XP-L High Intensity vs XP-L vs XP-L DeDomed
62 posts / 0 new
pflexpro
Last seen: 7 months 1 week ago
I have just finished testing the XPL High Intensity emitter and thought I would share the results. I wanted to see the difference between the H.I. and a dedomed emitter. Keep in mind, this test was only a single emitter test and if the test were repeated several times, each outcome would probably be a little different.
I used a single host (Convoy C8 3.8A potted) and a single battery (Efest 35A 18650) for the test. I used three emitters: an XPL V5-2A, XPL V5-2A heat dedomed – unsealed, and an XPL H.I. U2-1A.
I would have preferred to use the XPL V6-1A, but I don’t stock 1A in XPL.
Each emitter was mounted in the host and the following measurements were done: OTF lumens, throw (to .25lux), and beam pattern. The test battery was recharged and allowed to rest 1 hour before and between the OTF test and the throw test. The test emitter was removed and the next test emitter was installed -then the test series was repeated.
For the output test, I mounted the light in my integrating sphere. Although, I was only looking for the ANSI -30 second measurement, I continued to three minutes and plotted the results of all three on one graph:
!Integrating Sphere PFlexPRO photo intergrating sphere -logo_zpswrcsr8rq.jpg!
The flashlight was fan cooled during the output test -I have adjusted the fan to approximate the amount of cooling as if the flashlight were being handheld…although, for a 3 minute run, the cooling doesn’t make much difference.
Output test result:
! photo XPL H1 test_zpsaxktwj4l.jpg!
The overall output for the dedomed was just over 10% less than the domed version. The output of the H.I. was about 12% less (remember, I’m comparing a V6-2A to a V2-1A)…I haven’t checked the specs…but that sounds about right. I was hoping the H.I. would be higher that the dedomed, but it’s slightly lower…still close.
Next, I checked the throw for each emitter setup calculating meters to .25lux as specified in ANSI FL-1. I have recorded the throw on a photograph of the beam shots. I want to apologize, but my house doesn’t have a white wall…so the photos are on a ‘Toasted Cashew’ wall. I used manual exposure (same exposure for each) and I set the white balance to 6000°K.
! photo XPL H1 Throw test_zpshgzn9qao.jpg!
As expected, the dedomed had considerable color shift. Any color difference seen between the XPL and XPL H.I. is a result of using a 2A emitter and a 1A emitter.
I added one more photo of the H.I. emitter using an Orange peel reflector…this was an afterthought…all of the output test were done with a smooth reflector. Notice, the rings in the dedomed and H.I. emitter with the smooth reflector. I knew the orange peel reflector would smooth out the beam pattern, but it’s the first time I’ve taken a controlled reading on the effect of orange peel on throw. The orange peel reflector caused an 8 meter drop in throw…with a much nicer beam. I’ve always use a smooth reflector in my personal lights, but I think I will keep the orange peel in this light.
Back to the results: So, in this limited test, the dedomed was brighter than and had better throw than the XPL High Intensity…but by only a very small margin. The results were close enough, I think if I had sealed the dedomed led, the High Intensity may have come out on top.
The important thing is: no more weird color shifts, no more broken bond wires, no more stopped up led seal nozzles…no more dedoming for me!
ReManG
Last seen: 4 hours 55 min ago
This is great! I am thinking of dropping in a XP-L HI into my C8 and this is just what I was looking for. I am with you on the no more DeDoming, I have only done a couple, but this HI version is just the ticket for me. I think it is interesting that the Orange Peel reflector only lowers the throw by 8 meters… If you get time, post some outside beamshots with the XP-L HI and both reflectors, probably can not tell the difference then…
Thanks for this write up…
MRsDNF
MRsDNF's picture
Last seen: 17 hours 17 min ago
Thanks for showing us the results of your testing. Nice looking sphere.
Halo...
Halo...'s picture
Last seen: 4 years 3 months ago
Thanks! Beer Beer
viperbart
viperbart's picture
Last seen: 1 year 6 months ago
Whoa. Nice setup!
Thanks for sharing the info!
No more dedomes!
shrike3612
Thanks for great review!
It’s very helpful.
Ejected Filament
Ejected Filament's picture
Last seen: 2 years 5 months ago
We need to organise a get together, a few us distract pflexpro, while I steal the sphere.
sesgum
sesgum's picture
Last seen: 3 days 6 hours ago
Wow thanks for the comparison. Exactly what I have been waiting for.
The XPL HI 1A seems perfectly pure white, totally different from a dedomed XPL.
Now I will just wait for a nice thrower with REAL XPL HI cool white.
Thanks again! Cheers!
sesgum
sesgum's picture
Wish you could do some outdoor beam shots to see tint difference. Smile
pflexpro
You know you’ve been robbed by a flashaholic when your integrating sphere is stolen, but the laptop sitting next to it is left behind.
