Really looking forward to those beamshots. About that ND-filter, is that something you forgot recently? I guess the cam you’re using has a ND-filter built in…
I’m considering building a X6 3up XP-L HI once they become available over here. Should make a decent beam, right?
Yes, and yes. Last night I shot a sunset with the G1X and was trying some different settings for different effects. I turned on the 3 stop ND filter and forgot to turn it off. So the beam shots I took last night of the Meteor were 3 stops underexposed as compared to my usual settings…the settings were all the same, but the filter effectively put dark sunglasses over the lens.
Yes, these emitters should make a very nice X6 triple or quad. The CUTE-4 optics from Ledil, polished to a clear surface finish, should do exceptional with these in the X6.
Anybody test the throw on these yet? My D01 with a de-domed XPL V5 1A used to do 301,000cd, so I re-flowed a XPL HI 5700K on to the same star and only manage to get 279,000cd. But that’s o.k. with me, because as I tested the de-domed V5 for the last time, a piece of crap fell onto the emitter, started smoking, and scorched a nice black spot into it? Go figure? Well that will not happen with these H1’s, NOT any more!! No more chipping the phosphorus off from misplaced centering rings or reflectors that pop up and land on the emitter surface or stuff that magically appears and lands on it!!! I’ll gladly give up a bit of throw for a lot less frigging head aches and a way better tint!!! I wonder if these can take 7+ amps? 8)
Hmm so does anyone have pics of the triple XP=L HI leds mounted on a noctigon?
I figured before i go buying some new hype emitter i will see what the people with proper tools and knowledge to test it out.
WooWoo! My XP-L HI order has just shipped from Mtn. this afternoon! I'm looking forward to getting these in...
@Mr. Nobody: just buy the triple from Mtn once they are back in stock; you know you will want more than one, and that way, you get three, then you can just reflow onto whatever size PCBs you want.
I've got a couple of projects I'm working on with these; one of the triple boards is going into a DD-FET S2; I'm using the additional board to salvage emiters. One to replace the XM-L in my STL-V2 style thrower, another (hopefully) for a future UltraFire 1504 build, and the extra as a spare in case the unthinkable happens...
