Deal alerts for Banggood.com - BTU Shocker, SolarStorm, Olight, XinTD...
I thought there were deals here in this thread :frowning:
Yes that’s the one. It’s very big (heavy at least) and cheap but if it’s glued I might get something else instead.
Price lowered on: A multi-color copycat on Xiaomi ‘miLED’ LED USB 1.2W Light for just $0.99 / NON-REF /
Mine came from the link above. I bought three as they were very cheap. I've had a few looks at the lens to double check if it is AR and it definitely has a very slight blue reflective tinge to it.
Edit. The Banggood link. Don't you love that name.
Edit two. I've just stuck a couple of protected batteries in this light and the tailcap will not screw on fully. Even with the brass pill on the spring removed it still does not do all the way up. There is about 4mm gap before the tailcap will screw all the way on with 70mm long batteries installed. It has mode memory and the reflector has a slight haze to it. Tailcap current draw on high is around 1 amp on high, .5 amp med and .12 amp on low.
30-PCS only sale: ‘A zoomer’ CREE XPE-Q5 LED Flashlight 1xAA/14500 for $1.45 / NON-REF /
2 x NCR18650B 3400mAh Protected Rechargeable Lithium Battery / Not aff link: here US$15.95 (valid next 4 days)
If you are planning a gift for dear person that is also flashlight noob this are the best cells to give.
but have the length of 70mm in mind!
they do not fit in every light… (ask why i know)
True, and that was my first concern when I bought first NCR18650B protected cell (that was loooooong time ago), surprisingly I never had problems fitting then in any of my flashlights, they even fit my Nitecore MH20 and I was ready to bet they will not fit, good thing I don’t bet :smiley:
1W 50 lm Touch-Regulated Dimmable USB LED Light for $1.00 / NON-REF /
This is a great must-have thingie for using it as a camping light with power banks, etc. Warm and neutral white light color options are available.
Hint: 3+ pieces per $0.78 each. I also encourage you to use your accumulated BangGood points to reduce the paid amount by 15%!
just a side note, this little puppies are great but they don’t work so good with “smart” usb power banks like Xiaomi pb, actually when they are set to about 40% of intensity or below they don’t work at all. Smart power banks monitor current consumption and when this consumptions is low(er!) they presume that consumer device is fully charged and they cut off the power (shut down).
I bought Xiaomi 10400mAh power bank to use with this USB light but if I set the light to minimum intensity, which is still quite enough to light up the tent just enough but because consumption is so low that pb just shuts off and then you have to unplug and plug again USB light to get it working again and you have to crank up the output, somewhere to 50% and that is to much for my intended usage
Here is my review of Mini
I agree generally. Better to use ‘stupid’ power banks with these lights, such as this one:
You don’t need to unplug then plug again to the Xiaomi powerbank by the way—just press the Power button.
Just keeping in mind this downside of Xiaomi power banks. Because of this, some smart phones do not charge well, too: charging process shuts off after several seconds—right at the very beginning. :frowning:
any code for dqg AA/14500?
thank you
thank you.
—————- RELOCATED POST to correct forum category —————-
ACEBEAM EC32 Cree XP-L 1200LM Waterproof Mini LED Flashlight down to $40.38 after coupon “36bgc8” at Banggood.
ACEBEAM EC32 Cree XP-L 1200LM (Aff link) / Non AFF Link
Updated - New coupon added for a bigger discount. The coupon above can be used for AFF or Non AFF links as is standard with such coupons. The same coupon can be used for other clearance items.
See Holen Sie sich jetzt die besten Angebote für LED-Taschenlampe - Banggood Deutschland for torches where the coupon can be used. Be sure to select the “Clearance Box” for the items.
Strobe:1200lms 2.5hrs
Turbo:1200lms 1.2hrs
High:550lms 2.5hrs
Middle:250lms 6hrs
Low:30lms 70hrs
Firefly:0.3lms 1200hrs
since we are in the budgetlightforum i have to say again that banggood offers that light around 7 USD cheaper
please don´t ask me why, but some of the codes i get i am not allowed to publish...
but i can assure you: all of the codes i get from banggood and share with you also work without using an affiliate link!
@ rule:
Klarus RS20 ( nonaff ! )
Code: M4DRS20 price: $ 75
But that seems to be a friggin affiliate code! :stuck_out_tongue:
Sorry, but it's not. ;)
Warsun x65 zoomie for 13.99
Here is a forum discussion link for the x65
Link for the banggood warsun shows $15.99 for me, is there a trick to it?
Also says: Battery Configurations: 1 x 26650/3 x AAA battery (not included)
AAA not AA?
