You can do rainbow fades just by dipping it in colors in a certain order. To create flames you could then mask where you want flames, strip and dye a background color (orange in TK’s pic). Some of the thin feather lines would likely be difficult.
There are quite a few home anodizing guides around.
It’s that multi-color S2 body I was after for a GB, pre-loaded with your terrific software. I already modded several of the boring grey ones. The S2 Series is really a modders delight for the price, as you mention. And now we have the ReyLight for more modding fun………at more expense.
Received my red S2+ ordered from Gearbest for $12.99.
Sadly the quality is not on par with the other Convoy lights I own, or the nicer S2+ most people have reported:
-Received the wrong tint (ordered NW)
-Cheaply made aluminium pill and both retaining rings.
-Rusted washer used as switch retaining ring.
-Emitter is off-center, because the centering ring being used is not for this reflector.
-Only draws 2.2A, but all 8 chips are present. -Driver spring is the worst I’ve seen, looks like the spring from a pen (or worse).
Pros:
-Inexpensive!
-H.A. is well done.
-Switch is a small orange Omtem, switch assembly feels good and makes this S2+ much more usable.
It looks like GB is shipping out mixed batches of convoy S2+ with two grades of quality.
Despite all the above I think this S2+ is still a decent light for the price. For those (myself included) who mod every light they get there is no major issues, I actually prefer aluminium pill than brass. I plan to make this into a Triple nichia 219C 90+ CRI when it’s released.
But if you’re buying this flashlight to use it as-is, I think you should contact GB first to make sure you receive the better version.
Wow, never seen such a thin junk driver spring. :Sp
What is the thing that looks like a rusted washer? ….It’s a rusted washer isn’t it?
How is the the quality of the actual body seem? Reflector? Maybe they are buying convoy shells and adding all the internals. ~ edit~ 100% fake. Pics post #200
It feels good overall, a bit lighter than my old S2, H.A. is well done with no imperfections, but laser engraving is weak. Threads are smooth even without any lube. Reflector is ok but I have spare S2+ reflectors ordered directly from Simon and they have stronger OP finish, not a big deal.
I cannot describe how bad the spring is. I wonder how much did they save by producing this crap flimsy spring compared to the normal one, 0.02 RMB maybe?
Yeah that’s a rusted washer, it’s not even aluminium but a common washer that just happen to fit in there. “If it fits it works” -chinse proverb
It’s cost-saving efforts like this which motivate me to buy pretty much everything either direct from the OEM (Simon / Convoy in this case) or from RMM (who makes sure to only get the good stuff). I’d much rather pay a little extra and know I’m getting the right version of a product.
However, I do still try to keep spare parts around, like good springs, in case a stock item is sub-par or in case I break something. Like, I tried using a relatively weak driver spring on a FET triple and it melted in half, shorted, and unsoldered itself. Oops. Fortunately I got it turned off and taken apart quickly enough to avoid damaging anything except the spring. Spare parts to the rescue!
The reflector in the “good S2+” has a stronger OP finish, and comes with a GITD vs black o-ring in the cheap version.
Unless someone has one of each quality of S2+ we can’t know for sure if the light is entirely different or just the guts. There is a chance that these S2+ are not even from convoy!!
