New XP-L High Intensity Emitter
What kind of kcd will a good KD C8 do equipped with this emitter, I wonder?
100 kcd+ I'd think. 100 kcd is what I got on a dedomed XM-L2 U2 in a good C8 running bout 4A.
Stock C'8 do bout 25 kcd, good modded C8's do bout 50 kcd (domed XM-L2, 4A or so).
anyone plan on DDing this emitter? I know I am
I’ve got a batch of XPL HI V2 1A and XML2 U4 1A’s on route :slight_smile:
KD has the HI V2 0B here: http://www.kaidomain.com/product/details.S024235, but seems quite pricy at $8.59.
0B is not 6500K, it is around 8000K, give or take some looking at the XP-L datasheets (binning)
Do you mean XP-L HI datasheets, not XP-L? Looks like bin and temp ratings drop with the factory de-doming.
Binning and labeling for XP LEDs datasheet. 0B is a bin, so all LEDs that fit those X and Y coordinates for what is called 0B are label as such.
:Sp
That was then, this is now. The new XP-L HI changed the datasheets game.
With the loss of the dome at the factory, the output binning is not the same as a standard XP-L, hence, new datasheets for the HI.
Loss? It was never there.
Ahhh - I'm thinking KD has the interpreting the CREE label incorrectly - probably tint is 1C, and 1C is in the 6500K range. Look carefully at the CREE label in their picture:
XPLAWT-H-1C0-V20-0B-0001
Kind of, sort of match's up to CREE's listing on page 59 here: cree.com/~/media/Files/Cree/LED%20Components%20and%20Modules/XLamp/Data%20and%20Binning/XLampXPBL.pdf for the E1 kit, V2 code. In other CREE labels, the tint is in the 3rd grouping (here: http://intl-outdoor.com/cree-xml2-u3-1a-bare-led-p-823.html), so should be 1C.
Not sure how you figure that, is the chip made differently? Different bond wires? If they’d chosen to pop a standard dome on these, would they not then be normal XP-L’s as far as the binning sheets go?
I remember when it was all the rage to put dual exhaust on a car for the gain in horsepower and mileage. No alteration to the engine, but a better exhaust route that allowed it to breathe. Similar in some small way to changing the dome on an emitter, output is altered. Altered output would change the sheets, wouldn’t it?
Edit: The highest color temperature on the Cree charts for the XP-L High Intensity is 6500K. There is no 0B.
Edit II: Tom, you got the jump on me… I was referring to what EF said. And yes, Cree lists the HI separately on page 59 of the tint and binning sheet.
No prob - makes a whole lot more sense now. Glad we all questioned this.
I think you are correct.
Im referring to the use of the word loss, or lost, or factory dedomed as others have called them. It never had a dome to lose or remove, precisely the point of them. They are domeless, not dome lost or loss or dedomed etc.
So as said, its seems accurate these would not fit the normal chart, that chart taking into account a dome.
Interesting, that label doesn’t conform to Cree’s own information pertaining to order codes. The groups of numbers are broken up wrong according to every Cree publication from MT-G2 to XP-E2, they all have certain groups of numbers that mean certain things and the output bin/tint bin are always the last 5 numbers (V20E1 would be the hightest output and coolest tint).
V2 400 XPLAWT-H0-0000-0000V20E1 XPLAWT-H0-0000-000BV20E1
U6 380 XPLAWT-H0-0000-0000U60E1 XPLAWT-H0-0000-000BU60E1
U5 360 XPLAWT-H0-0000-0000U50E1 XPLAWT-H0-0000-000BU50E1
The above is copied straight from the tint and binning datasheet for the XP-L HI. And yes, at 1050mA there is only a 40 lumen difference between top and bottom output binning for the 6500K tint. But at 3000mA this expands to 92 lumens. Doesn’t seem like a big deal perhaps, but with 12 emitters in the M43 that adds up to a 920 1104 lumen gain for the top dawg. (Again, according to the datasheets) At any rate, Cree says the third group of numbers is internal coding, where all the zero’s are. The coded numbers are doubled above due to min 65 CRI and min 70 CRI columns on the datasheet.
Has anyone seen any information that would lead us to believe the die is different? Would this HI be any different with all the silicone removed, a full de-doming?
Here’s what they say in they’re intro… (I’m sure most of you have already studied this…)
“The XLamp® XP-L High-Intensity LED is the first of Cree’s new class of High-Intensity LEDs optimized to deliver maximum candela through secondary optics. The XP-L High-Intensity LED is the first single-die LED to deliver over 100,000 cd in a 4-degree beam with a 50-mm diameter optic at 10 W. Built on Cree’s breakthrough SC5 Technology™ Platform, the XP-L High-Intensity LED delivers more than double the candelas of the industry’s previous highest-performing single-die XP-L LED through the same optic.”
So I’m wondering if this “new” SC5 Tech is being employed in any other version? Or is the chosen flat silicone domeless style solely responsible for the tighter 115 degree visual angle? Curiouser and curiouser…
I got pretty much the same Q's, so can't help much. I'm thinking though these have all the characteristics of what we do de-doming wise - double the candela, tighter beam, possible tint shift (coolest tints not available), and lumens loss (only available in lower bins). Everything I see leads me to believe they are using the same XP-L dies.
when you say “lumen loss” what exactly are you saying? from the 7000k down to the lowest bin 5000k how much lumen loss is there?
I have a xpl hi (from mouser, the not so great bin one) in house, but have no time to do a test right now (need a bit of zen too for testing). I hope in a few days time. Perhaps that answers some questions about output and performance.
