Review request for HKJ [Chargers]
EDIT: Totally missed that HKJ had ordered one already. Sorry to bulk up the thread for nothing.
Now HKJ is going to kill me…
SkyRC MC3000
If it ever becomes available. :wink:
The NC-TGU01’s replacement is the BQ-CC25, but it does not have the same capabilities as the NC-TGU01… slower, not as fast… no “quick mode”
The current catalog is a little confusing: it doesn’t list it as a smart charger, but it does list it have charge termination controls… overall, it made me weary of getting the BQ-CC25 (relatively easy to get), so I found a NC-TGU01 (for a good price) and haven’t regretted it since
I don’t think Panasonic will bring the NC-TGU01 back, the way this charger is built appears to be a lot more expensive than what the BQ-CC25 costs… the flip up terminals like the NC-MDU01, dual color individual bank LEDs, full control logics, etc doesn’t appear to be too cheap….
The BQ-CC25 appears to just be a BQ-CC15 with updated firmware to officially support Eneloops. Both of these instead has simple spring loaded terminals (not fixed like all the Sanyo Eneloop chargers), has only 2 charging banks, making it incapable of charging more than 4 cells… the only thing that’s better about it is its official Evolta support (which can simply be done with any new Panasonic charger, because there isn’t any C and D Evolta cells, only Eneloop) and 9V charging (no charge termination controls)… the 9V battery is not an Eneloop, not Evolta, and expensive (MSRP about $20 USD)… so it’s not something to be missed
Anyhow, the NC-TGU01 can be found relatively easily used in Japan, but not so much in other countries due to far lower sales volumes…. maybe ChibiM can help you with this?
Interesting new 1*18650 charger from BG: http://www.banggood.com/5V-1A-Li-ion-Micro-USB-Charger-Mini-Battery-Charger-For-18650-p-984061.html
Gearbest has the same (I believe) and has promised to send me one.
I hope that they are as good as the Miller ones but can charge protected batteries.
Looks way nicer and is a bit cheaper. Looks like a good travel-charger to me.
Did someone claim that Litto kala is Finnish?
i don't think so.
http://liito-kala.com/About-us
http://www.liitokala.cn/offerlist.htm
+ 1
i looked it up, looks very impressive. basically it is a hobby charger from what i can tell. it is impossible to fully test/review a hobby charger because of the numerous settings ymmv
You are correct, but I can test some of the common settings and see how well the software works.
Nice catch
Possible to test the charging part of flashlights with inbuild chargers?
http://www.gearbest.com/led-flashlights/pp_33496.html
The setup is a bit tricky to do that and I believe that the audience is rather small for that type of reviews.
Around here I bet it is.
In my surrounding however I can’t count the times people wanted a bright flashlight but once they found out it required a specialized charger and the added cost of quality items decided their 2€ flashlight was bright enough for their needs.
I got a couple of these and according to a couple of simples tests I could perform it’s safe but was wondering how the guru would classify it.
But I can see it’s not worth your time for the audience that comes here, I assume most of us have decent chargers to work with, so no problem.
This is outside your specified range of chargers for now, but noting it in case it’s of interest later:
— might be interesting because of the claims and it’s cheap:
— $22.50, free shipping (at least in us, dunno otherwise)
— Claims to charge Li-ion as well as NiCd/NiMH — “triple” charger
— definitely interesting to any ham radio owners, who end up looking for replacement battery packs (e.g. 7.2v NiMH)
http://www.newegg.com/Product/Product.aspx?Item=9SIA1HS2F47298&cm_re=vertex_vx-150-*~~9SIA1HS2F47298~~*-Product
I will pass on that type of charger.
Keeppower L1
I have seen it, but was wondering where to get it. It is ordered now.
It is a pretty new model if I am not wrong. I found it while searching for keeppower battery at China sites. It is kind of low profile charger... Any way, I am looking forward for your Pro review!
did they send you one?
if not pm me your address and i dropship it to you…
