This looks to be a great portable charger from Jackery.
I am curious on about the new thin XIAOMI 5000mAh powerbank
With a cell phone type cell in it.
I suspect this kind will be much more common now that ASUS, XIAOMI & OnePlus has released similar powerbanks, all based on the cell phone type thin cells instead of the usual 18650 batteries.
And +1 on the IKEA KOPPLA, that one looks interesting, especially if it would work good to charge XIAOMI powerbanks with. For now the best & fastest known charger for the XIAOMI powerbanks i know from online sources is the Samsung 2A USB charger.
These look very much like the Enerpower charger that you have reviewed previously but are much cheaper:
Flypower DC 5V 2A AC Travel Power Adapter Wall Charger For Mobile Phone Ipad Tablets Android Tablet PC MID With USB port - Black
These car jumper/sub power banks are very interesting, I think they will be really popular. Good call for review.
HKJ, will you be able to test the starting power of these?
Not yet, I am looking for a new electronic load that will be able to do at least 100A at 15 volt, but I have not found one yet. 200A would be better, but they get very large when you want 3000W capability and a 100A test is probably enough to reveal the packs that are too optimistic.
Itech (Cheap (Depends on the eye), works well and my software can handle them directly) do have some, but I cannot find any dealers (Ebay or otherwise).
Supposedly 2.1A output, but divided if both outlets used.
Great!
I do definitely not have time at the moment with 20+ usb chargers in queue.
https://www.fasttech.com/products/0/10002784/2162000-enb-4-18650-li-ion-battery-usb-emergency-charger
I purchased this power bank and am curious to how it performs, especially since the smaller ENB banks have received such good reviews. I used it on a hike of the Apalachian Trail along with my Armytek Wizard pro and my Galaxy Note 3.
An all too vague request — if there is any power supply made yet that minimizes vampire drain, I’d sure like to see such things reviewed.
Here’s the news I found a few years ago about a reference design, using a supercapacitor:
http://cache.freescale.com/files/microcontrollers/doc/ref_manual/DRM130.pdf
A second request — a little essay on when to trash/recycle a power supply.
Specifically — when a wall wart switching power supply is audible, with a buzz/rapid clicking, I’d guess that’s a capacitor breaking down and it’s becoming junk?
What other reasons are there?
(When I give up on electronics, generally I cut off the wire and plug, crack the case, landfull the plastic parts, and recycle the electronic parts.)
I do include information about that in most of my reviews. Most usb power supplies is around 0.25 watt when unloaded, but a few are better.
The noise is not directly a signal about it being old, a new one can also be audible, but the noise pattern will probably change.
The typically old age breakdown is the capacitors loosing capacity, it can be measured, but is a difficult to detect without measuring equipment. The adapter will get hotter and it will probably increase the noise in AM radios.
http://m.gearbest.com/chargers/pp_197038.html?currency=AUD&gclid=CLHLwuqIwcYCFYiVvQodjZYE5A
Might be a good one to test.
RAVPower 3200mAh Power Bank (3rd Gen) Model:RP-PB08 EAN:6950639095127 ebay.co.uk amazon.com amazon.de
Widely available, inexpensive, 1 Amp output, single brand name 18650 (LGABB41865), smart USB DCP controller (switches USB coding to match device), 100 lumen flashlight (also available in non-flashlight version).
Looks like the same internals might even be available under different names.
Anker 3200mAh Astro mini 2nd gen ,
Thanks for all your work, HKJ.