Jubeldum
Jubeldum's picture
Last seen: 4 years 9 months ago
You know you’ve been robbed by a flashaholic when your integrating sphere is stolen, but the laptop sitting next to it is left behind, missing it’s battery.
Fixed that for you. Smile
pflexpro
come on…I just rebuilt that battery pack with 6 Panasonic 3400s.
ReManG
HA! I was thinking the same thing…
On the other hand, Perhaps our OP has been the ultimate lurker…. ~73 posts and a member with an integrated sphere since 2013… someone has been holding out…
Rusty Joe
Rusty Joe's picture
Last seen: 6 hours 39 min ago
Very good news! Thanks for the comparisons.
pflexpro
I strategically did the test so the XPL HI would be left in the flashlight last. I intend on rerunning a similar test in the M1 -I want to see if an M1 with the high intensity will come close to the throw of a C8 with a standard XPL or XML2. I can do some real beam shots with that test.
I’ve also started offering the HI in the small Convoy S2 and S2+ -with such small reflectors, more throw will be a good thing and with no dedoming…why not?
makapuu
Now that’s a sphere !!! Wonder if I can make one of those with my old Weber grill. LOL
Hikelite
Last seen: 5 hours 22 min ago
I would say that your results fit into the CREE datasheets ratings, here I mean the percentage difference between the XP-L HD V5 and XP-L HI V2 is 14%
lower lumen output according to the datasheets (3A current), and you test shows 13% lower lumens at 0.5minutes mark. Yes, throw is another thing but I was only pointing out the lumen difference between those 2 bins.
Hikelite
sesgum wrote:
Wow thanks for the comparison. Exactly what I have been waiting for. The XPL HI 1A seems perfectly pure white, totally different from a dedomed XPL. Now I will just wait for a nice thrower with REAL XPL HI cool white. Thanks again! Cheers!
1A is not totally pure white, in the shots you see the close-up hot spot at high current, and you can see the spill is blueish. But anyway I speak from personal experience saying that 2A or even 2B will be the pure white one and the 1A is still the classic slight blueish cool white. If you are after something that gives the impression of pure white I high recommend you try those tints.
pflexpro
I think everything is fairly close. The only variation may be the dedomed. I find that sealing the emitter after dedoming lowers the output some…depending on how many coats of sealer is used. I seem to remember finding that hot dedoming yields a little higher output than solvent. If dedoming is properly done (heat dedome and 2 coats of ‘led seal’), I think the the XPL HI would have had higher output and more throw…but again, it’s close enough for me.
All of this is water under the bridge…I don’t plan on intentionally dedoming an XPL or XML2 again. I may still dedome a few XPG2 emitters…but that will be very few.
Everything in the specs pointed to the results I got, but I always want to see it for myself.
will34
will34's picture
Last seen: 3 hours 50 min ago
Thanks for the test! No more dedoming for me as well.
Tint > output in most situations.
Mike C
Mike C's picture
Last seen: 2 months 4 days ago
Threads like this make me happy. Someone is willing to go through all the trouble to test and compare, and then post the results so others don’t have to. Thanks Beer
djozz
djozz's picture
Last seen: 47 min 8 sec ago
Great testing, well thought out and performed, as all of your tests, thanks! Smile
So the HI indeed does not seem to perform any different than a dedomed XP-L, that is good news for dedoming/tintshift-haters, a bit disappointing for those (me) who still hoped for a new level of performance.
I was planning on an output test of the HI (I have two emitters from Mouser, U5 bin), but this will make it much less exciting, I think I will skip that until after my (two weeks) camping  trip Innocent
I'd love to steal your integrating sphere too (one can not have too many integrating spheres Laughing), it looks very neat. Did you make it yourself? (it looks so slick, it could be a commercial one). Would you elaborate on the features?
djozz
djozz's picture
I see another (for me) interesting thing in your graph, I wonder how significant it is: the domed XP-L has a dead-contant output after 1 minute, while both dome-less XP-L's show a slow decrease of output throughout the three minutes test-run. Any idea's what reason there could be for that? (I don't btw).
DavidEF
DavidEF's picture
Last seen: 8 hours 44 min ago
djozz wrote:
I see another (for me) interesting thing in your graph, I wonder how significant it is: the domed XP-L has a dead-contant output after 1 minute, while both dome-less XP-L’s show a slow decrease of output throughout the three minutes test-run. Any idea’s what reason there could be for that? (I don’t btw).
The High Intensity has an almost flat output after two minutes. I wonder how the dome/seal are affecting the output constancy. With the small sampling of this test, there is no way to be sure that it isn’t being affected by something else, but it sure looks like a line could be drawn (no dome => some dome => full dome) with increasing output stability. Could it be that the dome helps relieve a little bit of heat, since just about everything is better at conducting heat than air?
