New XP-L High Intensity Emitter
Wow. I didn’t know RMM had those in stock. I guess I missed the boat on XP-L HI mounted on 16mm and 20mm Noctigon. :_(
Richard still has 3 in stock
But no 16mm Noctigon to mount them on.
Er, does the tint bin work differently on these? Instead of a bin, it simply lists “5000K”.
Don’t know if this would be useful:
www.mouser.com/ds/2/90/ds%20XPL-559395.pdf
I think he got “E3”, that means it could be every 3ish tint, 3A, 3B, 3C or 3D. So 5000K desribes it pretty accurate.
Hmm so does anyone have pics of the triple XP=L HI leds mounted on a noctigon?
I figured before i go buying some new hype emitter i will see what the people with proper tools and knowledge to test it out.
http://www.kaidomain.com/Search/SearchResult.Cree%20XP-L%20HI
I wonder when these will be available on single Noctigons?
Already are at least one place: http://www.cutter.com.au/products.php?cat=Cree+XPL+HI+Intensity
nice! I’m hoping rmm start selling them here in the US because Cutter shipping is super expensive
WooWoo! My XP-L HI order has just shipped from Mtn. this afternoon! I'm looking forward to getting these in...
@Mr. Nobody: just buy the triple from Mtn once they are back in stock; you know you will want more than one, and that way, you get three, then you can just reflow onto whatever size PCBs you want.
I've got a couple of projects I'm working on with these; one of the triple boards is going into a DD-FET S2; I'm using the additional board to salvage emiters. One to replace the XM-L in my STL-V2 style thrower, another (hopefully) for a future UltraFire 1504 build, and the extra as a spare in case the unthinkable happens...
RMM will be selling them on a single Noctigon soon.
What kind of kcd will a good KD C8 do equipped with this emitter, I wonder?
100 kcd+ I'd think. 100 kcd is what I got on a dedomed XM-L2 U2 in a good C8 running bout 4A.
Stock C'8 do bout 25 kcd, good modded C8's do bout 50 kcd (domed XM-L2, 4A or so).
anyone plan on DDing this emitter? I know I am
I’ve got a batch of XPL HI V2 1A and XML2 U4 1A’s on route :slight_smile:
KD has the HI V2 0B here: http://www.kaidomain.com/product/details.S024235, but seems quite pricy at $8.59.
0B is not 6500K, it is around 8000K, give or take some looking at the XP-L datasheets (binning)
