When I press the switch to turn on my K106 the light will flicker, it does not matter what battery is in it. How do I troubleshoot this, where do I start?
Contacts, battery length, switch.
This thread may be worth a look.
I cleaned the threads on the boday and head and that is all you can get to. It does not look like the switch end on the light comes off, if it does I can not get it to move....so I can not clean the area of the switch nor tighten it if it is loose like the CPF article mentions. Hmmmm The flicker happens with a gentle press of the switch turning it on or off or changing modes....it does not affect it working.
The switch does come out - but it is a huge pain to do so. Putting it back is an even bigger pain.
With the Akoray are you trying to pull the plastic retaining ring out? You can just go to the very end of the tailcap (almost at the rubber button cover) and unscrew that. It isn't obvious but it does unscrew.
As far as getting the lowest low...if you hit the "save" button before you see the light it isn't the lowest you can get. If you wait until you see the light that's not the lowest either. You have to put it in programming mode and halfway between the very start and when you can see it...that's when you hit the "save" button.
The key however is after you've done it to use a DMM to verify the low and try again if it isn't low enough. I don't still have mine and I can't remember the lowest reading I got but it was in the .10 mA range as I recall. I read online that others were getting low figures and I didn't believe it at first based on my initial efforts but you can do it. Just use a DMM to verify otherwise you don't really know when you have it at the lowest.
On an unrelated note...Romensen always seems to make their flashlight bigger than necessary for the batttery size. That's the only reason my first Romensen was my last.
Ok, I'll bite...how did you get your hands on the R5A3? BTW, all nice lights to me. What I'd really like to know is where you got the K106? All I can find appear to be the non-programmable versions.
The K106 came from Don and the R5A3 came from E1320. Both great and helpful dudes. :) They have helped me a lot to learn and grow as many on this forum, now on to more pics. These pics were taken like this:
Romisen RCA5
Akoray K106
Ultrafire U20
Trustfire R5A3
Trustfire flame 14500 @4.09v
pics @ 50feet
The UF U20 and TF R5A3 are the clear winners here. Of those two I prefer the TF R5A3. :)
Paul
I would be real careful with the switch on the K106. I would not recommend taking it apart it a huge PIA, try spraying it full of WD40 fill it like a cup click it on and off like a madman as many times as you are patient enough to do. You want the WD to soak in then turn it upside down and let it dry outside so you don't get in trouble with the misses from the smell. In the AM wipe it all off and try again switch repair is complete move on to other causes. Good Luck E
I will go give this a shot right now and let it sit over night outside but out of the weather....it is not raining, but it is cool and damp. Thank you for the tip.
OK it is done, we will see what happens tomorrow.
That is why the only Romisen I own is the RC-C3 neutral from SB. One of my first real LEDs and still one of my favorites seriously a 5C tint is almost incandescent very nice, f you like twisties.
http://www.shiningbeam.com/servlet/the-205/Romisen-RC-dsh-C3-II-NW/Detail
PM sent
PM replied to. ;)
OK what secrets are being kept from me in MY thread? :)
No idea what you are talking about.
I must be seeing things....I mean not seeing them....DOH....my screen reading was telling me lies. Where is Deloris Umbridge when you need her?
Let's just say that Erik and Don are great guys! ;)
She is probably asleep isn't it way past her bed time.
last time (last night) while listening to my book she was still rather ticked off a Harry and Dumbledore
Like E1320, that is the light that started my addiction;-) However, I don't have the guts to change mine just yet. I like that light SO MUCH that I don't think I could bear the wait for a replacement if I screwed it up;-) Not only that, but I'm not sure if I have the version that is modable in the first place.
I live with the strobe. It is only one half click. My 18650s are 5 mode so I have strobe and SOS to get through. That drives me so nuts that the R5A3 seems I joy in comparison. Memory keeps it in mid where it is extremely useful. My hand chokes it to low.
You are a very lucky guy to have one with 3 modes, no strobe, real low. That really would make it the perfect light to me. However, it is always nice to have something to hope for;-) I think when I finally to get into modding however I will start with one of my 18650 lights!
Wade
Just order another R5A3 now, Wade. Then when it comes in you can mod it to your heart's content and still have the spare to fall back on and enjoy no matter what.