- The YKK Philosophy
pflexpro
There are 2 possible contributors to the flatness or the stability of the output…one is absolute and the other is a possibility:
Absolute: The power going into the emitter has only 2 ways to exit: light or heat. The domed led is putting out more light and therefore there is less heat. If there is less heat to deal with, the output will become stable earlier in the test.
Possible: The domed emitter has greater surface area and thermal mass. The effect of the dome’s thermal mass (although very small) will be seen in the initial output. The initial output (first few seconds) the drop from the domed emitter is less. With greater surface area, like any heat sink, the dome may be removing more heat and this could explain why the domed emitter is flatter after 2 minutes. The effect of the greater surface area and mass of the dome are just my guesses, both may be too insignificant to make any real difference.
The test sampling size is just too small to draw any real conclusions from these minor variations.
pflexpro
I’d love to steal your intergrating sphere too (one can not have too many integrating spheres Laughing), it looks very neat. Did you make it yourself? (it looks so slick, it could be a commercial one). Would you elaborate on the features?
I consider it a complement that anyone would think my integrating sphere is a commercial model, but it’s one of several that I’ve made. It is constructed of 2 22” security domes. The sphere is not quite spherical…it’s 21.25” wide, but only 20.5” tall. The inside is coated with 8 coats of barium sulfate/paint. Old lumens has a thread where he is building a similar one. If I were to build another, there are very few things I would do different, so overall, I’m happy with it’s accuracy and functionality. The biggest problem I have (and anyone who has built any kind of integrating sphere/device) is calibration. I’m using ANSI rated flashlights to do a comparative calibration. While this works okay, it doesn’t come close to a using an ANSI rated light source. I test the output on every flashlight I sell, so the performance of the sphere is very important to me…but not important enough to drop $20K on a commercial sphere and light source.
djozz
djozz's picture
I'd love to steal your intergrating sphere too (one can not have too many integrating spheres Laughing), it looks very neat. Did you make it yourself? (it looks so slick, it could be a commercial one). Would you elaborate on the features?
I consider it a complement that anyone would think my integrating sphere is a commercial model, but it's one of several that I've made. It is constructed of 2 22" security domes. The sphere is not quite spherical...it's 21.25" wide, but only 20.5" tall. The inside is coated with 8 coats of barium sulfate/paint. Old lumens has a thread where he is building a similar one. If I were to build another, there are very few things I would do different, so overall, I'm happy with it's accuracy and functionality. The biggest problem I have (and anyone who has built any kind of integrating sphere/device) is calibration. I'm using ANSI rated flashlights to do a comparative calibration. While this works okay, it doesn't come close to a using an ANSI rated light source. I test the output on every flashlight I sell, so the performance of the sphere is very important to me...but not important enough to drop $20K on a commercial sphere and light source.
Thanks for the information, you seem to encounter the same limitations as I Undecided ! It sounds like a great device, as good as one can make without spending the multi-kdollar of money Smile
Jubeldum
Jubeldum's picture
Maybe there is something to that. The domes on the LEDs in newest generation of Cree light bulbs (the ones without a heat sink) have tall square shaped domes.
I wonder what LED this is? The new BR30 flood lights are supposed to use XHP LED.
bibihang
bibihang's picture
Awesome stuff! I mean both of your review and the integrating sphere!
I am quite surprised that the tint if the XP-L HI appears to be pure white. I used to shave the dome of an old XM-L (with cool white tint originally) before and the tint started to shift to warmer side even though I only shaved a small portion of it. This is why I am surprised with the cool white tint of this XP-L HI especially its silicon layer appears to be fairly thin. I guess it may have something to do with the die itself.
On the other hand, while some people are happy with the tint of this XP-L HI, I believe there are still certain people who prefer the neutral white tint produced by our ‘conventional’ dedome methods. I know that some of these produce terrible greenish tint, but I’ve also seen some XM-L2 do produce fairly nice neutral white tint too. Maybe CREE will offers different tints for this XP-L HI too in the future, we will wait and see for that.
Beside that, while XP-L HI seems to be quite a good and convenient selection for maximum throw modding project, some XM-L2 reflectors do not fit very well with XP-L/XP-G2 size of emitters. Some examples would be those which require XM-L2 centering piece, like the new version Convoy C8, JAX Z1, HD2010, T08… etc.
power911
power911's picture
Last seen: 20 hours 50 min ago
these square domes just made me sad as I have accidentally tore the domes of my rgb LEDs in my mouse
why did I even do that…
but these domes seem to scatter light well for a flood compared to sphere which cause some slight pointy artifacts
I had no idea how things work
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
DavidEF
DavidEF's picture
I think you’re looking at it as if the XPL HI is “de-domed” like we do around here. But, that is not the case. The color binning is done after production. So, the tint will be what they bin it as. It may take a different mix of phosphors to produce the same tint as one with the dome on. But they don’t bin it by the phosphor mix, they bin it by the light output after production.
