Well, only if the LED were positioned at the focal point of the curve. Look at how integrating spheres work. They donāt focus the light back to the LED. They are spherical, yet they scatter the light evenly in every direction. The position of the light source influences where the curve will focus the light back to.
If the led is not at the focus point the light will scatter, thats why reflectors are parabolic, all light is reflected at a known angle, light from the source must be reflected at different angles at different places of the reflector so they all come out the front at the same required angle.
Put a led pointing in at the focal point of a parabolic dish with edges at 45 degreeās and all of the light emitted will be focused by the reflector
Reflectors in flashlights are getting hit with light from behind. Or, you could say, from the back edge of the parabola. The light is travelling in a specific way and the parabola forms it a specific way in order to focus a beam outward. Here, weāre talking about a light source pointing toward the front of the curve, not from the back. That makes things a bit different. If you think about a perfect sphere, and a point source at the center, all the light is focused back to center, as you said before. If you move the point source, the light will still be focused but not to the same place or at the same angle. That is because the angle that the light hits the curve is no longer perpendicular or 90 degrees to the surface of the curve.
I just did a quick online search and found this webpage. The āLesson Threeā talks about concave mirrors and how light reflection works with them. I was unable to find specific mention of a distinction between parabolic vs spherical surfaces. But, the way the text was worded suggests that they are assuming a spherical mirror shape.
I wonder if you could shape a parabolic mold negative(think beehive shape) then use it to cast a Fiberglas and epoxy reflector. Do your best Richard Dreyfus imitation. Whom knows? You might even be able to pick it up. Kind of like the way integrating spheres are done but in a parabola.
Hereās a parabolic mirror on ebay that is in bidding. As of 1:00 PM EST, it has one bid and is at $9USD. Listing says it will ship to Australia. Has free shipping.
Believe me, I spent a lot of time searching on-line for something suitable, with a reasonable price.
I'm choking on forking out for four XHP's, never mind ~$150 for a reflector...
I have some "97%" reflective flexible adhesive mirror squares in the mail, so I'm really just looking for a suitable shape to coat with them, although a 'ready to go' reflector would be nice.
Explain to me why I can't use the satellite dish if it's tilted on an angle, or if the emitters are off-center?
This seems to be the best option I can find in a pre-made solution. Almost perfect size for the body I have, good focal length, only costs half the earth... I know I can get it in a couple of days, being local to me. Not sure what impact the small hole in the center would have, but I could patch that with some reflective material.
Of course, the other solution is to make something.... after a bit more searching, I came across this site, which made understanding the parabola easier for me.
I'm also planning to make a few cardboard parabola cut-outs that I can take to the dollar-store, in the hope that they may have a dish/bowl that just happens to have a parabolic contour.
