This is great! I am thinking of dropping in a XP-L HI into my C8 and this is just what I was looking for. I am with you on the no more DeDoming, I have only done a couple, but this HI version is just the ticket for me. I think it is interesting that the Orange Peel reflector only lowers the throw by 8 meters… If you get time, post some outside beamshots with the XP-L HI and both reflectors, probably can not tell the difference then…
Wow thanks for the comparison. Exactly what I have been waiting for.
The XPL HI 1A seems perfectly pure white, totally different from a dedomed XPL.
Now I will just wait for a nice thrower with REAL XPL HI cool white.
Thanks again! Cheers!
On the other hand, Perhaps our OP has been the ultimate lurker…. ~73 posts and a member with an integrated sphere since 2013… someone has been holding out…
I strategically did the test so the XPL HI would be left in the flashlight last. I intend on rerunning a similar test in the M1 -I want to see if an M1 with the high intensity will come close to the throw of a C8 with a standard XPL or XML2. I can do some real beam shots with that test.
I’ve also started offering the HI in the small Convoy S2 and S2+ -with such small reflectors, more throw will be a good thing and with no dedoming…why not?
I would say that your results fit into the CREE datasheets ratings, here I mean the percentage difference between the XP-L HD V5 and XP-L HI V2 is 14%
lower lumen output according to the datasheets (3A current), and you test shows 13% lower lumens at 0.5minutes mark. Yes, throw is another thing but I was only pointing out the lumen difference between those 2 bins.
1A is not totally pure white, in the shots you see the close-up hot spot at high current, and you can see the spill is blueish. But anyway I speak from personal experience saying that 2A or even 2B will be the pure white one and the 1A is still the classic slight blueish cool white. If you are after something that gives the impression of pure white I high recommend you try those tints.
I think everything is fairly close. The only variation may be the dedomed. I find that sealing the emitter after dedoming lowers the output some…depending on how many coats of sealer is used. I seem to remember finding that hot dedoming yields a little higher output than solvent. If dedoming is properly done (heat dedome and 2 coats of ‘led seal’), I think the the XPL HI would have had higher output and more throw…but again, it’s close enough for me.
All of this is water under the bridge…I don’t plan on intentionally dedoming an XPL or XML2 again. I may still dedome a few XPG2 emitters…but that will be very few.
Everything in the specs pointed to the results I got, but I always want to see it for myself.
Threads like this make me happy. Someone is willing to go through all the trouble to test and compare, and then post the results so others don’t have to. Thanks
