomorrow, Rehearsal Dinner Friday night and a Wedding Saturday. What lovely timing! lol I finished the light before digging the little beads of solder out of my eye though, I mean, a guy just has to have priorities or what is he?
Mouser has U5 and U4 bins for the XP-L High Intensity, these are lower brightness bins according to the datasheets, there are U6, V2, V3 bins, which are higher bins.
I was having some trouble with the light dropping down from 12,000 lumens to 7900. Could not for the life of me figure out what happened.
Come to find out, one of the 2 screws holding the driver down was loose. I had taken the driver out and put new 18ga wires on it for neatness sake. Somehow I didn’t get both screws tight. Now the ground supply is good and it’s back up to mega lumens, with LG HE-4 cells freshly charged it’s making 12,523.5 lumens. Ahhhh, sweeet!
I don’t understand it, will have to get an amp measurement on the negative lead coming into the board up top.
Halo, I had put a big fat 16 ga lead wire coming from the driver and it was sinking my iron, wouldn’t let go of the mcpcb. So I had my tweezers under it, giving it a bit of a pull while heating it up and it suddenly let go and liquid solder splashed my face, got in my right eye and in my whiskers. And the phone rang, my cousin returning a call. By the time I’d talked to Michael I was chomping on the bit to get the light finished up (maybe this is how I missed that loose screw?) and so I worked on it first, then got the little solder balls out from under my lower eyelid. lol
Took a good long shower and streamed water in my eyes later, feel much better now.
I mean, it was tearing up and kinda burning but once the solder got under the lower eyelid it was bearable while I finished (as long as I didn’t blink too much.)
Dude, I know what REAL pain is, that was just a nuisance.
I just completed my first mod using the XPL high intensity emitter.
My DQG 18650 Tiny III was equipped with 3x XPG2 5A2 tint. Now it’s sporting triple XPL high-intensity. Two of them are 4000K and one is 5000K, all 70 CRI.
Driver is a 10x7135 3.8 amp Nanjg 105c with DrJones Mokkadrv.
Preliminary observations:
The Carclo 10507 Triple-TIR optic fit on top of the emitters with no problem. It might be touching the top of the lens, but if so, there isn’t much pressure at all. Seems like a great emitter for use in small triples. I need to try this in a light with a FET driver to really see what it can do.
Not sure of the output, but it’s noticeably brighter than with the XPG2. I forgot to do a lux test before doing the swap. Oops!
