Have another question. Please don't take my questions as attempts to get the rules bent. I will comply with what ever your rulings are. Not pushing for yes' to my questions. Just need an answer so I can plan accordingly.
And some of us even less intelligent people bought a lathe without working feed gears. Threading isnāt possible with my lathe except with taps and dies.
Fortunately as I found out, Iām not limited to using my lathe.
Are CNC lasers and benders frowned upon? If I used them Iād do all the programming and operating, and itās in a machine shop, so it fits in your description of acceptable tools. No pressure, just checking.
Interesting, a machine such as a drill press is listed and then limited in the way itās used? Due to whether or not itās ālabor intensiveā?
Iāve used a table saw to cut off bar stock, even to reduce the diameter of bar stock by manually turning the part in order to get a shank that would fit in the drill press. Then Iāve used the drill press to spin the bar stock and manually manipulated the table to use a broken planer blade in a drill press vise as a cutting tool to turn the bar stock down and shape it, much like a lathe but in a very primitive manner. So would this type of usage be prohibited? Obviously, I canāt cut threads that way.
Get ahead of the work with the table and it can pop the chuck off the 25 yr old benchtop drill press from Harbor Freight, sending the part/chuck flying onto a concrete floor and making one scramble to keep toes clear. (ill fitting press fit taper chuck)
Recently made a .500 S&W MagLight with this technique, turning a 1/2ā Titanium bar into a hollowpoint bullet for the reflector and pill housing, using brass threads cut off a plumbing fitting to screw this light engine into the .500 Mag brass. Would doing something like this be ok?
Made this 431 lumen XP-L V6 3D light for rdrfronty as a token of appreciation for making my Dadās day with a gifted live .500 S&W round that he showed off to all his domino buddies. Even made an elephant skin sheath for it to keep dust/pocket lint out of the hollowpoint/reflector.
The actual primer is used to engage the omten clicky inside. Boring out the tapered walls of the brass was fun! The drill press method was used to inset the base of the ti bullet so the light engine would fit inside with the 10mm sinkpad and XP-L. Proxxon rotary to cut the hollowpoint.
(Just wanted yāall to know Iām still doing bullet lights. lol)
So, can the drill press be used in this way?
Donāt know if Iāll enter, trying to give some people some ideas
"Interesting, a machine such as a drill press is listed and then limited in the way itās used? Due to whether or not itās ālabor intensiveā?"
I wanted to ask something along that line too, but this statement stopped me short of asking:
"Let's try to be keep this event FUN and the rules loose and flexible enough. Judges will lower the score if they think that a contestant is bending the rules too much."
I second your question. At this point, I don't care if I am looked at as bending the rules by asking questions. I'm all for fun, but mysterious rules take a lot of the fun out for me.
Being told you can use a tool is clear. Being told you can use in in certain ways (with no clear guidelines) is not. I've spent a good amount of my planning time the last couple days trying to think of how to do things that will be considered acceptable to how I think the judges will be thinking.
As far as keeping the rules loose and flexible, that is totally in the control of the rule maker, not the competitor.
I think itās important to keep in mind the distinction between hand made and machine made. Using a bench tool with guides to cut a part vs using the same tool to shape a part. There will always be grey areas and if you chose to go there then just be sure the results justify the risks. Itās supposed to be fun so worrying about winning or loosing points because of methods is contraindicated. Just do it, donāt let the rules stifle your imagination. In the hand made category itās all about doing the most with the least and sharing creative ways to get it done.
DBCstm, ImA4Wheelr: You are right. The rules are a bit vague about those things.
We (Judges) will discuss about this issue and we hope we can come up with a clear list what's allowed and what's not.
Please allow a couple of days for all judges to respond.
The original categorization was based on what tools are commonly available -> hand made, and what are usually used only in machine shops -> machine made.
In my opinion hand made lights should look and feel hand made, not having too fancy "lathe-like" designs. But that's just me. Other judges might disagree..
I have nothing but big time respect for you and your above opinion. I, however, disagree with some of what you say
"think itās important to keep in mind the distinction between hand made and machine made."
I have thought a lot about it. I think you and I just have different ideas as to what the differences are.
"Using a bench tool with guides to cut a part vs using the same tool to shape a part."
This is a pretty arbitrary line. Both activities change the shape of the part. I consider myself a pretty average joe with average joe tools. One of the things I like about this competition is that other average joe's out there show me new ways to accomplish things I didn't realize I could accomplished the same or other average joe tools. Restricting how tools are used limits the range of things that can be be accomplished. That reduces what I consider one of the "funnest" parts of the competition.
Yes, there are people with even more limited means than me. That is why I proposed that there be true handmade category with no electric tools allowed at all. That way, those people and people that want that type of challenge can compete on a fairly level ground. The current "hand made" category left that concept behind long ago. To invoke it now requires some arbitrary lines to be drawn such as the one you chose above.
"There will always be grey areas and if you chose to go there then just be sure the results justify the risks."
Agreed, but the grey areas don't have to be such large easy targets.
"Itās supposed to be fun so worrying about winning or loosing points because of methods is contraindicated."
This is a contest, right?
That being said, I have no illusions that I have a chance of winning this competition. I, however, would like to comply with the rules if I participate.
"Just do it, donāt let the rules stifle your imagination. "
Trying, but the rules combined with my desire to compete fairly is stifling my imagination. This is the planning stage. Trying to brainstorm and map the path ahead. It's a bit hard to do when you don't have clear boundaries to operate in.
"In the hand made category itās all about doing the most with the least and sharing creative ways to get it done."
Here is probably the core of our difference in perspective. The rules would be much more restrictive if that was the case. To me, this competition is all about making the most with what you have available (and is permitted by the rules). It's great to see the amazing things people can imagine and make real. Vague restrictions will hamper that and cause the end products to be much more similar.
EDIT: Fixed some typos and clarified wording in a couple spots.
See, itās all about imagination. If a guy happened to have an old foot cranked weaving machine he might imagine a way to mount a bar of aluminum on it. Then he could spin the part, like a lathe, with pedal power and no electricity at all. Then, if he again imagined a way to mount a screw shaft brace that might hold a carbide bit, heād have himself a human powered lathe and could do most anything he desired, and still no electricity burned. So the application of the tools is what gives a professional result, limited only by oneās imagination.
Like Scott says, just go for it and see what you come up with. Judging panel be damned! (oops, sorry judges, yāall know what I mean!) At the end of the day itās about the creation, not the win.
